查看: 222|回复: 0
[轉貼]:小遊戲
发表于 2006-6-20 15:35:18 | 显示全部楼层 |阅读模式 来自 江苏苏州
/NOPR !Suppress printout
/PMACRO
/COM, ==========================================================
/COM,
/COM, NAVAL BATTLE
/COM,
TRUE = 1 !Logical true
FALS = 0 !Logical false
HORZ = 0 !Horizontal
VERT = 1 !Vertical
NHOR = 10 !Number of horizontal grids
NVER = 10 !Number of vertical grids
NSHP = 6 !Number of ships
NSNK = 0 !Number of ships sunk
NDES = 0 !Number of destroyers sunk
NSUB = 0 !Number of submarines sunk
NMVE = 0 !Number of moves
*DIM,SSHP,ARRAY,NSHP !Ship sizes
SSHP(1) = 5,4,3,3,2,2
*DIM,RSHP,ARRAY,NSHP !Real constant for each ship
RSHP(1) = 0,0,0,0,0,0
*DIM,OSHP,ARRAY,NSHP !Orientation of each ship
OSHP(1) = 0,0,0,0,0,0
*DIM,XSHP,ARRAY,NSHP !Horizontal starting grid
XSHP(1) = 0,0,0,0,0,0
*DIM,YSHP,ARRAY,NSHP !Vertical starting grid
YSHP(1) = 0,0,0,0,0,0
*DIM,HSHP,ARRAY,NSHP !Number of hits on each ship
HSHP(1) = 0,0,0,0,0,0
*DIM,GRID,ARRAY,NHOR,NVER !Grid array
/PREP7
/TRIAD,OFF
IMMED,OFF
N,1
N,NHOR+1,NHOR
FILL,1,NHOR+1
NGEN,NVER+1,NHOR+1,1,NHOR+1,1,0,1
ET,1,42
E,1,2,NHOR+3,NHOR+2
EGEN,NHOR,1,1,1,1
EGEN,NVER,NHOR+1,1,NHOR,1
KSHP = 1
*DO,I,1,999,1
RSHP(KSHP) = NINT(RAND(2,NSHP+1))
UNIQ = TRUE
*DO,J,1,KSHP-1,1
*IF,RSHP(KSHP),EQ,RSHP(J),THEN
UNIQ = FALS
*ENDIF
*ENDDO
*IF,UNIQ,EQ,FALS,CYCLE
KSHP = KSHP+1
*IF,KSHP,EQ,NSHP+1,EXIT
*ENDDO
*DO,I,1,NHOR,1
*DO,J,1,NVER,1
GRID(I,J) = 0
*ENDDO
*ENDDO
KSHP = 1
*DO,I,1,999,1
OSHP(KSHP) = NINT(RAND(0,1))
*IF,OSHP(KSHP),EQ,HORZ,THEN
XSHP(KSHP) = NINT(RAND(0.51,NHOR-SSHP(KSHP)+0.51))
YSHP(KSHP) = NINT(RAND(0.51,NVER+0.49))
*IF,XSHP(KSHP)+SSHP(KSHP),GT,NHOR,CYCLE
*ELSE
XSHP(KSHP) = NINT(RAND(0.51,NHOR+0.49))
YSHP(KSHP) = NINT(RAND(0.51,NVER-SSHP(KSHP)+0.51))
*IF,YSHP(KSHP)+SSHP(KSHP),GT,NVER,CYCLE
*ENDIF
UNIQ = TRUE
*DO,J,XSHP(KSHP),XSHP(KSHP)+SSHP(KSHP),1
*IF,GRID(J,YSHP(KSHP)),EQ,1,THEN
UNIQ = FALS
*ENDIF
*ENDDO
*ELSE
*DO,J,YSHP(KSHP),YSHP(KSHP)+SSHP(KSHP),1
*IF,GRID(XSHP(KSHP),J),EQ,1,THEN
UNIQ = FALS
*ENDIF
*ENDDO
*ENDIF
*DO,J,XSHP(KSHP),XSHP(KSHP)+SSHP(KSHP)-1,1
GRID(J,YSHP(KSHP)) = 1
*ENDDO
NSEL,S,LOC,X,XSHP(KSHP)-1,XSHP(KSHP)+SSHP(KSHP)-1
NSEL,R,LOC,Y,YSHP(KSHP)-1,YSHP(KSHP)
ESLN,S,1
REAL,RSHP(KSHP)
EMODIF,ALL,REAL
ALLSEL
*ELSE
*DO,J,YSHP(KSHP),YSHP(KSHP)+SSHP(KSHP)-1,1
GRID(XSHP(KSHP),J) = 1
*ENDDO
NSEL,R,LOC,Y,YSHP(KSHP)-1,YSHP(KSHP)+SSHP(KSHP)-1
ESLN,S,1
REAL,RSHP(KSHP)
EMODIF,ALL,REAL
ALLSEL
*ENDIF
KSHP = KSHP+1
*ENDDO
/PNUM,TYPE,1
/NUM,1
/PLOPTS,INFO,OFF
/PLOPTS,LOGO,OFF
/WIND,1,-1,1,-1,1
/PLOPTS,WINS,OFF
EPLOT
/TSPEC,15,0.8
/TLABEL,1.05,0.94,NAVAL BATTLE
/TLABEL,1.05,0.88,by Dave Lindeman
/TLABEL,1.05,0.76,1 BATTLESHIP - 5 HITS
/TLABEL,1.05,0.70,1 CRUISER - 4 HITS
/TLABEL,1.05,0.64,2 DESTROYERS - 3 HITS
/TLABEL,1.05,0.58,2 SUBMARINES - 2 HITS
/PSPEC,15,1,0
/POLYG,4,1.20,0.20,1.50,0.20,1.50,0.40,1.20,0.40
FCOL=NINT(RAND(1,11))
/PSPEC,FCOL,1,0
/POLYG,3,1.28,0.25,1.42,0.30,1.28,0.35
/LSPEC,13,0,2
/LINE,1.20,-0.45,1.20,0.42
/PSPEC,12,1,0
/PCIRC,1.35,-0.15,0.25
/PSPEC,15,1,0
/PCIRC,1.35,-0.15,0.20
/PSPEC,12,1,0
/PCIRC,1.35,-0.15,0.15
/PSPEC,15,1,0
/PCIRC,1.35,-0.15,0.10
/PSPEC,12,1,0
/PCIRC,1.35,-0.15,0.05
/NOER
/USER
/PNUM,REAL,1
/NUM,0
*MSG,UI
To play, simply select one or more elements at a time. %/&
Moves will not be registered until the Select elements %/&
dialog box has been closed by pressing the OK button
*GET,EMAX,ELEM,,NUM,MAX
*DIM,EPCK,ARRAY,EMAX
*DO,I,1,EMAX,1
EPCK(I) = 0
*ENDDO
DONE = FALS
*DO,I,1,999,1
ESEL,S,P
*GET,NELE,ELEM,,COUNT
ENUM = 0
*DO,J,1,NELE,1
ENUM = ELNEXT(ENUM)
*IF,EPCK(ENUM),EQ,1,CYCLE
EPCK(ENUM) = 1
NMVE = NMVE+1
*GET,RNUM,ELEM,ENUM,ATTR,REAL
*DO,K,1,NSHP,1
*IF,RNUM,EQ,RSHP(K),THEN
HSHP(K) = HSHP(K)+1
*IF,HSHP(K),EQ,SSHP(K),THEN
NSNK = NSNK+1
*IF ,SSHP(K),EQ,2,THEN
NSUB = NSUB+1
/TSPEC, 0,0.8
*IF,NSUB,EQ,1,THEN
/TLABEL,1.05,0.58,2
/TSPEC,15,0.8
/TLABEL,1.05,0.58,1
*ELSE
/TLABEL,1.05,0.58,1 SUBMARINES - 2 HITS
*ENDIF
*ELSEIF,SSHP(K),EQ,3,THEN
NDES = NDES+1
/TSPEC, 0,0.8
*IF,NDES,EQ,1,THEN
/TLABEL,1.05,0.64,2
/TSPEC,15,0.8
/TLABEL,1.05,0.64,1
*ELSE
/TLABEL,1.05,0.64,1 DESTROYERS - 3 HITS
*ENDIF
*ELSEIF,SSHP(K),EQ,4,THEN
/TSPEC, 0,0.8
*ELSEIF,SSHP(K),EQ,5,THEN
/TSPEC, 0,0.8
*ENDIF
*IF,NSNK,EQ,NSHP,THEN
DONE = TRUE
*EXIT
*ENDIF
*ENDIF
*ENDIF
*ENDDO
*ENDDO
EPLOT
*IF,DONE,EQ,TRUE,EXIT
ALLSEL
*ENDDO
/PSPEC,15,1,0
/POLYG,4,1.22,0.22,1.48,0.22,1.48,0.38,1.22,0.38
IMMED,ON
ESEL,S,REAL,,1
ENUM = 0
*DO,I,1,NELE,1
ENUM = ELNEXT(ENUM)
EPCK(ENUM) = 2
*ENDDO
ECNT = 0
*DO,I,1,999,1
ENUM = NINT(RAND(0,EMAX))
ENUM = ELNEXT(ENUM)
*IF,ENUM,EQ,0,THEN
ENUM = 1
*ENDIF
*IF,EPCK(ENUM),EQ,2,THEN
EPCK(ENUM) = 0
ECNT = ECNT+1
EDELE,ENUM
*ENDIF
*IF,ECNT,EQ,NELE,EXIT
*ENDDO
FINI
*MSG,UI,NMVE
You sunk my fleet in %I moves!
/WAIT,5
*MSG,UI
To play another game, enter /CLEAR, then /INPUT,BATTLE
/EOF
有些地方扔仍看不懂,望高手給簡單講解一下:)
[ 本帖最后由 galen_03 于 2006-6-20 15:43 编辑 ]
GMT+8, 2024-9-30 00:22 , Processed in 0.030915 second(s), 12 queries , Gzip On, MemCache On.
