- 4
- 2005-6-30
发表于 2006-7-28 10:28:33
来自 重庆大学
Modeling Using the Graphical User Interface
MODEL NAVIGATOR
1, In the Model Navigator, select 2D in the Space dimension list.
2, In the PDE Modes folder, select Weak Form, Subdomain.
3, Type psix psiy x y in the Dependent variables edit field.
4, Type mesh in the Application mode name edit field.
5, Click the Multiphysics button and then the Add Geometry button.
6, Keep the 2D space dimension and enter X Y Z as independent variables.
7. Click OK.
8. Click Add.
9. In the PDE Modes folder, select Weak Form, Subdomain.
10. Type u v p in the Dependent variables edit field.
11. Type ns in the Application mode name edit field.
12. Click Add.
13. Click OK.
帮助里的这种做法好象不可以。我这样做了,软件提示我:ERROR:9001
The dependent variable name must not be equal to an independent variable name
咋回事啊? |
