- 2012-9-13
*MAT_NULL
ID
RO:材料密度
PC:压力截断值,总是小于零。
The cut-off pressure, PC, must be defined to allow for a material to “numerically” cavitate. In other words, when a material undergoes dilatation above certain magnitude, it should no longer be able to resist this dilatation. Since dilatation stress or pressure is negative, setting PC limit to a very small negative number would allow for the material to cavitate once the pressure in the material goes below this negative value.
MU:动力粘度系数
请问这个PC大家是怎么理解,如何设置呢?
