- 5
- 2004-7-14
最优化程序汇编 常用程序集
工人出版社
C**********************************************************************
 ROGRAM TAY
C DIMENSION X(N),H(N),F(M),DF(M,N),AA(N,N)
DIMENSION X(2),H(2),F(479),DF(479,2),AA(2,2),TT(479),U(479)
COMMON NF
COMMON TT,U
OPEN(2,FILE='CL.DAT')
OPEN(3,FILE='RESULT2.DAT')
DO 5 I=1,479
5 READ(2,*,END=6) TT( I ),U( I )
6 N=2
M=479
DO 10 I=1,N
H( I )=0.001
10 CONTINUE
NF=0
ITMAX=1000
S=1.0E20
X(1)=60
X(2)=4
CALL TAYLOR(N,M,X,H,F,ITMAX,0.5E-1,0.5E-1,S,KENN,DF,AA)
IF(KENN.EQ.1) WRITE(*,*)'NO REACH CONVERGENCE PRECISION WHEN
* ITMAX=1000'
IF(KENN.EQ.-1) WRITE(*,*)'MINIZATION FAILED'
IF(KENN.EQ.0) WRITE(*,30)
30 FORMAT(/1X, 'REACH CONVERGENCE PRECISION '/)
WRITE(*,*) 'X( I ),I=1,N'
WRITE(*,40) (I,X( I ),I=1,N)
WRITE(*,*) 'F( I ),I=1,N'
WRITE(*,40) (I,F( I ),I=1,N)
WRITE(3,*) 'X( I ),I=1,N'
WRITE(3,40) (I,X( I ),I=1,N)
WRITE(3,*) 'F( I ) ,I=1,N'
WRITE(3,40) (I,F( I ),I=1,N)
40 FORMAT(1X,5(3X,I3,2X,E15.8))
WRITE(*,50) ITMAX,NF,S
WRITE(6,50) ITMAX,NF,S
50 FORMAT(1X,'ITMAX=',I3,3X,'NF=',I4,3X,'S=',E15.8)
STOP
END
SUBROUTINE TAYLOR(N,M,X,H,F,ITMAX,EPS1,EPS2,S,KENN,DFDX,AA)
DIMENSION FP(500),FM(500),B(30),DX(30),DFDX(M,N),AA(N,N),
* X(N),F(M),H(N)
HS=S
KENN=0
IZ=0
23 IZ=IZ+1
IF(IZ-ITMAX) 1,1,2
2 KENN=1
GO TO 25
1 L=0
HL=1.0
24 L=L+1
IF(L-16) 3,3,4
4 KENN=-1
GO TO 25
3 CALL FUNCT(X,F,N,M)
HF=0
DO 5 I=1,M
5 HF=HF+F( I )*F( I )
IF(HF-HS*(1.0-0.2*HL)) 6,6,7
7 HL=0.5*HL
DO 8 K=1,N
8 X(K)=X(K)+HL*DX(K)
GO TO 24
6 HS=HF
IF(HS.LT.EPS1) GO TO 25
DO 12 I=1,N
HF=H( I )
HZ=2.0*HF
HH=X( I )
X( I )=X( I )+HF
CALL FUNCT(X,FP,N,M)
X( I )=X( I )-HZ
CALL FUNCT(X,FM,N,M)
X( I )=HH
HZ=1.0/HZ
DO 12 K=1,M
12 DFDX(K,I)=HZ*(FP(K)-FM(K))
IF(M-N) 14,15,14
15 CALL GAUSS(N,DFDX,F,DX,1.0E-10,N)
GO TO 20
14 DO 17 I=1,N
HF=0.0
DO 18 K=1,M
18 HF=HF+DFDX(K,I)*F(K)
B( I )=HF
DO 17 K=1,N
HF=0.0
DO 16 J=1,M
16 HF=HF+DFDX(J,I)*DFDX(J,K)
AA(I,K)=HF
17 AA(K,I)=HF
CALL GAUSS(N,AA,B,DX,1.E-10,N)
20 HZ=0.0
HF=0.0
DO 21 I=1,N
X( I )=X( I )-DX( I )
HZ=HZ+ABS(X( I ))
21 HF=HF+ABS(DX( I ))
IF(HF.GE.EPS2*HZ) GO TO 23
25 CALL FUNCT(X,F,N,M)
S=0.0
ITMAX=IZ
DO 22 I=1,M
22 S=S+F( I )*F( I )
RETURN
END
SUBROUTINE GAUSS(N,A,B,X,EP,M)
DIMENSION A(M,M),B(N),X(N)
DO 10 K=1,N
C=0.0
DO 9 I=K,N
IF(ABS(A(I,K)).LE.ABS(C)) GO TO 9
C=A(I,K)
I0=I
9 CONTINUE
IF(ABS(C).LE.EP) PAUSE 1
IF(I0.EQ.K) GO TO 13
DO 12 J=K,N
T=A(K,J)
A(K,J)=A(I0,J)
12 A(I0,J)=T
T=B(K)
B(K)=B(I0)
B(I0)=T
13 C=1.0/C
IK=K+1
DO 15 J=IK,N
A(K,J)=A(K,J)*C
DO 16 I=IK,N
16 A(I,J)=A(I,J)-A(I,K)*A(K,J)
15 CONTINUE
B(K)=B(K)*C
DO 8 I=IK,N
8 B( I )=B( I )-B(K)*A(I,K)
10 CONTINUE
DO 18 I=N,1,-1
DO 18 J=I+1,N
B( I )=B( I )-A(I,J)*B(J)
18 CONTINUE
DO 11 I=1,N
11 X( I )=B( I )
RETURN
END
SUBROUTINE FUNCT(X,F,N,M)
DIMENSION X(N),F(M),TT(479),U(479),FF(479)
COMMON NF
COMMON TT,U
P0=316.77
WRITE(*,*) P0,X(1),X(2)
WRITE(3,5) P0,X(1),X(2)
PAUSE 2
DO 10 I=1,M
10 FF( I )=P0-X(1)*LOG(TT( I )/(X(2)+TT( I ))+1)
DO 20 I=1,M
20 F( I )=U( I )-FF( I )
NF=NF+1
5 FORMAT(F8.4,6X,F10.6,4X,F10.6)
RETURN
END
编辑过了,请大家禁用笑脸标记 |
