查看: 261|回复: 4
3D感应加热
发表于 2005-1-20 11:00:01 | 显示全部楼层 |阅读模式 来自 北京航空航天大学
那位大虾能够上传或Email一个3D感应加热的实例啊,小第正心急如焚的做客提,将不胜感激。
Email:zws77826@163.com
发表于 2005-2-24 14:21:23 | 显示全部楼层 来自 大连理工大学
Re:3D感应加热
#151436 - A 3d induction heating example
The main limitiations with this analysis type are 1) you can't have a
bh curve in a harmonic analysis and 2)  BH curves are not temperature
dependent.  Given these limitations, the most accurate thing that can be
done is to define a series of effective constant permeabilities, and
assign elements different material set numbers based on their H value.
Of course, this would be an iterative process.
!  3d Induction Heating Example created at ANSYS 6.0
/prep7
et,1,117
et,2,117,1                ! volt dof needed in eddy current region
et,11,200,7               ! quad with mid-side nodes for meshing
mp,murx,1,1
mp,murx,2,1000            ! approximate iron properties
mp,rsvx,2,.2e-6
wprot,,90                 ! build model in xz plane for later use of
csys,1
                         ! build model in inches and scale to meters at
the end
rect,.5,1,,1
rect,.5,1,1,2
rect,.5,1,2,3
rect,1,1.2,,1
rect,1,1.2,1,2
rect,1,1.2,2,3
rect,1.2,2,,1
rect,1.2,2,1,2
rect,1.2,2,2,3
nummrg,kp
lsel,a,,,3,11,4
LESIZE,all,,,20,10,,,,1
lsel,all
lesize,1,,,20,.1,,,,1
lesize,25,,,10,5
lsel,s,,,27,35,4
lesize,all,,,10,.2
lsel,all
FLST,5,4,4,ORDE,4
FITEM,5,6
FITEM,5,8
FITEM,5,18
FITEM,5,30
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,20, , , , ,1
FLST,5,8,4,ORDE,8
FITEM,5,2
FITEM,5,4
FITEM,5,10
FITEM,5,12
FITEM,5,14
FITEM,5,22
FITEM,5,26
FITEM,5,34
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10,5, , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,2
FITEM,5,12
FITEM,5,14
FITEM,5,26
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10,.2, , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,13
FITEM,5,15
FITEM,5,19
FITEM,5,23
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,2, , , , ,1
type,11
esha,2
amesh,all
k,101,
k,102,,,1
type,1
esize,,2
vrotate,all,,,,,,101,102,15,1
aclear,1,9,1
etdele,11
vsel,s,,,2
eslv
emod,all,mat,2
emod,all,type,2
alls
local,11,1
emod,all,esys,11      ! so current is applied tangentially
vlscale,all,,,1/39.36,1/39.36,1/39.36,,,1     ! scale to meters
FINISH
!!! Create 10 magnetic solutions at 10 coil locations
/filn,emag
/solu
antype,harm
harf,,10000             ! excitation at 10 khz
nsel,s,ext
d,all,az,0              ! flux parallel at model edges
nsel,all
CoilLoc=1.15            ! parameter controlling coil location
*do,iii,1,10,1
CoilLoc=CoilLoc+.05     ! move coil .05 meters each new solution
bfedel,all,js           ! delete previous curr density load
vsel,s,,,5
eslv
nsel,s,loc,z,CoilLoc/39.36,(CoilLoc+.1)/39.36
esln,r,1
bfe,all,js,2,1e8     ! Arbitrary current density input, 1e8
amps/meter**2
alls
save
solve
*enddo
fini
!!! Convert to thermal model and solve for the 10 heat generation cases
/filn,thermal
/prep7
et,1,0           ! make non steel elements null
et,2,70          ! 8 node thermal brick
mp,kxx,2,50
mp,dens,2,7800
mp,c,2,4
FINISH
/solu
antype,trans
ic,all,temp,70
tval=0
*do,jjj,1,10,1
ldread,hgen,jjj,1,,,emag,rst
tval=tval+1      ! use 1 second between solutions, velocity = .05/1
Meters/sec.
time,tval
solve
*enddo
fini
/exit
发表于 2009-4-13 15:43:27 | 显示全部楼层 来自 上海
这个例子不行啊,根本运行不下去,error太多。
发表于 2010-7-5 16:39:43 | 显示全部楼层 来自 浙江杭州
运行很好,没问题,不知计算结果如何
发表于 2010-7-9 18:00:38 | 显示全部楼层 来自 黑龙江哈尔滨
有没有GUI的啊
GMT+8, 2024-9-30 05:25 , Processed in 0.048338 second(s), 14 queries , Gzip On, MemCache On.
