查看: 1552|回复: 0
[高级仿真] 如何运行NX自带的verification test case的dat文件
发表于 2020-12-8 21:44:35 | 显示全部楼层 |阅读模式 来自 福建厦门
如题,请教如何运行install_dir/NXr/nast/demo中文件?
其中一个dat文件内容如下:
$ DEC/CMS REPLACEMENT HISTORY, Element HD10101.DAT
$ *2    13-JAN-1994 16:41:47 A_BOYADJIAN "68 PLUS/G/ HEAT TRANSFER CONVERTED DECKS FOR V68 /DCC"
$ *1    15-JUN-1990 16:37:52 CMSMGR "66B PLUS/G 66B/ Initial installation of DEMO test problems"
$ DEC/CMS REPLACEMENT HISTORY, ELEMENT HD10101.DAT
$ *1    15-JUN-1990 16:37:52 CMSMGR "66B PLUS/G 66B/ INITIAL INSTALLATION OF DEMO TEST PROBLEMS"
NASTRAN SYSTEM(70) = -1
ID EDS, HD10101  $
$ID EDS, HDEM01   $
$ID EDS, HDEMO01  $
$ID CLASS PROBLEM ONE. C.E.JACKSON
$       MAXIMUM CPU TIME ALLOWED FOR THE JOB
TIME 5 $ UNITS ARE MINUTES
$       THE THERMAL ANALYZER PORTION OF NX/NASTRAN IS TO BE USED
$       THE LINEAR STEADY STATE ALGORITHM IS TO BE USED
$SOL 61
SOL 153
CEND $ END OF EXECUTIVE CONTROL DECK
ANALYSIS = HEAT
NLPARM = 100
SPC=100
$       END OF EXECUTIVE CONTROL  ...  START CASE CONTROL
TITLE=          LINEAR STEADY STATE PROBLEM                    HD10101
$       REQUEST SORTED AND UNSORTED CARD ECHO=S  TO SEE COMMENTS
$       IF THIS CARD IS OMITTED ONLY THE SORTED BULK DATA WILL APPEAR
$       COMMENT CARDS WOULD THEN NOT BE PRINTED
ECHO = BOTH
$       SPECIFY THE SUPERELEMENTS TO BE RUN
$       THIS CARD IS REQUIRED AND SPECIFIES ALL
$       FOR THIS MODEL THERE IS BUT A SINGLE SUPERELEMENT WHICH
$               ENCOMPASSES THE ENTIRE MODEL
$       SELECT THE SPC,MPC AND LOAD SETS TO BE USED IN THIS RUN
MPC=200
LOAD=300
$       SELECT THE OUTPUT DESIRED (TEMPERATURES,LOADS, AND CONSTRAINT
$               POWERS)
OUTPUT
THERMAL = ALL
OLOAD = ALL
SPCF = ALL
FLUX = ALL
$       PLOT PACKAGE TO DISPLAY MODEL AND SOLUTION
OUTPUT(PLOT)
CSCALE 1.8
PLOTTER NASTRAN
SET 1 INCLUDE ALL EXCEPT 60
AXES Z,X,Y
VIEW 0.,0.,0.
FIND SET 1
PTITLE = BASIC MODEL
PLOT SET 1
PTITLE = LABEL GRIDS
PLOT SET 1 LABEL GRIDS
PTITLE = LABEL ELEMENTS
PLOT SET 1 LABEL ELEMENTS
PTITLE = LABEL ELEMENT PROPERTIES
PLOT SET 1 LABEL EPID
PTITLE = THERMAL SHAPE
AXES X,Y,Z
VIEW 34.27,23.17,0.
FIND SET 1 SCALE ORIGIN 1
PLOT STATIC DEFORMATION 0,1 SET 1
PTITLE = TEMPERATURE CONTOURS
CONTOUR MAGNIT
PLOT CONTOUR 0,1 OUTLINE SET 1 PRINT
$       END CASE CONTROL ... START BULK DATA
BEGIN BULK $ ENDS CASECONTROL DECK
NLPARM, 100
$       UNITS MUST BE CONSISTENT
$       IN THIS PROBLEM METERS,WATTS,AND DEGREES CELSIUS ARE USED.
$       DEFINE GRID POINTS
$       CONNECT GRID POINTS
$       THESE ELEMENTS IMPROVE PLOT PICTURE BUT DO NOT EFFECT MODEL
$       DEFINE CROSS-SECTIONAL AREAS AND/OR THICKNESS
$       DEFINE MATERIAL THERMAL CONDUCTIVITY
$       DEFINE CONVECTIVE AREA AND CONVECTIVE COEFFICIENT =H=
$       DEFINE CONSTRAINTS
$       DEFINE APPLIED LOADS
$       THIS CARD BLOCKS PLOT MESSAGES(USUALLY MEANINGLESS)
$       END OF BULK DATA DECK
CHBDYP  60      300     LINE                    1       5
                                                        1.
PHBDY   300     .314
PCONV   300     3000
CONV    60      300                     100     100
CQUAD4  30      200     1       2       6       5
CQUAD4  40      200     2       3       7       6
CQUAD4  50      200     3       4       8       7
CROD    10      100     10      2
CROD    20      100     9       6
GRID    1
GRID    2               .1
GRID    3               .2
GRID    4               .3
GRID    5                       .1
GRID    6               .1      .1
GRID    7               .2      .1
GRID    8               .3      .1
GRID    9                       .2
GRID    10                      -.1
GRID    100             -.05    .05
MAT4    1000    200.
MAT4    3000                            200.
MPC     200     9       1       1.      5       1       -1.
MPC     200     10      1       1.      1       1       -1.
PARAM   PDRMSG  1
PARAM   PLTMSG  0
PLOTEL  70      5       9
PLOTEL  80      1       10
PROD    100     1000    .001
PSHELL  200     1000    .01
SLOAD   300     1       4.      2       8.
SLOAD   300     3       8.      4       4.
SLOAD   300     5       4.      6       8.
SLOAD   300     7       8.      8       4.
SPC     100     100     1       300.
$User Information Message: A number of default values are used when certain parameters are not available from the old decks.
$                          These parameters are given as the follows:
$CHBDYP  E1=3.141 E2=1.414 E3=1.732
$PHBDY   D1=1. D2=1.
$PCONVM  FORM=0 FLAG=1 COEF=1.E-6 EXPR=0. EXPPI=0. EXPPO=0.
$CONVM   TA1=99999
$SPC     C1=1
$MAT4    RHO (DENSITY) = 1.
$VIEW3D  ICAVITY=1
$RADCAV  ICAVITY=1 RMAX=0.1
$RADMTX  ICAVITY=1
$RADLST  ICAVITY=1 MTXTYP=1
ENDDATA
GMT+8, 2024-4-19 19:29 , Processed in 0.033929 second(s), 10 queries , Gzip On, MemCache On.
