- 1
- 2009-4-15
发表于 2011-9-29 15:27:10
来自 江西南昌
在这一经典的vumat好贴中,我弱弱地向各位版主提一个问题。 我用vumat编写的johnson-cook模型,运行时遇到693的错误。不清楚程序到底哪里有误。请daivvife 等版主帮忙看看, 真的感激不尽!
c User subroutine VUMAT
subroutine vumat (
c Read only -
1 nblock, ndir, nshr, nstatev, nfieldv, nprops, lanneal,
2 stepTime, totalTime, dt, cmname, coordMp, charLength,
3 props, density, strainInc, relSpinInc,
4 tempOld, stretchOld, defgradOld, fieldOld,
5 stressOld, stateOld, enerInternOld, enerInelasOld,
6 tempNew, stretchNew, defgradNew, fieldNew,
c Write only -
7 stressNew, stateNew, enerInternNew, enerInelasNew )
c
include 'vaba_param.inc'
c
dimension coordMp(nblock,*), charLength(nblock), props(nprops),
1 density(nblock), strainInc(nblock,ndir+nshr),
2 relSpinInc(nblock,nshr), tempOld(nblock),
3 stretchOld(nblock,ndir+nshr),
4 defgradOld(nblock,ndir+nshr+nshr),
5 fieldOld(nblock,nfieldv), stressOld(nblock,ndir+nshr),
6 stateOld(nblock,nstatev), enerInternOld(nblock),
7 enerInelasOld(nblock), tempNew(nblock),
8 stretchNew(nblock,ndir+nshr),
9 defgradNew(nblock,ndir+nshr+nshr),
1 fieldNew(nblock,nfieldv),
2 stressNew(nblock,ndir+nshr), stateNew(nblock,nstatev),
3 enerInternNew(nblock), enerInelasNew(nblock)
c
character*80 cmname
c
parameter ( zero = 0.d0, one = 1.d0, two = 2.d0,
1 third = 1.d0 / 3.d0, half = 0.5d0, op5 = 1.5d0 )
c
c For plane strain, axisymmetric, and 3D cases using
c the J2 Mises Plasticity with linear hardening.
c The state variable is stored as:
c STATE(*,1) = equivalent plastic strain
c STATE(*,2) = plastic strain rate
c
c
c User needs to input
c props(1) Young's modulus
c props(2) Poisson's ratio
c props(3) A
c prpps(4) B
c prpps(5) n
c prpps(6) C
c prpps(7) m
c
c
e = props(1)
xnu = props(2)
A = props(3)
B = props(4)
EN = props(5)
C = props(6)
EM = props(7)
twomu = e / ( one + xnu )
alamda = xnu * twomu / ( one - two * xnu )
thremu = op5 * twomu
if ( stepTime .eq. zero ) then
do k = 1, nblock
trace = strainInc(k,1) + strainInc(k,2) + strainInc(k,3)
stressNew(k,1) = stressOld(k,1)
1 + twomu * strainInc(k,1) + alamda * trace
stressNew(k,2) = stressOld(k,2)
1 + twomu * strainInc(k,2) + alamda * trace
stressNew(k,3) = stressOld(k,3)
1 + twomu * strainInc(k,3) + alamda * trace
stressNew(k,4)=stressOld(k,4) + twomu * strainInc(k,4)
if ( nshr .gt. 1 ) then
stressNew(k,5)=stressOld(k,5) + twomu * strainInc(k,5)
stressNew(k,6)=stressOld(k,6) + twomu * strainInc(k,6)
end if
end do
else
do k = 1, nblock
c
c calculate hard and yieldOld
c
peeqOld=stateOld(k,1)
c
if(peeqOld.eq.zero) then
yieldOld = A
else
hard = EN * B * peeqOld ** (EN-1)
yieldOld = A + B * peeqOld ** EN
end if
s11 = stressOld(k,1) + twomu * strainInc(k,1) + alamda *
1 trace
s22 = stressOld(k,2) + twomu * strainInc(k,2) + alamda *
1 trace
s33 = stressOld(k,3) + twomu * strainInc(k,3) + alamda *
1 trace
s12 = stressOld(k,4) + twomu * strainInc(k,4)
s13 = stressOld(k,5) + twomu * strainInc(k,5)
s23 = stressOld(k,6) + twomu * strainInc(k,6)
end if
c
smean = third * ( s11 + s22 + s33 )
s11 = s11 - smean
s22 = s22 - smean
s33 = s33 - smean
if ( nshr .eq. 1 ) then
vmises = sqrt( op5*
1 (s11*s11+s22*s22+s33*s33+two*s12*s12) )
else
vmises = sqrt( op5 * ( s11 * s11 + s22 * s22 + s33 * s33 +
1 two * s12 * s12 + two * s13 * s13 + two * s23 *
2 s23 ) )
end if
c
tvp = C * log(stateOld(k,2))
tvp1 = tvp + one
hard1 = hard * tvp1 + yieldOld * C / stateOld(k,2)
yieldOld = yieldOld * tvp1
sigdif = vmises - yieldOld
facyld = zero
if ( sigdif .gt. zero ) facyld = one
deqps = facyld * sigdif / (thremu + hard1)
c
c Update the state variable
stateNew(k,1) = stateOld(k,1) + deqps
stateNew(k,2) = deqps/dt
c
c
c
c
c Update the stress
yieldNew = yieldOld + hard1 * deqps
factor = yieldNew / ( yieldNew + thremu * deqps )
stressNew(k,1) = s11 * factor + smean
stressNew(k,2) = s22 * factor + smean
stressNew(k,3) = s33 * factor + smean
stressNew(k,4) = s12 * factor
stressNew(k,5) = s13 * factor
stressNew(k,6) = s23 * factor
end if
c
c Update the specific internal energy -
c
stressPower = half * (
1 ( stressOld(k,1) + stressNew(k,1) ) * strainInc(k,1) +
2 ( stressOld(k,2) + stressNew(k,2) ) * strainInc(k,2) +
3 ( stressOld(k,3) + stressNew(k,3) ) * strainInc(k,3) ) +
4 ( stressOld(k,4) + stressNew(k,4) ) * strainInc(k,4)
else
4 ( stressOld(k,4) + stressNew(k,4) ) * strainInc(k,4) +
5 ( stressOld(k,5) + stressNew(k,5) ) * strainInc(k,5) +
6 ( stressOld(k,6) + stressNew(k,6) ) * strainInc(k,6)
end if
enerInternNew(k) = enerInternOld(k) + stressPower / density(k)
c
c Update the dissipated inelastic specific energy -
plasticWorkInc = yieldNew * deqps
enerInelasNew(k) = enerInelasOld(k)
1 + plasticWorkInc / density(k)
end do
end if
return
end
c |
