查看: 216|回复: 0
问一个关于帮助文档的问题
发表于 2005-3-23 17:06:25 | 显示全部楼层 |阅读模式 来自 北京交通大学
当添加某一帮助文件到收藏夹的时候,出现以下错误,哪位能帮在下解决一下。
fatal error.
-Type:IllegalArgumentException
以下是详细信息:
Exception:
  java.lang.IllegalArgumentException: argument is null
  (rethrown as com.femlab.util.FlFatalException)
  Fatal error.
  Type: IllegalArgumentException
Stack trace:
  at javax.swing.tree.DefaultMutableTreeNode.getIndex(DefaultMutableTreeNode.java:261)
  at javax.help.plaf.basic.BasicFavoritesNavigatorUI.treeNodesInserted(BasicFavoritesNavigatorUI.java:846)
  at javax.swing.tree.DefaultTreeModel.fireTreeNodesInserted(DefaultTreeModel.java:497)
  at javax.swing.tree.DefaultTreeModel.nodesWereInserted(DefaultTreeModel.java:294)
  at javax.swing.tree.DefaultTreeModel.insertNodeInto(DefaultTreeModel.java:223)
  at javax.help.plaf.basic.BasicFavoritesNavigatorUI$AddAction.actionPerformed(BasicFavoritesNavigatorUI.java:942)
  at javax.help.FavoritesAction.actionPerformed(FavoritesAction.java:68)
  at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1786)
  at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(AbstractButton.java:1839)
  at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
  at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
  at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:245)
  at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:231)
  at java.awt.Component.processMouseEvent(Component.java:5100)
  at java.awt.Component.processEvent(Component.java:4897)
  at java.awt.Container.processEvent(Container.java:1569)
  at java.awt.Component.dispatchEventImpl(Component.java:3615)
  at java.awt.Container.dispatchEventImpl(Container.java:1627)
  at java.awt.Component.dispatchEvent(Component.java:3477)
  at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:3483)
  at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3198)
  at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3128)
  at java.awt.Container.dispatchEventImpl(Container.java:1613)
  at java.awt.Window.dispatchEventImpl(Window.java:1606)
  at java.awt.EventQueue.dispatchEvent(EventQueue.java:456)
  at com.femlab.gui.FlEventQueue.dispatchEvent(FlEventQueue.java:24)
  at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:201)
  at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
  at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:145)
  at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:137)
  at java.awt.EventDispatchThread.run(EventDispatchThread.java:100)
GMT+8, 2026-1-7 03:58 , Processed in 0.027312 second(s), 14 queries , Gzip On, MemCache On.
