查看: 105|回复: 2
[3. Fortran] 请教关于gfortran的输出问题!
发表于 2006-8-21 22:16:54 | 显示全部楼层 |阅读模式 来自 北京
我用gfortran运行一段程序,用输出语句write(*,*)老是有问题,请高手指点!
程序如下:
    program test_sbhdl
        implicit doubleprecision (a-h,o-z)
        ! Variables
    character algorithm*3,direction*1,vc
        dimension a(6),ica(6),ira(0:4),ncqa(1,4)
        dimension ncqsub(1)
        common nout
        ! Body of test_sbhdl
    nout=20
        write(*,*)"aaa"
        open(unit=nout,file="information.txt",status="unknown",form="formatted")
        ma=6;msa=4;nsa=4;mncq=1
        a(1)=0.25d0;a(2)=-0.25d0;a(3)=0.5d0;a(4)=0.5d0;a(5)=-0.25d0;a(6)=0.25d0
        ica(1)=1;ica(2)=2;ica(3)=3;ica(4)=2;ica(5)=3;ica(6)=4
        ira(0)=0;ira(1)=1;ira(2)=3;ira(3)=5;ira(4)=6
        ncqa(1,1)=2;ncqa(1,2)=0;ncqa(1,3)=0;ncqa(1,4)=-2
        write(*,*)"bbb"
        open(unit=6,file="HBL002",status="unknown",form="unformatted")
        write(*,*)"ccc"
        write(6)ma,msa,nsa,mncq
    write(6)ncqa
        write(6)a
        write(6)ica
        write(6)ira
        close(6)
        end
其中,前两个write(*,*)可以在屏幕上打印出来,而第三个有问题。
出错信息:
At line 24 of file 666.f90
Fortran runtime error: Format present for UNFORMATTED data transfer
我文件名取的是666.f90
同样是这段程序用compag visual fortran 运行就没问题。
我想不通是什么问题,请高手指点!
 楼主| 发表于 2006-8-21 22:33:51 | 显示全部楼层 来自 北京
我把unit=6改成unit=4就没有错误了,
难道unit=6有特殊的用途?还是编译器的bug?
发表于 2006-8-22 03:09:04 | 显示全部楼层 来自 美国
Unit numbers 0, 5, and 6 are associated with the standard error, standard input (keyboard), and standard output files (screen)
GMT+8, 2024-11-1 19:27 , Processed in 0.053415 second(s), 13 queries , Gzip On, MemCache On.
