- 2007-1-11
file:///D:/mydoc/My
*** ERROR *** CODE ADF2701:
Fluid node (label) 1 is not attached to solid fluid-structure
interface 1. The relative distance to solid boundary element
152 is 1.00E+02.
The fluid nodal coordinates are (0.00E+00, 0.00E+00, 0.00E+00).
The points and their coordinates of the solid boundary element are:
point 1 = ( 4.000E+01, 0.000E+00, 0.000E+00)
point 92 = ( 4.000E+01, 1.600E-01, -4.00E-01)
point 7 = ( 4.000E+01, 4.000E-01, 0.000E+00)
Possible causes are:
* Fluid-structure interfaces in fluid and solid models are not
coincident;
* Solid boundary elements are too coarse compared with fluid boundary
elements on the same fluid-structure interface.
Recall that fluid-structure interfaces are specified in both fluid and
solid models. They must be coincident with each other. However, it is
normal to have a small distance between fluid nodes and solid
fluid-structure interfaces if meshes of interfaces in both models are
not matched.
The relative distance here is defined as the ratio of the distance between
the fluid node and the closest solid boundary element to the length of the
solid boundary element.
请教如何处理!!有酬谢!
我的QQ:10932901 |
