- 84
- 2004-3-18
发表于 2011-6-7 18:00:50
来自 安徽淮北
Engine Keyword
/PROC - Number of Processors
Description
Number of processors.
Format
/PROC/N/M
Data
Description
N
Number of MIMD processors for this run.
M
Minimum number of MIMD processors for this run.
Default = N
Comments
1. This option has no effect in the MPP (SPMD) version: the number of processors is defined in RADIOSS Starter by domain decomposition.
2. /PROC is only applied for RADIOSS SMP parallel version (for RADIOSS SPMD parallel version, the number of processors is set in the Runname_0000.rad input deck using the /SPMD option).
3. For Flexlm type licenses:
• if the number of available licenses is greater or equal to N, the computation runs normally on N processors.
• if the number of available licenses is between N and M, the computation runs on the number of available processors.
• if the number of available licenses is lower than M, the computation does not run. |
