- 13
- 2003-4-29
发表于 2011-9-25 20:12:17
来自 广东珠海
刚从网上下了一个原始prototypeApp分享一下
百思原帖 有没有人用GUI toolkit设计界面?
弄错了本版就有
[16.二次开发] ABAQUS Plug-ins系列分享http://www.simwe.com/forum/forum.php?mod=viewthread&tid=765925
下了半个月没去看,,不过里面没有run.bat
楼主可能是用正版用户,本人业余爱好
2.4 Running the prototype application
A custom application called the prototype application is available from the Abaqus Process Automation
Portal. The prototype application allows you to experiment with the contents of your dialog box until you
produce a design that is satisfactory. You can start the prototype application, make changes to the code
that controls the contents of the dialog box, and instantly see those changes re?ected in the application.
You can access the portal from the Abaqus/CAE Plug-ins→Abaqus→Process Automation
Portal menu. The portal provides examples of plug-ins and customized applications as well as
access to a community of users that fosters the advance of the Abaqus Scripting Interface and the
Abaqus GUI Toolkit. The prototype application is available from the GUI Examples section of the
Downloads area.
Unzip the ?les and go to the directory containing the ?les that you downloaded. To use the prototype
application, open the ?le testDB.py in a text editor. From the system prompt, enter the following:
abaqus cae -custom prototypeApp -noStartup
The -custom parameter indicates that you are executing an application that is a customized version
of Abaqus/CAE. The -noStartup parameter indicates that you want to start Abaqus/CAE without
displaying the startup screen. For more information, see “Abaqus/CAE execution,” Section 3.2.3 of the
Abaqus Analysis User’s Manual.
The application creates two icons in the toolbox, as shown in Figure 2–2.
好像正版用户的才可以下
早知道搜索一下,
