Simdroid
查看: 519|回复: 13
[子程序] 有关复合材料vumat的渐进损伤模型的请教
发表于 2020-9-30 21:49:45 | 显示全部楼层 |阅读模式 来自 天津
本人根据ABAQUS自带的hashin三维准则的代码,更改为刚度线性退化的方式,但是一直没有成功,在损伤的初始,刚度下降的还算正常,但是到了某一时刻,不知道为什么,整个层合板出现了大面积的单元删除,很明显是不正确的,我做的是低速冲击的模拟,采用的应变定义的损伤准则。想请教各位大神有没有办法解决。
 楼主| 发表于 2020-9-30 21:59:57 | 显示全部楼层 来自 天津
vumat的程序奉上
       subroutine vumat(
c Read only -
     1  nblock, ndir, nshr, nstatev, nfieldv, nprops, lanneal,
     2  stepTime, totalTime, dt, cmname, coordMp, charLength,
     3  props, density, strainInc, relSpinInc,
     4  tempOld, stretchOld, defgradOld, fieldOld,
     5  stressOld, stateOld, enerInternOld, enerInelasOld,
     6  tempNew, stretchNew, defgradNew, fieldNew,
c Write only -
     7  stressNew, stateNew, enerInternNew, enerInelasNew )
c
      include 'vaba_param.inc'
c
c 3D Orthotropic Elasticity with Hashin 3d Failure criterion
c
c The state variables are stored as:
c    state(*,1)   = material point status
c    state(*,2:7) = damping stresses
c
c User defined material properties are stored as
c  * First line:
c     props(1) --> Young's modulus in 1-direction, E1
c     props(2) --> Young's modulus in 2-direction, E2
c     props(3) --> Young's modulus in 3-direction, E3
c     props(4) --> Poisson's ratio, nu12
c     props(5) --> Poisson's ratio, nu13
c     props(6) --> Poisson's ratio, nu23
c     props(7) --> Shear modulus, G12
c     props(8) --> Shear modulus, G13
c
c  * Second line:
c     props(9)  --> Shear modulus, G23
c     props(10) --> beta damping parameter
c     props(11) --> "not used"
c     props(12) --> "not used"
c     props(13) --> "not used"
c     props(14) --> "not used"
c     props(15) --> "not used"
c     props(16) --> "not used"
c
c  * Third line:
c     props(17) --> Ultimate tens stress in 1-direction, sigu1t
c     props(18) --> Ultimate comp stress in 1-direction, sigu1c
c     props(19) --> Ultimate tens stress in 2-direction, sigu2t
c     props(20) --> Ultimate comp stress in 2-direction, sigu2c
c     props(21) --> Ultimate tens stress in 2-direction, sigu3t
c     props(22) --> Ultimate comp stress in 2-direction, sigu3c
c     props(23) --> "not used"
c     props(24) --> "not used"
c
c  * Fourth line:
c     props(25) --> Ultimate shear stress, sigu12
c     props(26) --> Ultimate shear stress, sigu13
c     props(27) --> Ultimate shear stress, sigu23
c     props(28) --> "not used"
c     props(29) --> "not used"
c     props(30) --> "not used"
c     props(31) --> "not used"
c     props(32) --> "not used"
c
      dimension props(nprops), density(nblock), charLength(nblock),
     1  coordMp(nblock,*),
     2  strainInc(nblock,ndir+nshr),
     3  relSpinInc(nblock,nshr), tempOld(nblock),
     4  stretchOld(nblock,ndir+nshr), defgradOld(nblock,ndir+nshr+nshr),
     5  fieldOld(nblock,nfieldv), stressOld(nblock,ndir+nshr),
     6  stateOld(nblock,nstatev), enerInternOld(nblock),
     7  enerInelasOld(nblock), tempNew(*),
     8  stretchNew(nblock,ndir+nshr), defgradNew(nblock,ndir+nshr+nshr),
     9  fieldNew(nblock,nfieldv), stressNew(nblock,ndir+nshr),
     1  stateNew(nblock,nstatev),
     2  enerInternNew(nblock), enerInelasNew(nblock)
      character*80 cmname
      parameter( zero = 0.d0, one = 1.d0, two = 2.d0, half = .5d0 )
      parameter(
     *     i_svd_DmgFiberT   = 1,
     *     i_svd_DmgFiberC   = 2,
     *     i_svd_DmgMatrixT  = 3,
     *     i_svd_DmgMatrixC  = 4,
     *     i_svd_statusMp   = 5,
     *     i_svd_dampStress = 6,
c     *    i_svd_dampStressXx = 6,
c     *    i_svd_dampStressYy = 7,
c     *    i_svd_dampStressZz = 8,
c     *    i_svd_dampStressXy = 9,
c     *    i_svd_dampStressYz = 10,
c     *    i_svd_dampStressZx = 11,
     *     i_svd_Strain   = 12,
c     *    i_svd_StrainXx = 12,
c     *    i_svd_StrainYy = 13,
c     *    i_svd_StrainZz = 14,
c     *    i_svd_StrainXy = 15,
c     *    i_svd_StrainYz = 16,
c     *    i_svd_StrainZx = 17,
     *     i_svd_dft = 18,
     *     i_svd_dfc = 19,
     *     i_svd_dmt = 20,
     *     i_svd_dmc = 21,
     *     n_svd_required = 21 )
      parameter(
     *     i_s33_Xx = 1,
     *     i_s33_Yy = 2,
     *     i_s33_Zz = 3,
     *     i_s33_Xy = 4,
     *     i_s33_Yz = 5,
     *     i_s33_Zx = 6 )
* Structure of property array
      parameter (
     *     i_pro_E1    = 1,
     *     i_pro_E2    = 2,
     *     i_pro_E3    = 3,
     *     i_pro_nu12  = 4,
     *     i_pro_nu13  = 5,
     *     i_pro_nu23  = 6,
     *     i_pro_G12   = 7,
     *     i_pro_G13   = 8,
     *     i_pro_G23   = 9,
     *     i_pro_beta  = 10,
     *     i_pro_sigu1t = 17,
     *     i_pro_sigu1c = 18,
     *     i_pro_sigu2t = 19,
     *     i_pro_sigu2c = 20,
     *     i_pro_sigu3t = 21,
     *     i_pro_sigu3c = 22,
     *     i_pro_sigu12 = 25,
     *     i_pro_sigu13 = 26,
     *     i_pro_sigu23 = 27,
     *     i_pro_Gft = 28,
     *     i_pro_Gfc = 29,
     *     i_pro_Gmt = 30,
     *     i_pro_Gmc = 31 )
* Temporary arrays
      dimension eigen(maxblk*3)
* Read material properties
      E1 = props(i_pro_E1)
      E2 = props(i_pro_E2)
      E3 = props(i_pro_E3)
      xnu12 = props(i_pro_nu12)
      xnu13 = props(i_pro_nu13)
      xnu23 = props(i_pro_nu23)
      G12 = props(i_pro_G12)
      G13 = props(i_pro_G13)
      G23 = props(i_pro_G23)
      xnu21 = xnu12 * E2 / E1
      xnu31 = xnu13 * E3 / E1
      xnu32 = xnu23 * E3 / E2
* Compute terms of stiffness matrix
      gg = one / ( one - xnu12*xnu21 - xnu23*xnu32 - xnu31*xnu13
     *     - two*xnu21*xnu32*xnu13 )
      C11  = E1 * ( one - xnu23*xnu32 ) * gg
      C22  = E2 * ( one - xnu13*xnu31 ) * gg
      C33  = E3 * ( one - xnu12*xnu21 ) * gg
      C12  = E1 * ( xnu21 + xnu31*xnu23 ) * gg
      C13  = E1 * ( xnu31 + xnu21*xnu32 ) * gg
      C23  = E2 * ( xnu32 + xnu12*xnu31 ) * gg
      f1t = props(i_pro_sigu1t)
      f1c = props(i_pro_sigu1c)
      f2t = props(i_pro_sigu2t)
      f2c = props(i_pro_sigu2c)
      f3t = props(i_pro_sigu3t)
      f3c = props(i_pro_sigu3c)
      f12 = props(i_pro_sigu12)
      f13 = props(i_pro_sigu13)
      f23 = props(i_pro_sigu23)
      beta = props(i_pro_beta)
      Gft = props(i_pro_Gft)
      Gfc = props(i_pro_Gfc)
      Gmt = props(i_pro_Gmt)
      Gmc = props(i_pro_Gmc)
* Assume purely elastic material at the beginning of the analysis
      if ( totalTime .eq. zero ) then
         if (nstatev .lt. n_svd_Required) then
            call xplb_abqerr(-2,'Subroutine VUMAT requires the '//
     *           'specification of %I state variables. Check the '//
     *           'definition of *DEPVAR in the input file.',
     *           n_svd_Required,zero,' ')
            call xplb_exit
         end if
         call OrthoEla3dExp ( nblock,
     *        stateOld(1,i_svd_DmgFiberT),
     *        stateOld(1,i_svd_DmgFiberC),
     *        stateOld(1,i_svd_DmgMatrixT),
     *        stateOld(1,i_svd_DmgMatrixC),
     *        stateOld(1,i_svd_statusMp),
     *        stateOld(1,i_svd_dft),
     *        stateOld(1,i_svd_dfc),
     *        stateOld(1,i_svd_dmt),
     *        stateOld(1,i_svd_dmc),
     *        C11, C22, C33, C12, C23, C13, G12, G23, G13,
     *        E1, E2, Gft, Gfc, Gmt, Gmc, f1t, f2t, f1c, f2c,
     *        charLength,
     *        strainInc,
     *        stressNew )
         return
      end if
*  Update total elastic strain
      call strainUpdate ( nblock, strainInc,
     *     stateOld(1,i_svd_strain), stateNew(1,i_svd_strain) )
* Stress update
     *     charLength,
     *     stateNew(1,i_svd_strain),
     *     stressNew )
* Failure evaluation
      call copyr ( nblock,
     *     stateOld(1,i_svd_DmgFiberT), stateNew(1,i_svd_DmgFiberT) )
     *     stateOld(1,i_svd_DmgFiberC), stateNew(1,i_svd_DmgFiberC) )
     *     stateOld(1,i_svd_DmgMatrixT), stateNew(1,i_svd_DmgMatrixT) )
     *     stateOld(1,i_svd_DmgMatrixC), stateNew(1,i_svd_DmgMatrixC) )
      nDmg = 0
      call eig33Anal ( nblock, stretchNew, eigen )
      call Hashin3d  ( nblock, nDmg,
     *     f1t, f2t, f3t, f1c, f2c, f3c, f12, f23, f13,
     *     E1, E2, G12, G13, G23,
     *     stateNew(1,i_svd_DmgFiberT),
     *     stateNew(1,i_svd_DmgFiberC),
     *     stateNew(1,i_svd_DmgMatrixT),
     *     stateNew(1,i_svd_DmgMatrixC),
     *     stateNew(1,i_svd_statusMp),
     *     stateNew(1,i_svd_strain),stressNew,eigen )
*     -- Recompute stresses if new Damage is occurring
      if ( nDmg .gt. 0 ) then ! >
     *        stateNew(1,i_svd_dft),
     *        stateNew(1,i_svd_dfc),
     *        stateNew(1,i_svd_dmt),
     *        stateNew(1,i_svd_dmc),
     *        charLength,
     *        stressNew )
      end if
* Beta damping
      if ( beta .gt. zero ) then
         call betaDamping3d ( nblock,
     *        beta, dt, strainInc,
     *        stressOld, stressNew,
     *        stateOld(1,i_svd_dampStress),
     *        stateNew(1,i_svd_dampStress) )
      end if
* Integrate the internal specific energy (per unit mass)
      call EnergyInternal3d ( nblock, stressOld, stressNew,
     *   strainInc, density, enerInternOld, enerInternNew )
      return
      end
*   OrthoEla3dExp: Orthotropic elasticity - 3d
* call OrthoEla3dExp ( nblock,
*     *        stateOld(1,i_svd_DmgFiberT),
*     *        stateOld(1,i_svd_DmgFiberC),
*     *        stateOld(1,i_svd_DmgMatrixT),
*     *        stateOld(1,i_svd_DmgMatrixC),
*     *        C11, C22, C33, C12, C23, C13, G12, G23, G13,
*     *        strainInc,
*     *        stressNew )
*用于更新材料的刚度矩阵
      subroutine OrthoEla3dExp ( nblock,
     *     dmgFiberT, dmgFiberC, dmgMatrixT, dmgMatrixC, statusMp,
     *     outdft,outdfc,outdmt,outdmc,
     *     charLength,
     *     strain, stress )
*  Orthotropic elasticity, 3D case -
      parameter( zero = 0.d0, one = 1.d0, two = 2.d0, half = 0.5d0)
      parameter( cri = .99d0, thickness = 0.1875d-3, three = 3.d0)
      parameter( smt = 0.9d0, smc = 0.5d0, sft = 0.5d0, sfc = 0.5d0)
      parameter(
     *     i_s33_Xx = 1,
     *     i_s33_Yy = 2,
     *     i_s33_Zz = 3,
     *     i_s33_Xy = 4,
     *     i_s33_Yz = 5,
     *     i_s33_Zx = 6,
     *     n_s33_Car = 6 )
      dimension  strain(nblock,n_s33_Car),
     *     dmgFiberT(nblock), dmgFiberC(nblock),
     *     dmgMatrixT(nblock), dmgMatrixC(nblock),
     *     outdft(nblock), outdfc(nblock),
     *     outdmt(nblock), outdmc(nblock),
     *     charLength(nblock), statusMp(nblock),
     *     stress(nblock,n_s33_Car)
*     -- shear fraction in matrix tension and compression mode
      do k = 1, nblock
*     -- Compute damaged stiffness
         dft = zero
         dfc = zero
         dmt = zero
         dmc = zero
         e11 = strain(k,i_s33_Xx)
         e22 = strain(k,i_s33_Yy)
         e33 = strain(k,i_s33_Zz)
         e12 = strain(k,i_s33_Xy)
         e23 = strain(k,i_s33_Yz)
         e13 = strain(k,i_s33_Zx)
         e_11P = (abs(strain(k,i_s33_Xx)) + strain(k,i_s33_Xx))/two
         e_11N = (abs(strain(k,i_s33_Xx)) - strain(k,i_s33_Xx))/two
         e_22P = (abs(strain(k,i_s33_Yy)) + strain(k,i_s33_Yy))/two
         e_22N = (abs(strain(k,i_s33_Yy)) - strain(k,i_s33_Yy))/two
         e_eq1t = ((e_11P)**two + (e12)**two + (e13)**two)**half
         e_eq1c = e_11N
         e_eq2t = ((e_22P)**two + (e12)**two)**half
         e_eq2c = ((e_22N)**two + (e12)**two)**half
         charLength(k) = (charLength(k)**three / thickness)**half
         e_ft0 = f1t / C11
         e_fft = two*Gft/charLength(k)/f1t
         e_fc0 = f1c / C11
         e_ffc = two*Gfc/charLength(k)/f1c
         e_mt0 = f2t / C22
         e_fmt = two*Gmt/charLength(k)/f2t
         e_mc0 = f2c / C22
         e_fmc = two*Gmc/charLength(k)/f2c
         if (dmgFiberT(k) .eq. one) then
             dft = e_fft * (e_eq1t-e_ft0) / e_eq1t / (e_fft - e_ft0)
             if (dft.lt.zero) then
                 dft = sft
             end if
             if( dft.gt.cri )then
                 dft = cri
             end if
         end if
         if (dmgFiberC(k) .eq. one) then
             dfc = e_ffc * (e_eq1c - e_fc0)/ e_eq1c / (e_ffc - e_fc0)
             if (dfc.lt.zero) then
                 dfc = sfc
             end if
             if( dfc.gt.cri )then
                 dfc = cri
             end if
         end if
         if (dmgMatrixT(k) .eq. one) then
             dmt = e_fmt * (e_eq2t - e_mt0)/ e_eq2t/ (e_fmt - e_mt0)
             if (dmt.lt.zero) then
                 dmt = smt
             end if
             if(dmt.gt.cri)then
                 dmt = cri
             end if
         end if
         if (dmgMatrixC(k) .eq. one) then
             dmc = e_fmc * (e_eq2c - e_mc0)/ e_eq2c / (e_fmc - e_mc0)
             if (dmc.lt.zero) then
                 dmc = smc
             end if
             if( dmc.gt.cri )then
                 dmc = cri
             end if
         end if
         if (dft .eq. cri) then
             statusMp(k) = zero
         end if
         df = one - ( one - dft ) * ( one - dfc )
*         print * ,'efft = ',e_fft
*         print *, 'eft0 = ',e_ft0
*         if (dmgMatrixT(k) .eq. one) then
*             print *, 'eft = ',e_eq2t
*      endif
         outdft(k) = dft
         outdfc(k) = dfc
         outdmt(k) = dmt
         outdmc(k) = dmc
* 新的刚度矩阵,一旦纤维拉伸或压缩的的系数为1就会出现dC11=0,新的应力就会不同
* 已经改成连续性退化
         dC11 = ( one - df ) * C11
         dC22 = ( one - df ) * ( one - dmt ) * ( one - dmc ) * C22
         dC33 = ( one - df ) * ( one - dmt ) * ( one - dmc ) * C33
         dC12 = ( one - df ) * ( one - dmt ) * ( one - dmc ) * C12
         dC23 = ( one - df ) * ( one - dmt ) * ( one - dmc ) * C23
         dC13 = ( one - df ) * ( one - dmt ) * ( one - dmc ) * C13
         dG12 = ( one - df )
     *        * ( one - dmt ) * ( one - dmc ) * G12
         dG23 = ( one - df )
     *        * ( one - dmt ) * ( one - dmc ) * G23
         dG13 = ( one - df )
     *        * ( one - dmt ) * ( one - dmc ) * G13
*     -- Stress update
         stress(k,i_s33_Xx) = dC11 * strain(k,i_s33_Xx)
     *        + dC12 * strain(k,i_s33_Yy)
     *        + dC13 * strain(k,i_s33_Zz)
         stress(k,i_s33_Yy) = dC12 * strain(k,i_s33_Xx)
     *        + dC22 * strain(k,i_s33_Yy)
     *        + dC23 * strain(k,i_s33_Zz)
         stress(k,i_s33_Zz) = dC13 * strain(k,i_s33_Xx)
     *        + dC23 * strain(k,i_s33_Yy)
     *        + dC33 * strain(k,i_s33_Zz)
         stress(k,i_s33_Xy) = two * dG12 * strain(k,i_s33_Xy)
         stress(k,i_s33_Yz) = two * dG23 * strain(k,i_s33_Yz)
         stress(k,i_s33_Zx) = two * dG13 * strain(k,i_s33_Zx)
      end do
      return
      end
*   strainUpdate: Update total strain                      *
      subroutine strainUpdate ( nblock,
     *     strainInc, strainOld, strainNew )
      parameter(
     *     i_s33_Xx = 1,
     *     i_s33_Yy = 2,
     *     i_s33_Zz = 3,
     *     i_s33_Xy = 4,
     *     i_s33_Yz = 5,
     *     i_s33_Zx = 6,
     *     n_s33_Car = 6 )
      dimension strainInc(nblock,n_s33_Car),
     *     strainOld(nblock,n_s33_Car),
     *     strainNew(nblock,n_s33_Car)
      do k = 1, nblock
         strainNew(k,i_s33_Xx)= strainOld(k,i_s33_Xx)
     *                        + strainInc(k,i_s33_Xx)
         strainNew(k,i_s33_Yy)= strainOld(k,i_s33_Yy)
     *                        + strainInc(k,i_s33_Yy)
         strainNew(k,i_s33_Zz)= strainOld(k,i_s33_Zz)
     *                        + strainInc(k,i_s33_Zz)
         strainNew(k,i_s33_Xy)= strainOld(k,i_s33_Xy)
     *                        + strainInc(k,i_s33_Xy)
         strainNew(k,i_s33_Yz)= strainOld(k,i_s33_Yz)
     *                        + strainInc(k,i_s33_Yz)
         strainNew(k,i_s33_Zx)= strainOld(k,i_s33_Zx)
     *                        + strainInc(k,i_s33_Zx)
      end do
      return
      end
*   Hashin3d w/ Modified Puck: Evaluate Hashin 3d failure  *
*   criterion for fiber, Puck for matrix                   *
*   缺少除了失效区域的hashin系数
      subroutine Hashin3d ( nblock, nDmg,
     *     statusMp, strain, stress, eigen )
      parameter(
     *     zero = 0.d0, one = 1.d0,
     *     half = 0.5d0, two= 2.d0, three =3.d0, alpha = 0.9d0)
      parameter(
     *     i_s33_Xx = 1,
     *     i_s33_Yy = 2,
     *     i_s33_Zz = 3,
     *     i_s33_Xy = 4,
     *     i_s33_Yz = 5,
     *     i_s33_Zx = 6,
     *     n_s33_Car = 6 )
      parameter(i_v3d_X=1,i_v3d_Y=2,i_v3d_Z=3 )
      parameter(n_v3d_Car=3 )
      parameter ( eMax = 1.00d0, eMin = -0.8d0 )
      dimension  dmgFiberT(nblock), dmgFiberC(nblock),
     *     strain(nblock,n_s33_Car),
     *     stress(nblock,n_s33_Car),
     *     eigen(nblock,n_v3d_Car),
     *     statusMp(nblock)
      f1tInv = zero
      f2tInv = zero
      f3tInv = zero
      f1cInv = zero
      f2cInv = zero
      f3cInv = zero
      f12Inv = zero
      f23Inv = zero
      f13Inv = zero
      if ( f1t .gt. zero ) f1tInv = one / f1t
      if ( f2t .gt. zero ) f2tInv = one / f2t
      if ( f3t .gt. zero ) f3tInv = one / f3t
      if ( f1c .gt. zero ) f1cInv = one / f1c
      if ( f2c .gt. zero ) f2cInv = one / f2c
      if ( f3c .gt. zero ) f3cInv = one / f3c
      if ( f12 .gt. zero ) f12Inv = one / f12
      if ( f23 .gt. zero ) f23Inv = one / f23
      if ( f13 .gt. zero ) f13Inv = one / f13
      e1t0 = f1t / E1
      e1c0 = f1c / E1
      e2t0 = f2t / E2
      e2c0 = f2c / E2
      do k = 1, nblock
         if ( statusMp(k) .eq. one ) then
         lFail = 0
         s11 = stress(k,i_s33_Xx)
         s22 = stress(k,i_s33_Yy)
         s33 = stress(k,i_s33_Zz)
         s12 = stress(k,i_s33_Xy)
         s23 = stress(k,i_s33_Yz)
         s13 = stress(k,i_s33_Zx)
*     Evaluate Fiber modes
         if ( s11 .gt. zero ) then
*     -- Tensile Fiber Mode
            rft = (e11/e1t0)**two
     *          + alpha * (e12 * f12Inv * G12)**two
     *          + alpha * (e13 * f12Inv * G12)**two
            dmgFiberT(k) = rft
            if ( rft .ge. one ) then
               lDmg = 1
               dmgFiberT(k) = one
            end if
         else if ( s11 .lt. zero ) then
*     -- Compressive Fiber Mode
            rfc = (e11 /e1c0)**two
            dmgFiberC(k) = rfc
            if ( rfc .ge. one ) then
               lDmg = 1
               dmgFiberC(k) = one
            end if
         end if
*     Evaluate Matrix Modes
         if ( ( s22 + s33 ) .gt. zero ) then
*     -- Tensile Matrix mode
            rmt = (e22/e2t0)**two
     *          + (e12 * G12 * f12Inv)**two
     *          + (e13 * G12 * f12Inv)**two
     *          - (e22 * e33)*(G23 * f23Inv)**two
     *          + (e23 * G23 * f23Inv)**two
            dmgMatrixT(k) = rmt
            if ( rmt .ge. one ) then
               lDmg = 1
               dmgMatrixT(k) = one
            end if
         else if ( ( s22 + s33 ) .lt. zero ) then
*     -- Compressive Matrix Mode
            rmc = (E2 * e22 * half * f12Inv)**two
     *          + (e22 / e2c0)*((E2 * e2c0 * half * f12Inv)**two - one)
           dmgMatrixC(k) = rmc
            if ( rmc .ge. one ) then
               lDmg = 1
               dmgMatrixC(k) = one
            end if
         end if
         eigMax=max(eigen(k,i_v3d_X),eigen(k,i_v3d_Y),eigen(k,i_v3d_Z))
         eigMin=min(eigen(k,i_v3d_X),eigen(k,i_v3d_Y),eigen(k,i_v3d_Z))
         enomMax = eigMax - one
         enomMin = eigMin - one
         if ( enomMax .gt. eMax .or.
     *        enomMin .lt. eMin ) then
            statusMp(k) = zero
         end if
         nDmg = nDmg + lDmg
         end if
      end do
      return
      end
*   betaDamping: Add beta damping                          *
      subroutine betaDamping3d ( nblock,
     *     beta, dt, strainInc, sigOld, sigNew,
     *     statusMp, sigDampOld, sigDampNew )
      parameter(
     *     i_s33_Xx = 1,
     *     i_s33_Yy = 2,
     *     i_s33_Zz = 3,
     *     i_s33_Xy = 4,
     *     i_s33_Yz = 5,
     *     i_s33_Zx = 6,
     *     n_s33_Car = 6 )
      dimension  sigOld(nblock,n_s33_Car),
     *     sigNew(nblock,n_s33_Car),
     *     strainInc(nblock,n_s33_Car),
     *     statusMp(nblock),
     *     sigDampOld(nblock,n_s33_Car),
     *     sigDampNew(nblock,n_s33_Car)
      parameter ( zero = 0.d0, one = 1.d0, two=2.0d0,
     *     half = 0.5d0, third = 1.d0/3.d0 )
      parameter ( asmall = 1.d-16 )
      betaddt =  beta / dt
      do k =1 , nblock
         sigDampNew(k,i_s33_Xx) = betaddt * statusMp(k) *
     *        ( sigNew(k,i_s33_Xx)
     *        - ( sigOld(k,i_s33_Xx) - sigDampOld(k,i_s33_Xx) ) )
         sigDampNew(k,i_s33_Yy) = betaddt * statusMp(k) *
     *        ( sigNew(k,i_s33_Yy)
     *        - ( sigOld(k,i_s33_Yy) - sigDampOld(k,i_s33_Yy) ) )
         sigDampNew(k,i_s33_Zz) = betaddt * statusMp(k) *
     *        ( sigNew(k,i_s33_Zz)
     *        - ( sigOld(k,i_s33_Zz) - sigDampOld(k,i_s33_Zz) ) )
         sigDampNew(k,i_s33_Xy) = betaddt * statusMp(k) *
     *        ( sigNew(k,i_s33_Xy)
     *        - ( sigOld(k,i_s33_Xy) - sigDampOld(k,i_s33_Xy) ) )
         sigDampNew(k,i_s33_Yz) = betaddt * statusMp(k) *
     *        ( sigNew(k,i_s33_Yz)
     *        - ( sigOld(k,i_s33_Yz) - sigDampOld(k,i_s33_Yz) ) )
         sigDampNew(k,i_s33_Zx) = betaddt * statusMp(k) *
     *        ( sigNew(k,i_s33_Zx)
     *        - ( sigOld(k,i_s33_Zx) - sigDampOld(k,i_s33_Zx) ) )
         sigNew(k,i_s33_Xx) = sigNew(k,i_s33_Xx)+sigDampNew(k,i_s33_Xx)
         sigNew(k,i_s33_Yy) = sigNew(k,i_s33_Yy)+sigDampNew(k,i_s33_Yy)
         sigNew(k,i_s33_Zz) = sigNew(k,i_s33_Zz)+sigDampNew(k,i_s33_Zz)
         sigNew(k,i_s33_Xy) = sigNew(k,i_s33_Xy)+sigDampNew(k,i_s33_Xy)
         sigNew(k,i_s33_Yz) = sigNew(k,i_s33_Yz)+sigDampNew(k,i_s33_Yz)
         sigNew(k,i_s33_Zx) = sigNew(k,i_s33_Zx)+sigDampNew(k,i_s33_Zx)
      end do
      return
      end
*   EnergyInternal3d: Compute internal energy for 3d case  *
      subroutine EnergyInternal3d(nblock, sigOld, sigNew ,
     *   strainInc, curDensity, enerInternOld, enerInternNew)
      parameter(
     *     i_s33_Xx = 1,
     *     i_s33_Yy = 2,
     *     i_s33_Zz = 3,
     *     i_s33_Xy = 4,
     *     i_s33_Yz = 5,
     *     i_s33_Zx = 6,
     *     n_s33_Car = 6 )
      parameter( two = 2.d0, half = .5d0 )
      dimension sigOld (nblock,n_s33_Car), sigNew (nblock,n_s33_Car),
     *     strainInc (nblock,n_s33_Car), curDensity (nblock),
     *     enerInternOld(nblock), enerInternNew(nblock)
      do k = 1, nblock
         stressPower  = half * (
     *        ( sigOld(k,i_s33_Xx) + sigNew(k,i_s33_Xx) )
     *        * ( strainInc(k,i_s33_Xx) )
     *        +       ( sigOld(k,i_s33_Yy) + sigNew(k,i_s33_Yy) )
     *        * ( strainInc(k,i_s33_Yy))
     *        +       ( sigOld(k,i_s33_Zz) + sigNew(k,i_s33_Zz) )
     *        * ( strainInc(k,i_s33_Zz))
     *        + two * ( sigOld(k,i_s33_Xy) + sigNew(k,i_s33_Xy) )
     *        * strainInc(k,i_s33_Xy)
     *        + two * ( sigOld(k,i_s33_Yz) + sigNew(k,i_s33_Yz) )
     *        * strainInc(k,i_s33_Yz)
     *        + two * ( sigOld(k,i_s33_Zx) + sigNew(k,i_s33_Zx) )
     *        * strainInc(k,i_s33_Zx) )
         enerInternNew(k) = enerInternOld(k) + stressPower/curDensity(k)
      end do
      return
      end
*   CopyR: Copy from one array to another                  *
      subroutine CopyR(nCopy, from, to )
      parameter(one = 1.d0)
      dimension from(nCopy), to(nCopy)
      do k = 1, nCopy
              to(k) = from(k)
      end do
      return
      end
* eig33Anal: Compute eigen values of a 3x3 symmetric matrix analytically *
      subroutine eig33Anal( nblock, sMat, eigVal )
      parameter(i_s33_Xx=1,i_s33_Yy=2,i_s33_Zz=3 )
      parameter(i_s33_Xy=4,i_s33_Yz=5,i_s33_Zx=6 )
      parameter(i_s33_Yx=i_s33_Xy )
      parameter(i_s33_Zy=i_s33_Yz )
      parameter(i_s33_Xz=i_s33_Zx,n_s33_Car=6 )
      parameter ( zero = 0.d0, one = 1.d0, two = 2.d0,
     *     three = 3.d0, half = 0.5d0, third = one / three,
     *     pi23 = 2.094395102393195d0,
     *     fuzz = 1.d-8,
     *     preciz = fuzz * 1.d4 )
      dimension eigVal(nblock,n_v3d_Car), sMat(nblock,n_s33_Car)
      do k = 1, nblock
        sh  = third*(sMat(k,i_s33_Xx)+sMat(k,i_s33_Yy)+sMat(k,i_s33_Zz))
        s11 = sMat(k,i_s33_Xx) - sh
        s22 = sMat(k,i_s33_Yy) - sh
        s33 = sMat(k,i_s33_Zz) - sh
        s12 = sMat(k,i_s33_Xy)
        s13 = sMat(k,i_s33_Xz)
        s23 = sMat(k,i_s33_Yz)
        fac  = max(abs(s11), abs(s22), abs(s33))
        facs = max(abs(s12), abs(s13), abs(s23))
        if( facs .lt. (preciz*fac) ) then
          eigVal(k,i_v3d_X) = sMat(k,i_s33_Xx)
          eigVal(k,i_v3d_Y) = sMat(k,i_s33_Yy)
          eigVal(k,i_v3d_Z) = sMat(k,i_s33_Zz)
        else
          q = third*((s12**2+s13**2+s23**2)+half*(s11**2+s22**2+s33**2))
          fac = two * sqrt(q)
          if( fac .gt. fuzz ) then
            ofac = two/fac
          else
            ofac = zero
          end if
          s11 = ofac*s11
          s22 = ofac*s22
          s33 = ofac*s33
          s12 = ofac*s12
          s13 = ofac*s13
          s23 = ofac*s23
          r = s12*s13*s23
     *         + half*(s11*s22*s33-s11*s23**2-s22*s13**2-s33*s12**2)
          if( r .ge. one-fuzz ) then
            cos1 = -half
            cos2 = -half
            cos3 = one
          else if( r .le. fuzz-one ) then
            cos1 = -one
            cos2 = half
            cos3 = half
          else
            ang = third * acos(r)
            cos1 = cos(ang)
            cos2 = cos(ang+pi23)
            cos3 =-cos1-cos2
          end if
          eigVal(k,i_v3d_X) = sh + fac*cos1
          eigVal(k,i_v3d_Y) = sh + fac*cos2
          eigVal(k,i_v3d_Z) = sh + fac*cos3
        end if
      end do
      return
      end
我个人感觉是特征长度出现了问题,然后这是我根据技术邻上的讲解改的,但是依旧不太对,而且貌似技术邻上主讲的那个人也不是很懂,或者他自己有所保留,因为我按照他展示出的代码改出来的也不对,希望论坛上的各位大神能帮帮忙,指出我的问题所在,为这个问题烦恼了好久了
 楼主| 发表于 2020-10-1 13:51:29 | 显示全部楼层 来自 天津
现在是真的没有人用论坛了吗
发表于 2020-10-6 10:10:40 | 显示全部楼层 来自 大连理工大学西山生活区
wbqALIX 发表于 2020-10-1 13:51
现在是真的没有人用论坛了吗
可能是真的没有了 也不知道大佬们跑哪去了 好的稿子都是十年前的 哭了
发表于 2020-10-19 16:38:22 | 显示全部楼层 来自 大连理工大学西山生活区
我也在做这一块,是菜鸟,加qq交流一下啊,359598254
发表于 2020-10-19 16:44:42 | 显示全部楼层 来自 中国
11月份Abaqus复合材料建模技术与应用
从建模基础、入门到进阶、高级应用到SCI论文撰写解析
本次内容涉及纤维增强、颗粒增强、短纤维、加筋板、层合结构、静力分析等17个案例,可以结合自己研究,解析契合自己研究方向的例子
联 系 人: 科宇老师
报名电话:13520456594(微信同号)   报名QQ: 1446084643
【腾讯文档】ABAQUS复合材料建模技术与应用
https://docs.qq.com/pdf/DRGlpaHNiTFRZdk1k
发表于 2021-1-26 10:49:51 | 显示全部楼层 来自 天津
现在是真的没有人用论坛了吗
很多人都去技术邻了,工科都不容易,大家都要吃饭啊
发表于 2021-3-20 10:58:24 | 显示全部楼层 来自 山西
太难了,我也刚刚开始学,完全不懂
发表于 2021-3-21 11:35:12 | 显示全部楼层 来自 美国
楼主已经很厉害了,学习了
发表于 2021-4-7 10:09:28 | 显示全部楼层 来自 江苏无锡
谢谢楼主了
发表于 2022-4-16 16:09:22 | 显示全部楼层 来自 江苏南京
太难了,刚开始学,蹲一下
发表于 2022-9-26 19:37:39 | 显示全部楼层 来自 四川绵阳
向楼主学习
发表于 2023-9-21 15:58:04 | 显示全部楼层 来自 中国
请问楼主props(10) --> beta damping parameter这里设置多少啊
GMT+8, 2023-12-3 21:30 , Processed in 0.044793 second(s), 12 queries , Gzip On, MemCache On.
© 2001-2023 Discuz! Team.
