- 5
- 2003-3-5
这是一个流固耦合问题的命令流文件(附件)。用/input,fsi,txt命令即可运行。但中途报错:“Old FLOTRAN results file exists, but contains different number of ndes. File will be renamed <jobname>.rfo. The analysis will be run
as a new case. To interpolate results from a previous file use a
FLDA,REST command."确定后又提示:“ Error attempting to back up unuseable results file. Check READ/WRITE permission. Fsi.rfo. ”;直到最后提示:“ No segments are defined. Use /SEG,MULT to create multiple segments. “。查看结果图象文件*.graph发现结果似乎基本正确。请大侠指点! |
