- 11
- 2004-8-8
楼主 |
发表于 2005-6-21 15:29:19
来自 河南焦作
Re:含水层排水产生固结压缩的讨论
那我想定义一个有含水层和隔水层的模型,怎么编程,另外底部含水层的空隙水压力怎么确定,我编的源程序如下,各位仁兄帮我看看对不对,希望提出更好的建议:
new
set logfile renlian
set log on
config fluid
gen zone brick &
p0 0,0,0 p1 12,0,0 p2 0,0,-4 p3 0,12,0 &
size 6 2 6
group z1 range z -4 0
gen zone brick &
p0 0,0,-4 p1 12,0,-4 p2 0,0,-6 p3 0,12,-4 &
size 6 1 6
group z2 range z -6 -4
gen zone brick &
p0 0,0,-6 p1 12,0,-6 p2 0,0,-10 p3 0,12,-6 &
size 6 2 6
group z3 range z -10 -6
gen zone brick &
p0 0,0,-10 p1 12,0,-10 p2 0,0,-12 p3 0,12,-10 &
size 6 1 6
group z4 range z -12 -10
plot surf
model mohr range group z1
prop bulk 6.173e5 shear 4.065e5 coh 0 fric 30 range group z1
model mohr range group z2 ;隔水层
prop bulk 6.667e6 shear 3.077e6 coh 18000 fric 23.0 range group z2
model mohr range group z3 ;含水层
prop bulk 32.051e6 shear 20.161e6 coh 200 fric 25 range group z3
model drucker range group z4 ;基岩
prop bulk 1.344e10 kshear 3.0e7 qdil 1.0 qvol 0.7 shear 1.050e10 tension 4.25e8 &
range group z4
;下面的定义对不对
model fl_iso range group z3
prop perm 1.0e-8 poro 0.3
model fl_iso range group z4
prop perm 1.0e-15 poro 0.1
;下面的语句是不是要有个范围才对
ini fmod 2.e9
ini fdensity 1000
ini pp 2.0e5 grad 0 0 -10000 range group z3 ;对吗
;fix pp range z -32.1 -31.9
;fix pp range z -38.1 -37.9
ini dens 1030 range group z1
ini dens 980 range group z2
ini dens 910 range group z3
ini dens 2650 range group z4
;--------------------------------边界条件
fix z range z -12.1 -11.9
fix x range x -0.1 0.1
fix x range x 11.9 12.1
fix y range y -0.1 0.1
fix y range y 11.9 12.1
set grav 0 0 -10
;一含
ini szz 0 grad 0 0 10300 range z -4 0
ini syy 0 grad 0 0 3090 range z -4 0
ini sxx 0 grad 0 0 3090 range z -4 0
;一隔
ini szz -2000 grad 0 0 9800 range z -6 -4
ini syy 4480 grad 0 0 4210 range z -6 -4
ini sxx 4480 grad 0 0 4210 range z -6 -4
;底含
ini szz -6200 grad 0 0 9100 range z -10 -6
ini syy -3320 grad 0 0 2910 range z -10 -6
ini sxx -3320 grad 0 0 2910 range z -10 -6
;基岩
ini szz 167800 grad 0 0 26500 range z -12 -10
ini syy 31180 grad 0 0 6360 range z -12 -10
ini sxx 31180 grad 0 0 6360 range z -12 -10
set fluid off
hist unbal
; Settings
set large
; Cycling
solve rat 1.e-6
save chu.sav
plot sketch
plot add cont zdisp
plot show
ini xdis 0 ydis 0 zdis 0
ini state 0
set mech force 1.5e2
set mech substep 100 slave
hist fltime
hist gp zd 2 6 -8
hist gp zd 6 6 -8
hist gp zd 10 6 -8
set fluid on
solve age 0.5e5
plot cont pp
save 2.sav
solve age 1e6
plot cont pp
save 3.sav
plot hist 3 4 5 vs 2 |
