/COM,ANSYS MEDIA REL. 9.0 (10/15/2004) REF. VERIF. MANUAL: REL. 9.0
/VERIFY,VM144
/PREP7
/TITLE, VM144, BENDING OF A COMPOSITE BEAM
C*** FORMULAS FOR STRESS AND STRAIN, ROARK, 5TH ED.
C*** USING LAYERED SHELL ELEMENT (SHELL99)
ANTYPE,STATIC
ET,1,SHELL99 ! 8 NODE LAYERED SHELL ELEMENT
R,1,2 ! 2 LAYERS PER ELEMENT
RMORE
RMORE,1,0,.2,2,0,.1 ! LAYER 1: 0.2 THK; LAYER 2: 0.1 THK
MP,EX,1,1.2E6 ! MATERIAL 1 PROPERTIES
MP,NUXY,1,0
MP,ALPX,1,18E-5
MP,ALPY,1,0.0
MP,EX,2,0.4E6 ! MATERIAL 2 PROPERTIES
MP,NUXY,2,0
MP,ALPX,2,6E-5
MP,ALPY,2,0
N,1
N,9,8
FILL
NGEN,3,10,1,9,,,.25
E,1,3,23,21,2,13,22,11
EGEN,4,2,-1 ! 4 ELEMENTS ALONG BEAM LENGTH
CP,1,ROTY,9,19,29 ! COUPLE FREE END NODES FOR ROTATION
D,1,ALL,,,21,10 ! FIXED END
F,19,MY,10 ! APPLY BENDING MOMENT AT FREE EDGE
BFUNIF,TEMP,100 ! ELEVATED TEMPERATURE LOAD
FINISH
/SOLU
SOLVE
FINISH
/POST1
NSEL,S,LOC,X,8 ! SELECT FREE EDGE
PRNSOL,U,Z ! PRINT DISPLACEMENTS
*GET,U1,NODE,9,U,Z
NSEL,S,LOC,Y ! SELECT NODES ALONG LENGTH
SHELL,TOP
PRNSOL,S,COMP ! PRINT TOP STRESSES
*GET,ST1,NODE,1,S,X
SHELL,BOT
PRNSOL,S,COMP ! PRINT BOTTOM STRESSES
*GET,SB1,NODE,1,S,X
ALLSEL
*DIM,LABEL,CHAR,3,2
*DIM,VALUE,,3,3
LABEL(1,1) = 'DISP ','PRS TP ','PRS BTM '
LABEL(1,2) = 'in','psi','psi'
*VFILL,VALUE(1,1),DATA,.832,2258,1731
*VFILL,VALUE(1,2),DATA,U1,ST1,SB1
*VFILL,VALUE(1,3),DATA,ABS(U1/.832),ABS(ST1/2258),ABS(SB1/1731)
SAVE,TABLE_1
FINISH
/PREP7
C*** USING SHELL99 ELEMENTS WITH NODE OFFSET OPTION
KEYOPT,1,11,2 ! WITH NODAL PLANE ON TOP FACE
R,1,1 ! BOTTOM LAYER
RMORE
RMORE,1,0,.2
ET,2,SHELL99 ! 8 NODE LAYERED SHELL ELEMENT
KEYOPT,2,11,1 ! WITH NODAL PLANE ON BOTTOM FACE
R,2,1 ! TOP LAYER
RMORE
RMORE,2,0,.1
EGEN,2,0,1,4,1,,1,1 ! GENERATE OVERLAPPING ELEMENTS
FINISH
/SOLU
SOLVE
FINISH
/POST1
*GET,U2,NODE,9,U,Z
SHELL,TOP
ESEL,S,TYPE,,2 ! ELEMENTS REPRESENTING TOP LAYER
*GET,ST2,NODE,1,S,X
SHELL,BOT
ESEL,S,TYPE,,1 ! ELEMENTS REPRESENTING BOTTOM LAYER
*GET,SB2,NODE,1,S,X
*VFILL,VALUE(1,2),DATA,U2,ST2,SB2
*VFILL,VALUE(1,3),DATA,ABS(U2/.832),ABS(ST2/2258),ABS(SB2/1731)
SAVE,TABLE_2
FINISH
/CLEAR,NOSTART
/PREP7
C*** USING LAYERED SOLID ELEMENTS (SOLID46)
ANTYPE,STATIC
ET,1,SOLID46,,,,,2,4 ! LAYERED SOLID ELEMENTS
R,1,2 ! 2 LAYERS
RMORE
RMORE,1,0,2,2,0,1 ! RELATIVE LAYER THICKNESSES
MP,NUXY,1,0
MP,ALPX,1,1.8E-4
MP,ALPY,1,0.0
MP,ALPZ,1,0.0
MP,NUXY,2,0
MP,ALPX,2,0.6E-4
MP,ALPY,2,0.0
MP,ALPZ,2,0.0
N,1
N,9,8
FILL
NGEN,2,10,1,9,1,,.5
NGEN,2,20,1,19,1,,,.3
E,1,2,12,11,21,22,32,31
EGEN,8,1,-1 ! 8 ELEMENTS ALONG LENGTH
D,1,ALL,,,31,10 ! FIXED END
F,9,FX,-(50/3),,19,10 ! APPLY NODAL FORCES TO GENERATE MOMENT
F,29,FX,(50/3),,39,10
FINISH
/SOLU
SOLVE
FINISH
/POST1
NSEL,S,LOC,X,8
PRNSOL,U,Z ! PRINT FREE END DISPLACEMENTS
*GET,U3,NODE,9,U,Z
NSEL,S,LOC,Z,0.3
PRNSOL,S,COMP ! PRINT STRESSES ALONG TOP SURFACE
*GET,ST3,NODE,21,S,X
NSEL,S,LOC,Z
PRNSOL,S,COMP ! PRINT STRESSES ALONG BOTTOM SURFACE
*GET,SB3,NODE,1,S,X
*DIM,LABEL,CHAR,3,2
*DIM,VALUE,,3,3
*VFILL,VALUE(1,2),DATA,U3,ST3,SB3
*VFILL,VALUE(1,3),DATA,ABS(U3/.832),ABS(ST3/2258),ABS(SB3/1731)
SAVE, TABLE_3
FINISH
/CLEAR,NOSTART
/PREP7
C*** USING LAYERED SOLID ELEMENTS (SOLID191)
ANTYPE,STATIC
ET,1,SOLID191,,,,,2, ! LAYERED SOLID ELEMENTS
R,1,2 ! 2 LAYERS
RMORE
MP,NUXY,1,0
MP,ALPX,1,1.8E-4
MP,ALPY,1,0.0
MP,ALPZ,1,0.0
MP,NUXY,2,0
MP,ALPX,2,0.6E-4
MP,ALPY,2,0.0
MP,ALPZ,2,0.0
N,1
N,9,8
FILL
NGEN,2,10,1,9,1,,.5
emid
nsel,s,loc,x
D,all,ALL, ! FIXED END
nsel,all
nlist,all
sfe,8,3,pres,,4000/3,4000/3,-4000/3,-4000/3 ! tapered pressure to apply moment on face
FINISH
/SOLU
outpr,,1
SOLVE
FINISH
/POST1
NSEL,S,LOC,X,8
*GET,U3,NODE,9,U,Z
NSEL,S,LOC,Z,0.3
NSEL,S,LOC,Z
*GET,SB3,NODE,1,S,X
*DIM,LABEL,CHAR,3,2
*DIM,VALUE,,3,3
SAVE, TABLE_4
RESUME,TABLE_1
/COM
/OUT,vm144,vrt
/COM,------------------- VM144 RESULTS COMPARISON --------------
/COM,
/COM, | TARGET | ANSYS | RATIO
/COM,
/COM,RESULTS USING SHELL99 MODEL
*VWRITE,LABEL(1,1),LABEL(1,2),VALUE(1,1),VALUE(1,2),VALUE(1,3)
(1X,A8,A8,' ',F10.3,' ',F10.3,' ',1F5.3)
/NOPR
RESUME,TABLE_2
/GOPR
/COM,
/COM,RESULTS USING SHELL99 (WITH NODE OFFSET)
/NOPR
RESUME,TABLE_3
/GOPR
/COM,
/COM,RESULTS USING SOLID46
/NOPR
RESUME, TABLE_4
/GOPR
/COM,RESULTS USING SOLID191
/COM,-----------------------------------------------------------
/OUT
FINISH
*LIST,vm144,vrt |
