- 2010-5-29
楼主 |
发表于 2011-6-5 10:52:41
来自 河北唐山
2# ferriswanglei
下面是HELP里面的选项,找不到等效应力那一项
Table: NSOL - Valid Item and Component Labels
Valid Item and Component Labels NSOL, NVAR,NODE,Item,Comp,Name | Valid item and component labels for nodal degree of freedom results are: | Item | Comp | Description | U | X, Y, Z | X, Y, or Z structural displacement. | ROT | X, Y, Z | X, Y, or Z structural rotation. | TEMP[1] | | Temperature. | PRES | | Pressure. | VOLT | | Electric potential. | MAG | | Magnetic scalar potential. | V | X, Y, Z | X, Y, or Z fluid velocity in a fluid analysis. | A | X, Y, Z | X, Y, or Z magnetic vector potential in an electromagnetic analysis. | VEL | X, Y, Z | X, Y, or Z velocity in a structural transient dynamic analysis (ANTYPE,TRANS). | ACC | X, Y, Z | X, Y, or Z acceleration in a structural transient dynamic analysis (ANTYPE,TRANS). | OMG | X, Y, Z | X, Y, or Z rotational velocity in a structural transient dynamic analysis (ANTYPE,TRANS). | DMG | X, Y, Z | X, Y, or Z rotational acceleration in a structural transient dynamic analysis (ANTYPE,TRANS). | CURR | | Current. | EMF | | Electromotive force drop. | ENKE | | Turbulent kinetic energy. | ENDS | | Turbulent energy dissipation. |
Table: NSOL - Valid Item and Component Labels for FLOTRAN Nodal Results
Item | Comp | Description | TTOT | | Total temperature. | HFLU | | Heat flux. | HFLM | | Heat transfer (film) coefficient. | COND | | Fluid laminar conductivity. | PCOE | | Pressure coefficient. | PTOT | | Total (stagnation) pressure. | MACH | | Mach number. | STRM | | Stream function. (2-D applications only.) | DENS | | Fluid density. | VISC | | Fluid laminar viscosity. | EVIS | | Fluid effective viscosity. | CMUV | | Turbulent viscosity coefficient. | ECON | | Fluid effective conductivity. | YPLU | | Y+, a turbulent law of the wall parameter. | RDFL | | Radiation heat flux. |
Table: NSOL - Valid Item and Component Labels for ANSYS LS-DYNA Nodal Results
Item | Comp | Description | U | X, Y, Z | X, Y, or Z nodal displacements. | ROT | X, Y, Z | X, Y, or Z nodal rotations. | V | X, Y, Z | X, Y, or Z nodal velocities. | A | X, Y, Z | X, Y, or Z nodal accelerations |
