- 8
- 2003-11-26
楼主 |
发表于 2005-1-31 09:21:07
来自 山东泰安
Re:direct coupled-field analysis of a bimetallic beam under a thermal load
:})Step 6: Set Boundary Conditions and Initial Temperatures.
1. Choose menu pathUtility Menu> Select> Entities.
2. In the top scroll box, select Nodes.
3. In the second scroll box, select By Location.
4. Click on X coordinates to select it, and enter 0 for Min, Max.
5. Click on Apply.
6. Click on Y coordinates, then Reselect.
7. Enter .05 for Min, Max, and click on OK.
8. Choose menu path Main Menu> Solution> Define Loads> Apply> Structural> Displacement> On Nodes. The Apply U,ROT on Nodes picking menu appears.
9. Click on Pick All. The Apply U,ROT on Nodes dialog box appears.
10. Click on UY for DOFs to be constrained and click on OK.
11. Choose menu path Utility Menu> Select> Entities.
12. Click on X coordinates to select it, click on From Full, enter 5 for Min, Max and click on OK.
13.Choose menu path Main Menu> Solution> Define Loads> Apply> Structural> Displacement> Symmetry B.C.> On Nodes. The Apply SYMM on Nodes dialog box appears.
14.Click on OK to accept the default of Symm surface is normal to X-axis.
15.Choose menu path Utility Menu> Select> Everything.
16. Choose menu path Main Menu> Solution> Define Loads> Apply> Structural> Displacement> On Nodes. The Apply U,ROT on Nodes picking menu appears.
17.Click on Pick All. The Apply U,ROT on Nodes dialog box appears.
18.Unselect UY and select Temp.
19.Enter 400 for displacement value and click on OK. |
