查看: 146|回复: 6
[原创] patran help文件安装问题
发表于 2013-12-2 11:03:49 | 显示全部楼层 |阅读模式 来自 安徽合肥
patran的help文件安装完后总是打不开,在开始菜单没有打开选项,在界面上摁F1后,会直接打开%1 C:\Users\ADMINI~1\AppData\Local\Temp\help2222660.tmp.html这个页面,但是是空白的,请问各位如何解决?(我安装的是2011版软件)
发表于 2013-12-2 15:18:58 | 显示全部楼层 来自 北京
Patran documentation exists in $P3_HOME in the helpfiles directory. Both PDF and HTML versions exist. The latest available documentation for MSC Nastran and Marc are also available in PDF format if unloaded from the delivery media. Patran’s context sensitive help system is accessed by pressing the F1 key for the currently active form. The HTML based help system should work automatically (in the patran.pl file in $P3_HOME\bin). Check the following variables if not.
Variable
Description
P3_HELP_MODE        Set this to “2” to indicate the HTML helpfile system is to be used.
P3_BRW_HELP        Set this to the location of the browser you wish to use, e.g., C:\Program Files\Internet Explorer\iexplore.exe
P3_HELP_DIRECTORY        Set this to the location of the HTML helpfile system, e.g., $P3_HOME\helpfiles\html_patran\
由上,找到以下三行(注意是单引号和双反斜杠),修改或补充:
setEnv('P3_HELP_DIRECTORY','E:\\MSC.Software\\Patran\\2008_r1\\helpfiles\\html_patran\\');
setEnv('P3_HELP_MODE','2');
setEnv('P3_BRW_HELP','C:\Program Files\Internet Explorer\iexplore.exe');
 楼主| 发表于 2013-12-3 09:36:13 | 显示全部楼层 来自 安徽合肥
谢谢,请问变量是在系统变量里修改,还是在系统注册表里修改?
发表于 2013-12-3 15:40:16 | 显示全部楼层 来自 北京
In the patran.pl file in $P3_HOME\bin
$P3_HOME:Patran安装目录
发表于 2013-12-4 19:27:27 | 显示全部楼层 来自 中国
请问哪里有help的安装文件啊?
发表于 2013-12-17 20:16:10 | 显示全部楼层 来自 陕西西安
zuoshen 发表于 2013-12-4 19:27
请问哪里有help的安装文件啊?
http://simcompanion.mscsoftware. ... amp;itData.offset=0
就是下载有点慢
发表于 2014-6-21 20:26:01 | 显示全部楼层 来自 浙江舟山
系统变量里修改
GMT+8, 2024-9-30 02:27 , Processed in 0.030695 second(s), 10 queries , Gzip On, MemCache On.
