- 22
- 2009-2-10
美国金属手册,相当权威的工具书,目前仍缺VOL22A,VOL14B,希望有的童鞋拿出来共享。其中有几本版本较旧,没有目录索引。网上很多下载链接都已经失效,包括本论坛中的http://forum.simwe.com/forum.php ... 6&highlight=asm,现重新上传,其他的不多说了,要下的速度。
ASM Handbook deskedtion
http://u.115.com/file/bhuw644m#
Desk+Edition.pdf
ASM Handbook Volume 01: Properties and Selection: Ir**, Steels, and High-Performance Alloys 10th Edition
http://u.115.com/file/dneif448#
ASM_Metals_Handbook,_Vol_01.pdf
ASM Handbook Volume 02: Properties and Selection: Nonferrous Alloys and Special-Purpose Materials 10th Edition
http://u.115.com/file/bhuwx1uw#
ASM_Metals_Handbook,_Vol_02.pdf
ASM Handbook Volume 03: Alloy Phase Diagrams 9th Edition
http://u.115.com/file/aq1jdbez#
ASM_Metals_Handbook,_Vol_03.pdf
ASM Handbook Volume 04: Heat Treating 10th Edition
http://u.115.com/file/clfzrnyr#
ASM_Metals_Handbook,_Vol_04.pdf
ASM Handbook Volume 05: Surface Engineering 10th Edition
http://u.115.com/file/aq1jd3fc#
ASM_Metals_Handbook,_Vol_05.pdf
ASM Handbook Volume 06: Welding, Brazing, and Soldering 10th Edition
http://u.115.com/file/aq1jdz7h#
ASM_Metals_Handbook,_Vol_06.pdf
ASM Handbook Volume 07: Powder Metal Technologies and Applicati** 10th Edition
http://u.115.com/file/dneifhk9#
ASM_Metals_Handbook,_Vol_07.pdf
ASM Handbook Volume 08: Mechanical Testing & Evaluation 10th Edition
http://u.115.com/file/bhuwxix1#
ASM_Metals_Handbook,_Vol_08.pdf
ASM Handbook Volume 09: Metallography and Microstructures 10th Edition
ASM Handbook Volume 10: Materials Characterization 9th Edition
http://u.115.com/file/aq1jdyaj#
ASM_Metals_Handbook,_Vol_10.pdf
ASM Handbook Volume 11: Failure Analysis and Prevention 10th Edition
http://u.115.com/file/bhuwxqhz#
ASM_Metals_Handbook,_Vol_11.pdf
ASM Handbook Volume 12: Fractography 10th Edition
http://u.115.com/file/clfzrf4e#
ASM_Metals_Handbook,_Vol_12.pdf
ASM Handbook Volume 13: Corrosion 9th Edition
http://u.115.com/file/clfzrfjr#
ASM_Metals_Handbook,_Vol_13.pdf
ASM Handbook Volume 13A: Corrosion Fundamentals, Testing, and Protection 10th Edition
http://u.115.com/file/e6mqy20o#
ASM_Metals_Handbook,_Vol_13A_Corrosion_Fundamentals,_Testing,_And_Protection.pdf
ASM Handbook Volume 14: Forming and Forging 9th Edition
http://u.115.com/file/e6msoeuz#
ASM_Metals_Handbook,_Vol_14.pdf
ASM Handbook Volume 15: Casting 9th Edition
http://u.115.com/file/e6msogp7#
ASM_Metals_Handbook,_Vol_15.pdf
ASM Handbook Volume 16: Machining 9th Edition
http://u.115.com/file/clfzrtd2#
ASM_Metals_Handbook,_Vol_16.pdf
ASM Handbook Volume 17: Nondestructive Evaluation and Quality Control 9th Edition
http://u.115.com/file/clf9gnkd#
ASM_Metals_Handbook,_Vol_17,_Nondestructive_Evaluation_and_Quality_Control_9th_Edition.pdf
ASM Handbook Volume 18: Friction, Lubrication, and Wear Technology 10th Edition
http://u.115.com/file/dneif8b9#
ASM_Metals_Handbook,_Vol_18.pdf
ASM Handbook Volume 19: Fatigue And Fracture 10th Edition
http://u.115.com/file/dneifrqa#
ASM_Metals_Handbook,_Vol_19.pdf
ASM Handbook Volume 20: Materials Selection and Design 10th Edition
http://u.115.com/file/aq1jd5kj#
ASM_Metals_Handbook,_Vol_20.pdf
ASM Handbook Volume 21: Composites 10th Edition
http://u.115.com/file/bhuwxgok#
ASM_Metals_Handbook,_Vol_21.pdf
ASM_Metals_Handbook,_Vol_22B,Metals_Process_Simulation
http://u.115.com/file/e6mqy39z#
ASM_Metals_Handbook,_Vol_22B,Metals_Process_Simulation.pdf |
5
