- 2023-7-8
DATE :20-08-23 TIME :18:24:18
%W-P1023214-NAS_PUT_SET1_ON_NIF, , ,
INPUT DECK: baobantest819.dat
LINE #15168: SET1,5,222165,THRU,222570,221759,THRU,222164,221353,
MESSAGE : SET1 - Duplicate SET1s (ID = 5) have been detected and
concatenated.
%W-P2141407-P2_CALC_GAS_CONST, , ,
The specific heat has not been specfied, or cannot
be calculated for material 2 . As a result, editing of
temperature for elements and heat transfer calculations concerning this
material is not possible.
be calculated for material 3 . As a result, editing of
%I-P2178301-P2_COUNT_REQ_MEMSIZE, , ,
The required memory size for the analysis is estimated:
23053857 integer words
18785590 float words
The above sizes will be used in core-memory allocation.
%W-P2092103-P2_WRITE_COUPLE_INFO, , ,(13),
THE SCALING FACTOR FOR THE TIME STEP IS GREATER THAN THE BLENDING
FACTOR, FOR STABILITY REASONS USE A PARAM STEPFCT SMALLER THAN PARAM
FBLEND
%E-P3116501-V3_REVERSE_POLYH_V3, , ,
A side of a face in surface SURFACE1 has no other faces attached.
This indicates a hole in the surface.
%E-P3116502-V3_REVERSE_POLYH_V3, , ,
Program error:
Inconsistent sorting of faces of COUPLING surface SURFACE1
Program error:
Program error:
Program error:
Program error:
NO MORE MESSAGES OF THIS KIND WILL BE WRITTEN
%I-P3002405-P3_CHECK_POLYH_SURF_VOL, , ,
Volume covered by SURFACE SURFACE1 is 0.26219E+00
%I-P3002404-P3_CHECK_POLYH_SURF_VOL, , ,
Area of surface SURFACE1 is 0.30968E+01
%I-P4024001-P4_SET_EUL_POLYH_TOLS, , ,
The general coupling will use the following tolerances:
Relative tolerance for lengths : 0.100E-13
Relative tolerance for gradients : 0.100E-13
%W-P4023706-P4_PROC_1_EULER_INFACE_CELL, , ,
Illegal coverage of face (4) of Euler element 247374 by surface
1. Covered face area is -0.79998E-03.
Total face area is 0.10000E-01
Check Current Geometry.
%W-P4023704-P4_PROC_1_EULER_INFACE_CELL, , ,
Illegal coverage of face (2) of Euler element 249873 by surface
1. Covered face area is -0.80000E-03.
%W-P4023708-P4_PROC_1_EULER_INFACE_CELL, , ,
Illegal coverage of face (6) of Euler element 249873 by surface
%W-P4023701-P4_PROC_1_EULER_INFACE_CELL, , ,
Intersection volume for Euler element 249874 by surface
1 is negative
Cell volume is 0.10000E-02 , intersection volume is -0.79998E-04
%W-P4023710-P4_PROC_1_EULER_INFACE_CELL, , ,(13),
NO FACE-POLYHEDRON COMBINATION FOUND FOR EULER ELEMENT 260128 ,BUT THERE
SHOULD BE ONE
JOBNAME IS: BAOBANTEST819
Dytran 2019 Windows x64
SUMMARY OF MESSAGES (INCLUDING NON-PRINTED MESSAGES)
INFORMATIVE : 4
WARNINGS : 9
ERRORS : 10
请求高手不吝赐教! |
