查看: 107|回复: 4
[接触分析] 【求救】为什么我的线接触不收敛?有代码
发表于 2013-9-14 22:33:19 | 显示全部楼层 |阅读模式 来自 美国
一个非常简单的两条并行的梁,中间定义了接触,老是不收敛。怎么回事?
FINISH  ! Make sure we are at BEGIN level
/CLEAR,START  ! Clear model since no SAVE found
/PREP7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,200e9
MPDATA,PRXY,1,,0.3
ET,1,BEAM188
ET,2,BEAM188
ET,3,TARGE170
ET,4,CONTA176
R,4,0.1,0.08,0.001, 0,0,0
SECTYPE,   1, BEAM, RECT, sqare, 0
SECOFFSET, CENT
SECDATA,0.1,0.15,0,0,0,0,0,0,0,0,0,0
SECTYPE,   2, BEAM, CTUBE, circle, 0
SECOFFSET, CENT
SECDATA,.1,.15,0,0,0,0,0,0,0,0,0,0
K,1,0,1,0,
K,2,0,1,1,
K,3,0,1,0,
K,4,0,1,1,
LSTR,       1,       2
LSTR,       3,       4
LSEL,s , , ,       1
LATT,1,1,1, , , ,1
LSEL,s , , ,       2
LATT,1,2,2, , , ,2
alls
LESIZE,all, , ,10, , , , ,1
lmesh,all
eplot
! Generate the target surface
LSEL,S,,,1
TYPE,4
real,4
mat,1
lsel,s,,,1
esll,s
nsle,s
ESURF
TYPE,3
lsel,s,,,2
esll,s
nsle,s
ESURF
EPLOT
finish
/solu
ANTYPE,0
NLGEOM,1
NSUBST,10,1000,5
kbc,0
nsel,s,loc,z,1
d,all,all
esel,s,type,,2
nsle,s
nsel,r,loc,z,0
f,all,fx,-1
TIME,100
alls
solve
finish
/post1
pldisp
发表于 2013-9-15 18:19:59 | 显示全部楼层 来自 上海闵行区
1  求解前缺少一句:  allsel,all, 因此只有单元类型 2,其它单元没有参与求解;
2  接触设置中,需要增加对间隙和穿透的调整;
对你的命令流做了一些修改,见下面。你可以试试:
/filn,contact_line&line
/PREP7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,200e9
MPDATA,PRXY,1,,0.3
ET,1,BEAM188
ET,2,BEAM188
ET,3,TARGE170
ET,4,CONTA176
SECOFFSET, CENT
SECOFFSET, CENT
K,1,0,1,0,
K,2,0,1,1,
K,3,0.0,1,0,
K,4,0.0,1,1,
LSTR,       1,       2
LSTR,       3,       4
LSEL,s , , ,       1
LATT,1,1,1, , , ,1
LSEL,s , , ,       2
LATT,1,2,2, , , ,2
alls
LESIZE,all, , ,50, , , , ,1
lmesh,all
eplot
LSEL,S,,,1
TYPE,4
real,4
mat,1
lsel,s,,,1
esll,s
nsle,s
ESURF
TYPE,3
lsel,s,,,2
esll,s
nsle,s
ESURF
! /COM, CONTACT PAIR PROPERTIES - START   以下修改接触设置
MP,MU,1,0.2
RMODIF,4,7,
RMODIF,4,8,
KEYOPT,4,4,2
KEYOPT,4,5,3
KEYOPT,4,10,2
! /COM, CONTACT PAIR PROPERTIES - END
EPLOT
finish
/solu
ANTYPE,0
NLGEOM,1
kbc,0
nsel,s,loc,z,1
d,all,all
esel,s,type,,2      !  此处选择了单元类型 2,后面需要加一句:  allsel,all
nsle,s
nsel,r,loc,z,0
f,all,fx,-1
allsel,all
CNVTOL,,-1,23
CNVTOL,F, ,0.001,2,-0.1,
OUTRES,ERASE
OUTRES,ALL,ALL
NCNV,2,0,0,0,0
TIME,1
AUTOTS,1
alls
NSUBST,1e4,1e8,5
solve
finish
/post1
pldisp
回复 1 不支持 0
发表于 2013-9-15 09:36:24 | 显示全部楼层 来自 江苏南京
NSUBST,10,1000,5
调调?
 楼主| 发表于 2014-11-25 00:31:16 | 显示全部楼层 来自 美国
谢谢。找出问题了
我应该定义pipe in pipe接触
R,4,-0.1,0.08,0.001, 0,0,0
发表于 2014-12-8 15:37:51 | 显示全部楼层 来自 浙江杭州
2  接触设置中,需要增加 ...
我也犯过这种错误,学习了!
GMT+8, 2024-7-7 20:20 , Processed in 0.030709 second(s), 12 queries , Gzip On, MemCache On.
