- 1
- 2004-10-27
各位大哥,我由于做球穿透板的那个例子老是不对,从论坛上找到启示直接运行官方例子的dat文件,但还是出现同样的错误,百思不得其解,不知道是软件的原因还是例子本身就有错误,特来向各位大哥请教
这是求穿透板的错误文件:
DATE :30-04-05 TIME :13:21:28
%I-P2044902-P2XXTXIX_PACKET_ZVARS,,,
Requested variable EFFPL is unknown and changed into EFFPLS
Requested variable EFFST is unknown and changed into EFFSTS
%W-P2108906-P2_DEFINE_VARIABLES_FOR_EDIT,,,
Variable EFFPLS is not legal in input set PLATE and is
therefore ignored.
This may result in an empty edit set.
Variable EFFSTS is not legal in input set PLATE and is
therefore ignored.
Variable TXX is not legal in input set PLATE and is
therefore ignored.
%I-P4142610-P4_CONT_OSCNTC_V4,,,
The suggested number of cubes from the contact cube sorting algoritm is
5400. LIMCUB is set to 2000
The contact runs faster if LIMCUB is raised to at least the number
that is suggested by the algoritm. This can be achieved by setting
PARAM,LIMCUB to 5400 at the beginning of a new analysis.
Please note that more memory will be used and it is not allowed in a
restart analysis.
3645. LIMCUB is set to 2000
PARAM,LIMCUB to 3645 at the beginning of a new analysis.
restart analysis.
3125. LIMCUB is set to 2000
PARAM,LIMCUB to 3125 at the beginning of a new analysis.
restart analysis.
2304. LIMCUB is set to 2000
PARAM,LIMCUB to 2304 at the beginning of a new analysis.
restart analysis.
restart analysis.
NO MORE MESSAGES OF THIS KIND WILL BE WRITTEN
JOBNAME IS: RIGID_IMAPCT
MSC.Dytran 2004 Single-CPU Windows
SUMMARY OF MESSAGES (INCLUDING NON-PRINTED MESSAGES)
INFORMATIVE : 7
WARNINGS : 3
NO ERRORS
这是梁撞击墙的错误文件:
DATE :30-04-05 TIME :13:57:15
Variable EFFST-IN is not legal in input set BEAM and is
therefore ignored.
Variable EFFST-MID is not legal in input set BEAM and is
therefore ignored.
Variable EFFST-OUT is not legal in input set BEAM and is
therefore ignored.
Variable EFFPL-IN is not legal in input set BEAM and is
therefore ignored.
Variable EFFPL-MID is not legal in input set BEAM and is
therefore ignored.
%W-P4216001-V4LZT8I1_MOD2_STRAIN_RATE_SPIN,,,
Time step 1.097E-06 too large for correct stress rotation
Use corotational stress formulation
JOBNAME IS: BEAM
WARNINGS : 6
NO ERRORS |
