查看: 3620|回复: 7
[【3】商业软件] 请问viscous pressure的具体公式是什么?
发表于 2011-9-26 18:06:21 | 显示全部楼层 |阅读模式 来自 欧洲
第一次在这里发帖,诚惶诚恐,希望没有问的太低级。
在ABAQUS中可以运用viscous pressure帮助控制动能,但在ls-dyna中我还没有找到这个功能,所以想自己用公式加载。但是找遍了所有的help文件,也没有找到相应的公式。请问有人知道吗?谢谢!
发表于 2011-9-28 05:11:55 | 显示全部楼层 来自 美国
should be sort of history-dependent pressure, the help document of soft should specify the parameters and related funciton.
 楼主| 发表于 2011-10-3 18:44:49 | 显示全部楼层 来自 欧洲
caoer 发表于 2011-9-28 05:11
should be sort of history-dependent pressure, the help document of soft should specify the parameter ...
谢谢版主的回复!
我找到公式了,如附件所示。但是我对定义中的对n的解释“ the unit outward normal vector to the surface at the same point”不理解。是说n只是一个单位吗?还是有具体的数值,即垂直于表面的距离?
再次感谢!
发表于 2011-10-4 04:43:15 | 显示全部楼层 来自 美国
\vec{n} is a normalized vector, represents the direction of velocity.
the dot product of two vectors is a scaler value. thats it.
 楼主| 发表于 2011-10-6 15:43:58 | 显示全部楼层 来自 欧洲
the dot product of two vectors ...
Got it.
Thank you for your detailed explanation!
 楼主| 发表于 2011-10-20 16:55:25 | 显示全部楼层 来自 欧洲
Hi Caoer,
In ls-dyna, I found damping settings and I am trying to use global damping. The explanation of global damping is a kind of force applied to each node, F=-f(t)mv, where f(t) is a curve representing damping fator, m and v should be the mass  and velocity of each node, respectively. So what's the difference between the ls-dyna' damping and ABAQUS's viscous pressure?
发表于 2011-10-21 02:13:58 | 显示全部楼层 来自 美国
i think it is similar, difference may lie in the pressure and force.
 楼主| 发表于 2011-10-24 15:03:43 | 显示全部楼层 来自 欧洲
thank you, caoer. I will have some tests and show the results later.
GMT+8, 2024-4-28 07:51 , Processed in 0.034639 second(s), 11 queries , Gzip On, MemCache On.
