查看: 142|回复: 0
[10. Others] 【求助】那位大侠有梁剖面分析的VABS分析软件或其源程序
发表于 2004-11-3 14:21:25 | 显示全部楼层 |阅读模式 来自 江苏南京
具体概念如下:Variational Asymptotical Beam Sectional Analysis (VABS) is a cross-sectional analysis tool to calculate the cross-sectional properties (neutral axes, centroid, center of gravity, shear center, classical beam model, Timoshenko beam model, and Vlasov beam model) for a slender structure with arbitrary geometry made with arbitrary material. and recover the 3-D strain and stress fields distribution throughout the cross section.网上有介绍,但是没有代码或者软件。谢谢!
GMT+8, 2024-11-2 01:32 , Processed in 0.031184 second(s), 13 queries , Gzip On, MemCache On.
