在做workbench的瞬态力学设置中出现了如下的错误:An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.(超过了内部解决方案的大小限制。请检查您的环境是否有不适当的负载值或支持不足。还要检查你的网格是否有超过1个元素,如果有实心的砖元素存在的话。请参阅帮助系统的故障排除部分以获得更多信息。)
之后我将载荷部分的转速跟集中力取消后就可以正常运行,但不知道该怎么改!
