- 38
- 2004-4-24
偶用Matlab编了一个小文件,可以将Gambit 2.0做出来的2D三角形网格文件转换成Femlab 3.0的网格文件格式,不过可能有点缺陷,请大家指正。[在Polyflow里面可以得到收敛结果,但转换后在Femlab里面不收敛。:(]
function mesh = rdmesh(file)
if nargin < 1
error('Function requires one input argument');
elseif ~isstr(file)
error('Input must be a string representing a filename');
end
fid = fopen(file,'r');
if fid==-1
error('File not found or permission denied');
end
% Start of main routine ...
line = fgetl(fid);
while line~=-1
if ~isempty(findstr(line,'NUMNP'))
line = fgetl(fid);
para=sscanf(line,'%f'); % para represents: NUMNP NELEM NGRPS NBSETS NDFCD NDFVL
break;
end
line = fgetl(fid);
end
while line ~= -1
% Treat the node coordinates
if ~isempty(findstr(line,'NODAL COORDINATES'))
p=[];
line = fgetl(fid);
data = sscanf(line,'%f');
while ~isempty(data)
p = [p, data(2:3)];
line = fgetl(fid);
end
end
% Treat the triangel element
if ~isempty(findstr(line,'ELEMENTS/CELLS'))
t=[];
line = fgetl(fid);
data = sscanf(line, '%f');
t = [t, data(4:6)];
line = fgetl(fid);
end
t(4, = 1; % trianlge elements
end
% Get data of the boundary edge
if ~isempty(findstr(line,'BOUNDARY CONDITIONS'))
tmp=[]; % store the repeat boundary edge
n=1; % which boundary
for i=1:para(4)
line = fgetl(fid);
line = fgetl(fid);
if data(3)==1
tmp=[tmp,[t(1,data(1));t(2,data(1));0;0;n;0;0]];
elseif data(3)==2
tmp=[tmp,[t(2,data(1));t(3,data(1));0;0;n;0;0]];
else
tmp=[tmp,[t(3,data(1));t(1,data(1));0;0;n;0;0]];
end
line = fgetl(fid);
end
line = fgetl(fid);
if line == -1
break;
end
n=n+1;
end
end
line = fgetl(fid);
end % while
fclose(fid);
% Treatment of boundary
eps=1E-4;
e=0*tmp;
for ix = 1:para(4)
n=find(tmp(5,:)==ix);
s=length(n);
if abs(p(1,tmp(1,n(1)))-p(1,tmp(2,n(1))))<eps
tmp(7,n)=1;
if p(2,tmp(1,n(1)))>p(2,tmp(2,n(1)))
e(:,n(1):n(s))=fliplr(tmp(:,n(1):n(s)));
e(1:2,n(1):n(s))=flipud(e(1:2,n(1):n(s)));
else
e(:,n(1):n(s))=tmp(:,n(1):n(s));
end
len=p(2,e(2,n(s)))-p(2,e(1,n(1)));
for i=1:s
e(3,n(i))=(p(2,e(1,n(i)))-p(2,e(1,n(1))))/len;
e(4,n(i))=(p(2,e(2,n(i)))-p(2,e(1,n(1))))/len;
end
else
tmp(6,n)=1;
if p(1,tmp(1,n(1)))>p(1,tmp(2,n(1)))
else
end
len=p(1,e(2,n(s)))-p(1,e(1,n(1)));
for i=1:s
e(3,n(i))=(p(1,e(1,n(i)))-p(1,e(1,n(1))))/len;
e(4,n(i))=(p(1,e(2,n(i)))-p(1,e(1,n(1))))/len;
end
end
end
% Mesh generate combine with femlab
mesh.p=p; mesh.e=e; mesh.t=t;
mesh.v=[1:para(4); NaN*ones(1,para(4))];
mesh.equiv = zeros(4,0);
save mesh mesh; |
