这个例子可以学到很多东西,可以获得get命令、path定义、时间变量等多个知识点的内容,练习一下肯定大有收获。
水结冰过程分析
/filname,phase1
/title,water phase change analysis
/prep7
et,1,plane55
keyopt,1,3,1
mp,dens,1,1000
mp,kxx,1,0.6 !导热系数
MPTEMP,,,,,,,,
MPTEMP,1,-10
MPTEMP,2,-1
MPTEMP,3,0
MPTEMP,4,10
MPDATA,ENTH,1,,0
MPDATA,ENTH,1,,3.78e7
MPDATA,ENTH,1,,7.98e7
MPDATA,ENTH,1,,1.22e8 !不同温度点焓值
rectang,0,0.02,0,0.1
/pnum,line,1
/replot
lsel,s,line,,1,3,2
lesize,all,,,5
lsel,s,line,,2,4,2
lesize,all,,,20
amesh,1
eplot
finish
/solu
antype,trans
bfunif,temp,0 !施加均匀温度载荷
lsel,s,line,,1,3
nsll,s,1
sf,all,conv,12.5,-10 !分别是对流系数、空气温度
allsel
time,7200 !单位秒
deltim,30,30,100
kbc,1 !阶跃载荷
autots,on
outres,,all
solve
finish
/post1
set,,,,,1800 !读取1800秒时结果
plnsol,temp
set,last
plnsol,temp
/axlab,x,dist,(m)
/axlab,y,temp
/gthk,axis,3
/gthk,curve,3
nsel,s,loc,x,0.02 !选择节点
nsel,r,loc,y,0
*get,node1,node,,num,max !根据坐标选择最大节点编号
nsel,r,loc,y,0.1
*get,node2,node,,num,max !根据坐标选择最大节点编号
nsel,s,loc,x,0 !选择节点
nsel,r,loc,y,0.1
*get,node3,node,,num,max !根据坐标选择最大节点编号
nsel,r,loc,y,0.05
*get,node4,node,,num,max !根据坐标选择最大节点编号
nsel,r,loc,y,0.05
*get,node5,node,,num,max !根据坐标选择最大节点编号
allsel
path,tpath1,2,,30 !定义路径
ppath,1,1
ppath,2,node1
pdef,temp,temp !映射路径
plpath,temp !画出路径
path,tpath2,2,,30 !定义路径
ppath,1,1
ppath,2,node3
plpath,temp !画出路径
finish
/post26
/axlab,x,time,(sec)
/axlab,y,temp
nsol,2,node2,temp,,ta !变量定义
nsol,3,node3,temp,,tb !变量定义
nsol,4,node4,temp,,tc !变量定义
nsol,5,node5,temp,,td !变量定义
plvar,2,3,4,5
finish
/exit,all
