用ansys计算电极放电,中间需要改变介质的电阻率,就想着用重启动分析解决,但是总是有警告出现。以下是APDL命令,麻烦大家帮忙看一下哪里出现了问题。
rescontrol,all,all
parsav,all,parameters
*do,t,1,75
*SET,v0,10000*(1-cos(0.0148*t))
rescontrol,all,all
antype,,rest,t
/solu
da,a1,volt,v0
da,a3,volt,v0
time,t
outres,all,all
outpr,all
solve
rescontrol,all,all
finish
*get,nnode,node,,num,max
*dim,e0,,nnode
*vget,e0(1),node,1,volt
*do,ie,1,nnode
*if,e0(ie),le,10000,then
/prep7
mp,rsvx,2,10E12
*else
/prep7
mp,rsvx,2,10
*endif
finish
*enddo
*** WARNING *** CP = 123.678 TIME= 15:38:33
The current solution may have been produced using different model or
boundary condition data than is currently stored. POST1 results may
be erroneous unless you perform a new solution using the stored data.
