- 2009-4-1
12345 (C:/Documents and Settings/Administrator/My Documents/Ansoft/)
Maxwell3DDesign1 (Transient)
[error] Could not map vertices on the moving mesh band. Possible causes are: 1) Motion setup is not correct. 2) The model uses rotational motion, the geometry is less than a full circle, and master-slave boundaries were not defined on the surfaces of the wedge. 3) The model uses translational motion, and true surface curves were used on the band object or on the outermost faces of moving objects. 4) Extremely small gaps or faces exist in the geometry. These may need to be removed or enlarged. (3:31 下午 十一月 16, 2012)
[error] Simulation completed with execution error on server: Local Machine. (3:31 下午 十一月 16, 2012)
