查看: 230|回复: 1
[错误和警告信息] 怎么更改错误信息
发表于 2022-10-20 17:25:00 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 5
     The default hourglass properties of the following
     ALE part are being modified to avoid unnecessary
     application of hourglass forces.
     Resetting coefficient qm=1.0e-6.
     PART ID 5 with
     MATERIAL ID 5 and
     EOS ID 5
     This is PART 1 in the order of input.
*** Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 6
     PART ID 6 with
     MATERIAL ID 6 and
     EOS ID 6
     This is PART 2 in the order of input.
Memory required to process keyword     :    19720454
*** Error 70021 (OTH+21)
     Memory is set 9441095 words short
     memory size 20000000
     Increase the memory size by one of the following
     where #### is the number of words requested:
       1) On the command line set - memory=####
       2) In the input file define memory with *KEYWORD
       i.e., *KEYWORD #### or *KEYWORD memory=####
发表于 2022-11-6 17:09:28 | 显示全部楼层 来自 广东
错误种类有很多,你这个是给计算文件的储存空间设置的太小了,调大一点
GMT+8, 2026-1-6 11:58 , Processed in 0.025379 second(s), 12 queries , Gzip On, MemCache On.
