- 12
- 2010-3-27
发表于 2011-7-26 10:18:04
来自 江苏镇江
ANALYSIS RESULTS :
ITERATION 0
Element # 111373, element type TETRA.
WARNING - Outside of recommended range: Face Skew Angle = 76.720
upper limit = 75.000
WARNING - Outside of recommended range: Face Vertex Angle = 9.1146
lower limit = 15.000
Element # 111375, element type TETRA.
ERROR - Acceptable range violation: Face Skew Angle = 86.967
upper limit = 85.000
WARNING - Outside of recommended range: Face Vertex Angle = 171.87
upper limit = 165.00
ERROR - Acceptable range violation: Face Vertex Angle = 1.8633
lower limit = 3.0000
WARNING - Outside of recommended range: Edge Angle = 86.158
Element # 111376, element type TETRA.
WARNING - Outside of recommended range: Edge Angle = 79.449
NOTE : other similar error/warning messages were suppressed,
use PARAM,CHECKEL,FULL to obtain full report
Element # 111377, element type TETRA.
WARNING - Outside of recommended range: Edge Angle = 82.001
Element # 111379, element type TETRA.
WARNING - Outside of recommended range: Face Skew Angle = 84.632
Element # 111612, element type TETRA.
WARNING - Outside of recommended range: Face Aspect Ratio = 51.376
upper limit = 50.000
ERROR - Acceptable range violation: Face Skew Angle = 87.808
ERROR - Acceptable range violation: Face Vertex Angle = 1.1000
Element # 111775, element type TETRA.
ERROR - Acceptable range violation: Face Skew Angle = 86.152
ERROR - Acceptable range violation: Face Vertex Angle = 1.9253
Element # 113410, element type TETRA.
ERROR - Acceptable range violation: Edge Angle = 87.816
upper limit = 87.000
Element # 114930, element type TETRA.
WARNING - Outside of recommended range: Face Aspect Ratio = 63.157
ERROR - Acceptable range violation: Edge Angle = 88.834
*** ERROR # 2203 ***
Error(s) encountered during element check
***** Element Quality Check Failed - error limits violation *****
NOTE : To bypass element quality checks (except essential validity checks)
use PARAM,CHECKEL,NO. This may, however, cause very poor results.
看看您的OUT文件。。 |
