The dilation angle is small or zero. The value will be set to 0.10000
A geostatic procedure with maximum displacement tolerances is supported only for the following materials: elastic, porous elastic, extended cam-clay plasticity model and mohr-coulomb plasticity model. In general, the use of other materials with this procedure may lead to poor convergence or no convergence of the analysis.
In step 2, removal specified for element 178 instance tuti-1 is redundant and ignored. This element is already inactive. This message will be printed a maximum of 10 times.
In step 2, removal specified for element 282 instance tuti-1 is redundant and ignored. This element is already inactive. This message will be printed a maximum of 10 times.
In step 2, removal specified for element 392 instance tuti-1 is redundant and ignored. This element is already inactive. This message will be printed a maximum of 10 times.
There are 3 unconnected regions in the model.
The strain increment is so large that the program will not attempt the plasticity calculation at 1424 points
