查看: 85|回复: 1
[ANSYS/LS-DYNA] ansys ls-dyna shell163加转速或转矩后体积膨胀,不旋转只膨胀
发表于 2017-2-14 20:50:42 | 显示全部楼层 |阅读模式 来自 四川
ansys ls-dyna shell加转速(OMGX)或转矩后体积膨胀,不旋转只膨胀,求大神解惑,我的模型是个车轮,原本定义的单元类型是solid164,结果都说其 没有转动自由度,于是换成了shell163,重新划分网格,好几次了,都是上面这种情况,我的体是由一个面绕轴旋转而成,然后按面划分的网格,最后创建了part和component,而component是选的节点,生成的也是节点,最后定义了时间、转速数组,将转速加载到了刚定义的component上,不知那个地方出了问题???
发表于 2017-3-14 09:36:02 | 显示全部楼层 来自 河南洛阳
/PREP7
!定义单元和材料
ET,1,SOLID164
MP,DENS,1,7800
MP,EX,1,2.1e11
MP,NUXY,1,0.3
EDMP,RIGI,2,7,4
MP,DENS,2,7800
MP,EX,2,2.1e11
MP,NUXY,2,0.3
!画刚体和弹性体的实体模型
BLOCK,-0.1,0.1,0.4,0.6,0,0.05,
BLOCK,-0.05,0.05,0.45,0.55,0.05,0.1,
KWPAVE,       9
wpro,,90.000000,
VSBW,       1
KWPAVE,      10
VSBW,       3
VGLUE,all
!确定实体模型上线条的网格密度
LESIZE,all,0.025, , , , , , ,1
lesize,11,,,2
lesize,12,,,2
lesize,31,,,2
lesize,32,,,2
lesize,9,,,2
lesize,10,,,2
lesize,39,,,2
lesize,40,,,2
lesize,21,,,2
lesize,22,,,2
lesize,23,,,2
lesize,24,,,2
numcmp,volu
!划分单元
vsweep,2
vsweep,3
vsweep,4
mat,2
vsweep,1
!建立part
edpart,create
!定义载荷数组
*DIM,time,ARRAY,2,1,1, , ,
*SET,TIME(2,1,1) , 10
*DIM,wz,ARRAY,2,1,1, , ,
*SET,WZ(1,1,1) , 5
*SET,WZ(2,1,1) , 5
!加载
EDLOAD,ADD,RBOZ,0,       2,TIME,WZ, 0, , , , ,
!定义分析选项
FINISH
/SOL
TIME,0.5,
EDRST,30,
EDHTIME,50,
EDDUMP,1,
EDENERGY,1,1,1,1
/STATUS,SOLU
SOLVE
!输出动画
FINISH
/POST1
SET,LAST
/DSCALE,1,1.0
/REPLOT
PLDI, ,
ANTIME,50,0.1, ,1,2,0,0
FINISH
/PREP7
!定义单元和材料
ET,1,SOLID164
MP,DENS,1,7800
MP,EX,1,2.1e11
MP,NUXY,1,0.3
EDMP,RIGI,2,7,4
MP,DENS,2,7800
MP,EX,2,2.1e11
MP,NUXY,2,0.3
!画刚体和弹性体的实体模型
KWPAVE,       9
wpro,,90.000000,
VSBW,       1
KWPAVE,      10
VSBW,       3
VGLUE,all
!确定实体模型上线条的网格密度
lesize,11,,,2
lesize,12,,,2
lesize,31,,,2
lesize,32,,,2
lesize,9,,,2
lesize,10,,,2
lesize,39,,,2
lesize,40,,,2
lesize,21,,,2
lesize,22,,,2
lesize,23,,,2
lesize,24,,,2
numcmp,volu
!划分单元
vsweep,2
vsweep,3
vsweep,4
mat,2
vsweep,1
!建立part
edpart,create
!定义载荷数组
*SET,WZ(1,1,1) , 5
*SET,WZ(2,1,1) , 5
!自定义质心和旋转轴
!质心定义在原点,模型本来的质心不在原点
*DIM,center,ARRAY,3,1,1, , ,
!定义惯性张量,反应了实体的质量相对自定义质心的分布
*DIM,II,ARRAY,6,1,1, , ,
*SET,II(1,1,1) , 1.1
*SET,II(4,1,1) , 0.02475
*SET,II(5,1,1) , 0.165
*SET,II(6,1,1) , 1.1
edipart,2,add,center,4.4,,II
!定义旋转轴
EDLCS,ADD,11,0,0,0,0,0,10,0,0,0,
!加载
EDLOAD,ADD,RBOZ,11,       2,TIME,WZ, 0, , , , ,
!定义分析选项
FINISH
/SOL
TIME,0.5,
EDRST,30,
EDHTIME,50,
EDDUMP,1,
EDENERGY,1,1,1,1
/STATUS,SOLU
SOLVE
这是两个转动的例子,或许对你有帮助
GMT+8, 2024-9-29 16:15 , Processed in 0.035820 second(s), 12 queries , Gzip On, MemCache On.
