- 2009-12-4
发表于 2016-5-17 21:10:30
来自 陕西西安
楼主,您好,为什么我运行您的程序就会出现“mpid.exe已停止工作”提示,然后就不能继续运行了。
具体提示是:The executable C:\Program aborted with system error code 65535. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. |
