- 2015-11-18
楼主 |
发表于 2017-4-7 19:39:55
来自 安徽合肥
;;;;;;;jinglibufen;;;;;;;
;;;;;;;moxingwanggejianli;;;;;;;;
gen zone uwedge p0(-8 20 0) p1(-488 20 0) p2(-8 -20 0) p3(-8 260 240) p4(-488 -20 0)&
p5(-8 -260 240) size 20 20 24 group 1;;1-1
gen zone brick p0(-8 -20 0) p1(-6 -20 0) p2(-8 20 0) p3(-8 -260 240) p4(-6 20 0)&
p5(-8 260 240) p6(-6 -260 240) p7(-6 260 240) size 1 20 24 group 2;;2-1
gen zone brick p0(-6 -20 0) p1(-5 -20 0) p2(-6 20 0) p3(-6 -260 240) p4(-5 20 0) size 1 20 24 group 3;;3-1
;p5(-5 260 240) p6(-5 -260 240) p7(-5 260 240)
gen zone brick p0(-5 -20 0) p1(5 -20 0) p2(-5 20 0) p3(-5 -260 240) p4(5 20 0)&
p5(-5 260 240) p6(5 -260 240) p7(5 260 240) size 5 20 24 group 4;;4
gen zone brick p0(5 -20 0) p1(6 -20 0) p2(5 20 0) p3(5 -260 240) p4(6 20 0)&
p5(5 260 240) p6(6 -260 240) p7(6 260 240) size 1 20 24 group 3;;3-2
gen zone brick p0(6 -20 0) p1(8 -20 0) p2(6 20 0) p3(6 -260 240) p4(8 20 0)&
p5(6 260 240) p6(8 -260 240) p7(8 260 240) size 1 20 24 group 2;;2-2
gen zone uwedge p0(8 -20 0) p1(488 -20 0) p2(8 20 0) p3(8 -260 240) p4(488 20 0)&
p5(8 260 240) size 20 20 24 group 1;;1-2
range name 1 group 1
range name 2 group 2
range name 3 group 3
range name 4 group 4
model mohr
prop cohesion = 10000.0 friction = 42.3 dilation = 12.0 tension = 0.0 range 1
prop cohesion = 30000.0 friction = 40.4 dilation = 12.0 tension = 0.0 range 2
prop cohesion = 37000.0 friction = 36.3 dilation = 10.0 tension = 0.0 range 3
prop cohesion = 30000.0 friction = 25 dilation = 14.0 tension = 0.0 range 4
ini den 2260 range 1
ini den 2210 range 2
ini den 2320 range 3
ini den 2350 range 4
;model fl_iso ran gro 1 gro 2 gro 3 gro 4 gro 6 a gro 7 a
plot zone
;plot block group
;pause
;;;;;;;????????????????????boundary conditions;;;;;;;;
fix x y z range plane norm 0,1,-1.0 origin -8 260 240 dist 0.1
fix x y z range z -0.01 0.01
fix x y z range plane norm 0,-1,-1.0 origin -8 -260 240 dist 0.1
his id 1 unbal
set grav=9.81 ;large
;set large
set dyn=off
;pause
;solve
set dynamic on
ini xdis=0 ydis=0 zdis=0
table 100 read shuiping.acc ;;;;;;;;;;;read acc history from located directory .acc file
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;apply xacc history on bottom of model
free x
apply xacc 0.1 his table 100 dynamic range z -0.01 0.01
apply xacc 0.1 his table 100 dynamic range plane norm 0,1,-1.2 origin -8 394 295 dist 0.1 z=0,295
apply xacc 0.1 his table 100 dynamic range plane norm 0,-1,-2 origin -8 -335 295 dist 0.1 z=0,295
ini damp hyst default -3.156 1.904
set dyn damp rayleigh=0.005 1.5 stiffness
set large
set dynamic time=0.0
hist nstep 100
set dynamic dt 0.0005
def solve_ages
loop n(1,15)
sol_n = n * 2.0 ;分15步保存,每2秒保存一个结果
sol_file = 'Dyn-x' + string(n) + 'x2s.sav'
command
sol age sol_n
save sol_file
endcommand
endloop
end
solve_ages
