- 2006-10-23
本人做ansys半年余,求解总是不收敛,看了好长时间帖子,还是调不出来,命令流如下,请教各位大侠。
*SET,CA,150 !C型钢参数
*SET,CB,65
*SET,CC,20
*SET,CD,1.8
*SET,CR,6
*SET,BL,35 !螺栓端距
*SET,BR1,8 !螺栓半径
*SET,BR2,14 !垫片外半径
*SET,BR3,12 !螺帽半径
*SET,BR4,18 !接触区域半径
*SET,BR5,9 !螺栓孔半径
*SET,BR6,10 !垫片内半径
*SET,BH1,2 !垫片高度
*SET,BH2,6 !螺帽高度
*SET,BJ,1.2 !螺栓间距参数1.2;1.4;1.6
*SET,JPT,6 !节点板厚度
*SET,SD,10 !安装间隙
*SET,JJ,600 !支撑间距
!加载参数
*SET,PREFOR,70000!施加螺栓预应力
*SET,DISP,100 !施加位移
/PREP7
ET,1,solid45
MPTEMP,,,,,,,, !节点板
MPTEMP,1,0
mp,ex,1,176000
mp,prxy,1,0.3
tb,kinh,1,1,4
tbpt,,235/(176000),235
tbpt,,0.002,235
tbpt,,0.02,235
tbpt,,0.1,235/2
MPTEMP,,,,,,,, !C型钢
MPTEMP,1,0
mp,ex,2,176000
mp,prxy,2,0.3
tb,kinh,2,1,4
tbpt,,0.002,235
tbpt,,0.02,235
tbpt,,0.1,235/2
MPTEMP,,,,,,,, !弯角
MPTEMP,1,0
mp,ex,3,176000
mp,prxy,3,0.3
tb,kinh,3,1,4
tbpt,,235*1.2/(176000),235*1.2
tbpt,,0.1,235*1.2
tbpt,,0.02,235*1.2
tbpt,,0.1,235*1.2/2
MPTEMP,,,,,,,, !高强螺栓
MPTEMP,1,0
MPDATA,EX,4,,206000
MPDATA,PRXY,4,0.3,
TB,BKIN,4,1,2,1
TBDATA,,640,20600,,,,
MPTEMP,,,,,,,,
MPTEMP,1,0
mp,ex,5,176000
mp,prxy,5,0.3
tb,kinh,5,1,4
tbpt,,0.002,235
tbpt,,0.02,235
tbpt,,0.1,235/2
MP,MU,5,0.25 !节点板与型钢
MPTEMP,,,,,,,,
MPTEMP,1,0
mp,ex,6,176000
mp,prxy,6,0.3
tb,kinh,6,1,4
tbpt,,0.002,235
tbpt,,0.02,235
tbpt,,0.1,235/2
MP,MU,6,0.15 !螺栓与螺孔
!柱子建模
CYL4,-CA/2+CR,-JPT/2-CR,CR,90,CR-CD,180,JJ-BL
CYL4,-CA/2+CR,-JPT/2-CB+CR,CR,180,CR-CD,270,JJ-BL
CYL4,CA/2-CR,-JPT/2-CR,CR,0,CR-CD,90,JJ-BL
CYL4,CA/2-CR,-JPT/2-CB+CR,CR,270,CR-CD,360,JJ-BL
BLOCK,-CA/2+CR,CA/2-CR,-JPT/2,-JPT/2-CD,0,JJ-BL
BLOCK,-CA/2+CR,CA/2-CR,-JPT/2,-JPT/2-CD,JJ-BL,JJ+BJ*CA+BL
BLOCK,-CA/2+CR,CA/2-CR,-JPT/2,-JPT/2-CD,JJ+BJ*CA+BL,JJ+BJ*CA+JJ
BLOCK,-CA/2,-CA/2+CD,-JPT/2-CR,-JPT/2-CB+CR,0,JJ-BL
BLOCK,-CA/2,-CA/2+CD,-JPT/2-CR,-JPT/2-CB+CR,JJ-BL,JJ+BJ*CA+BL
BLOCK,-CA/2,-CA/2+CD,-JPT/2-CR,-JPT/2-CB+CR,JJ+BJ*CA+BL,JJ+BJ*CA+JJ
BLOCK,CA/2,CA/2-CD,-JPT/2-CR,-JPT/2-CB+CR,0,JJ-BL
BLOCK,CA/2,CA/2-CD,-JPT/2-CR,-JPT/2-CB+CR,JJ-BL,JJ+BJ*CA+BL
BLOCK,CA/2,CA/2-CD,-JPT/2-CR,-JPT/2-CB+CR,JJ+BJ*CA+BL,JJ+BJ*CA+JJ
BLOCK,-CA/2+CR,-CA/2+CC,-JPT/2-CB,-JPT/2-CB+CD,0,JJ-BL
BLOCK,-CA/2+CR,-CA/2+CC,-JPT/2-CB,-JPT/2-CB+CD,JJ-BL,JJ+BJ*CA+BL
BLOCK,-CA/2+CR,-CA/2+CC,-JPT/2-CB,-JPT/2-CB+CD,JJ+BJ*CA+BL,JJ+BJ*CA+JJ
BLOCK,CA/2-CR,CA/2-CC,-JPT/2-CB,-JPT/2-CB+CD,0,JJ-BL
BLOCK,CA/2-CR,CA/2-CC,-JPT/2-CB,-JPT/2-CB+CD,JJ-BL,JJ+BJ*CA+BL
BLOCK,CA/2-CR,CA/2-CC,-JPT/2-CB,-JPT/2-CB+CD,JJ+BJ*CA+BL,JJ+BJ*CA+JJ
wpoff,0,-3,JJ+BJ*CA/2
wpro,,90.000000,
wpro,,,-90.000000
wpro,90.000000,,
wpro,,90.000000,
CYL4,BJ*CA/2,CA/2-BL,BR4, , , ,CD
CYL4,BJ*CA/2,-(CA/2-BL),BR4, , , ,CD
CYL4,-BJ*CA/2,CA/2-BL,BR4, , , ,CD
CYL4,-BJ*CA/2,-(CA/2-BL),BR4, , , ,CD
FLST,2,5,6,ORDE,3
FITEM,2,6
FITEM,2,20
FITEM,2,-23
VOVLAP,P51X
CYL4,BJ*CA/2,CA/2-BL,BR5, , , ,6
CYL4,BJ*CA/2,-(CA/2-BL),BR5, , , ,6
CYL4,-BJ*CA/2,CA/2-BL,BR5, , , ,6
CYL4,-BJ*CA/2,-(CA/2-BL),BR5, , , ,6
VSBV, 21, 25
VSBV, 23, 27
VSBV, 22, 26
VSBV, 20, 6
wpro,,-90.000000,
wpro,-90.000000,,
wpro,,,90.000000
wpro,,-90.000000,
wpoff,0,JPT/2,-BJ*CA/2-BL
CYL4,-CA/2+CR,-JPT/2-CR,CR,90,CR-CD,180,BJ*CA+BL*2
CYL4,-CA/2+CR,-JPT/2-CB+CR,CR,180,CR-CD,270,BJ*CA+BL*2
CYL4,CA/2-CR,-JPT/2-CR,CR,0,CR-CD,90,BJ*CA+BL*2
CYL4,CA/2-CR,-JPT/2-CB+CR,CR,270,CR-CD,360,BJ*CA+BL*2
wpoff,0,0,BJ*CA+BL*2
ALLSEL,ALL
VGLUE,all
CM,column,VOLU
!梁建模
wpoff,0,0,-CA/2
wpro,,90.000000,
wpoff,CA/2+SD,0,0
wpro,,,-90.000000
wpro,90.000000,,
CYL4,-CA/2+CR,-JPT/2-CR,CR,90,CR-CD,180,-(BJ*CA+BL*2)
CYL4,-CA/2+CR,-JPT/2-CB+CR,CR,180,CR-CD,270,-(BJ*CA+BL*2)
CYL4,CA/2-CR,-JPT/2-CR,CR,0,CR-CD,90,-(BJ*CA+BL*2)
CYL4,CA/2-CR,-JPT/2-CB+CR,CR,270,CR-CD,360,-(BJ*CA+BL*2)
BLOCK,-CA/2+CR,CA/2-CR,-JPT/2,-JPT/2-CD,0,-(BL+BJ*CA+BL)
BLOCK,-CA/2+CR,CA/2-CR,-JPT/2,-JPT/2-CD,-(BL+BJ*CA+BL),-(JJ+BJ*CA+BL)
BLOCK,-CA/2,-CA/2+CD,-JPT/2-CR,-JPT/2-CB+CR,0,-(BL+BJ*CA+BL)
BLOCK,-CA/2,-CA/2+CD,-JPT/2-CR,-JPT/2-CB+CR,-(BL+BJ*CA+BL),-(JJ+BJ*CA+BL)
BLOCK,CA/2,CA/2-CD,-JPT/2-CR,-JPT/2-CB+CR,0,-(BL+BJ*CA+BL)
BLOCK,CA/2,CA/2-CD,-JPT/2-CR,-JPT/2-CB+CR,-(BL+BJ*CA+BL),-(JJ+BJ*CA+BL)
BLOCK,-CA/2+CR,-CA/2+CC,-JPT/2-CB,-JPT/2-CB+CD,0,-(BL+BJ*CA+BL)
BLOCK,-CA/2+CR,-CA/2+CC,-JPT/2-CB,-JPT/2-CB+CD,-(BL+BJ*CA+BL),-(JJ+BJ*CA+BL)
BLOCK,CA/2-CR,CA/2-CC,-JPT/2-CB,-JPT/2-CB+CD,0,-(BL+BJ*CA+BL)
BLOCK,CA/2-CR,CA/2-CC,-JPT/2-CB,-JPT/2-CB+CD,-(BL+BJ*CA+BL),-(JJ+BJ*CA+BL)
wpoff,0,0,-(BJ*CA+BL*2)
CYL4,-CA/2+CR,-JPT/2-CR,CR,90,CR-CD,180,-(JJ-BL)
CYL4,-CA/2+CR,-JPT/2-CB+CR,CR,180,CR-CD,270,-(JJ-BL)
CYL4,CA/2-CR,-JPT/2-CR,CR,0,CR-CD,90,-(JJ-BL)
CYL4,CA/2-CR,-JPT/2-CB+CR,CR,270,CR-CD,360,-(JJ-BL)
wpoff,0,0,(BJ*CA+BL*2)
wpoff,0,-JPT/2,-(BL+BJ*CA/2)
wpro,,90.000000,
CYL4,CA/2-BL,BJ*CA/2,BR4, , , ,CD
CYL4,-(CA/2-BL),BJ*CA/2,BR4, , , ,CD
CYL4,CA/2-BL,-BJ*CA/2,BR4, , , ,CD
CYL4,-(CA/2-BL),-BJ*CA/2,BR4, , , ,CD
FLST,2,5,6,ORDE,5
FITEM,2,9
FITEM,2,26
FITEM,2,-27
FITEM,2,29
FITEM,2,-30
VOVLAP,P51X
CYL4,CA/2-BL,BJ*CA/2,BR5, , , ,6
CYL4,-(CA/2-BL),BJ*CA/2,BR5, , , ,6
CYL4,CA/2-BL,-BJ*CA/2,BR5, , , ,6
CYL4,-(CA/2-BL),-BJ*CA/2,BR5, , , ,6
VSBV, 26, 9
VSBV, 27, 55
VSBV, 30, 57
VSBV, 29, 56
ALLSEL,ALL
CMSEL,U,COLUMN
VGLUE,ALL
CM,beam,VOLU
!节点板建模
BLOCK,-CA/2,CA/2,-BL-BJ*CA/2,BL+BJ*CA/2+SD,0,-JPT/2
BLOCK,-BJ*CA+CA/2-2*BL,CA/2,BL+BJ*CA/2+CA+SD,BL+BJ*CA/2+SD,0,-JPT/2
BLOCK,-CA/2,-BJ*CA+CA/2-2*BL,-BL-BJ*CA/2,BL+BJ*CA/2+SD,0,-JPT/2
FLST,2,4,3
FITEM,2,90
FITEM,2,97
FITEM,2,81
FITEM,2,74
A,P51X
VSBA, 12, 77
VDELE, 13, , ,1
wpoff,0,0,-JPT/2
CYL4,CA/2-BL,BJ*CA/2,BR5, , , ,JPT/2
CYL4,-(CA/2-BL),BJ*CA/2,BR5, , , ,JPT/2
CYL4,CA/2-BL,-BJ*CA/2,BR5, , , ,JPT/2
CYL4,-(CA/2-BL),-BJ*CA/2,BR5, , , ,JPT/2
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL,BR5, , , ,JPT/2
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL,BR5, , , ,JPT/2
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR5, , , ,JPT/2
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR5, , , ,JPT/2
FLST,3,4,6,ORDE,2
FITEM,3,17
FITEM,3,-20
VSBV, 11,P51X
FLST,3,4,6,ORDE,4
FITEM,3,12
FITEM,3,-13
FITEM,3,15
FITEM,3,-16
VSBV, 10,P51X
ALLSEL,ALL
CMSEL,U,COLUMN
CMSEL,U,beam
VGLUE,ALL
CM,jointplate,VOLU
!螺栓建模
VSEL,none
CYL4,CA/2-BL,BJ*CA/2,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,CA/2-BL,BJ*CA/2,BR2, , , ,BH1
CYL4,CA/2-BL,BJ*CA/2,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Bbolt1,VOLU
VSEL,none
wpoff,0,0,-(JPT/2+CD)
CYL4,-(CA/2-BL),BJ*CA/2,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,-(CA/2-BL),BJ*CA/2,BR2, , , ,BH1
CYL4,-(CA/2-BL),BJ*CA/2,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Bbolt2,VOLU
VSEL,none
CYL4,CA/2-BL,-BJ*CA/2,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,CA/2-BL,-BJ*CA/2,BR2, , , ,BH1
CYL4,CA/2-BL,-BJ*CA/2,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Bbolt3,VOLU
VSEL,none
CYL4,-(CA/2-BL),-BJ*CA/2,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,-(CA/2-BL),-BJ*CA/2,BR2, , , ,BH1
CYL4,-(CA/2-BL),-BJ*CA/2,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Bbolt4,VOLU
VSEL,none
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL,BR2, , , ,BH1
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Cbolt1,VOLU
VSEL,none
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL,BR2, , , ,BH1
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Cbolt2,VOLU
VSEL,none
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR2, , , ,BH1
CYL4,CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Cbolt3,VOLU
VSEL,none
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR1, , , ,CD+JPT/2+BH1+BH2
wpoff,0,0,CD+JPT/2
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR2, , , ,BH1
CYL4,-BJ*CA+CA/2-BL,BJ*CA/2+BL+SD+BL+CA-2*BL,BR3, , , ,BH1+BH2
VOVLAP,ALL
CM,Cbolt4,VOLU
!!回原点
WPCSYS,-1,0
!创建选择组件
CMGRP,BOLT,BBOLT1,BBOLT2,BBOLT3,BBOLT4,CBOLT1,CBOLT2,CBOLT3,CBOLT4
VSEL,none
CMSEL,S,BEAM
CMSEL,A,COLUMN
VSEL,R,LOC,Y,-JPT/2-CD,-(JPT/2-CD+CR)
CM,WANJIAO1,VOLU
VSEL,none
CMSEL,S,BEAM
CMSEL,A,COLUMN
VSEL,R,LOC,Y,-(JPT/2-CD+CB),-(JPT/2-CD-CR+CB)
CM,WANJIAO2,VOLU
CMGRP,WANJIAO,WANJIAO1,WANJIAO2,
ALLSEL,ALL
CMSEL,S,BEAM
ASLV,R
ASEL,R,LOC,X,-CA/2,CA/2+2*BL+BJ*CA+SD
ASEL,R,LOC,Y,-JPT/2,-JPT/2
ASEL,R,LOC,Z,JJ-BL,JJ+BL+BJ*CA
CM,BJ,AREA
ALLSEL,ALL
CMSEL,S,COLUMN
ASLV,R
CM,CJ,AREA
ALLSEL,ALL
CMSEL,S,jointplate
ASLV,R
ASEL,R,LOC,Y,-JPT/2
ASEL,R, , , 88
CM,JC,AREA
ALLSEL,ALL
CMSEL,S,jointplate
ASLV,R
ASEL,R,LOC,Y,-JPT/2
ASEL,R, , , 63
CM,JB,AREA
CMGRP,CCJJ,BJ,CJ
CMGRP,JJCC,JB,JC
CMSEL,S,BBOLT1
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,133
FITEM,5,-134
FITEM,5,144
FITEM,5,153
ASEL,R, , ,P51X
CM,B1,AREA
CMSEL,S,BBOLT2
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,164
FITEM,5,-165
FITEM,5,185
FITEM,5,332
ASEL,R, , ,P51X
CM,B2,AREA
CMSEL,S,BBOLT3
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,343
FITEM,5,-344
FITEM,5,348
FITEM,5,353
ASEL,R, , ,P51X
CM,B3,AREA
CMSEL,S,BBOLT4
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,364
FITEM,5,-365
FITEM,5,369
FITEM,5,374
ASEL,R, , ,P51X
CM,B4,AREA
CMSEL,S,CBOLT1
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,385
FITEM,5,-386
FITEM,5,390
FITEM,5,395
ASEL,R, , ,P51X
CM,B5,AREA
CMSEL,S,CBOLT2
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,406
FITEM,5,-407
FITEM,5,411
FITEM,5,416
ASEL,R, , ,P51X
CM,B6,AREA
CMSEL,S,CBOLT3
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,427
FITEM,5,-428
FITEM,5,432
FITEM,5,437
ASEL,R, , ,P51X
CM,B7,AREA
CMSEL,S,CBOLT4
ASLV
FLST,5,4,5,ORDE,4
FITEM,5,448
FITEM,5,-449
FITEM,5,453
FITEM,5,458
ASEL,R, , ,P51X
CM,B8,AREA
CMSEL,S,BEAM
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,4
FITEM,5,71
FITEM,5,75
FITEM,5,285
FITEM,5,-287
ASEL,R, , ,P51X
CM,C1,AREA
CMSEL,S,BEAM
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,54
FITEM,5,-55
FITEM,5,79
FITEM,5,83
FITEM,5,169
ASEL,R, , ,P51X
CM,C2,AREA
CMSEL,S,BEAM
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,89
FITEM,5,-90
FITEM,5,181
FITEM,5,-182
FITEM,5,273
ASEL,R, , ,P51X
CM,C3,AREA
CMSEL,S,BEAM
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,94
FITEM,5,-95
FITEM,5,173
FITEM,5,-174
FITEM,5,271
ASEL,R, , ,P51X
CM,C4,AREA
CMSEL,S,COLUMN
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,98
FITEM,5,102
FITEM,5,147
FITEM,5,-148
FITEM,5,149
ASEL,R, , ,P51X
CM,C5,AREA
CMSEL,S,COLUMN
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,106
FITEM,5,-107
FITEM,5,119
FITEM,5,-120
FITEM,5,135
ASEL,R, , ,P51X
CM,C6,AREA
CMSEL,S,COLUMN
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,111
FITEM,5,-112
FITEM,5,123
FITEM,5,-124
FITEM,5,139
ASEL,R, , ,P51X
CM,C7,AREA
CMSEL,S,COLUMN
CMSEL,A,JOINTPLATE
ASLV
FLST,5,5,5,ORDE,5
FITEM,5,127
FITEM,5,-128
FITEM,5,131
FITEM,5,-132
FITEM,5,137
ASEL,R, , ,P51X
CM,C8,AREA
ALLSEL,ALL
SAVE
!!!!!!!划分网格!!!!!!!
LSEL,S,LOC,Y,0
LSEL,R,radius,,BR5
LESIZE,ALL, , ,4, , , , ,1
LSEL,S,LOC,Y,-JPT/2
LSEL,R,radius,,BR4
LSEL,S,LOC,Y,-JPT/2
LSEL,R,radius,,BR5
LSEL,S,LOC,Y,-JPT/2-CD
LSEL,R,radius,,BR4
LSEL,R,radius,,BR5
LESIZE,ALL, , ,4*2, , , , ,1
LSEL,R,radius,,BR2
LSEL,R,radius,,BR1
LSEL,R,radius,,BR3
LSEL,S,LOC,Y,-JPT/2-CD-BH1
LSEL,R,radius,,BR2
LSEL,R,radius,,BR3
LSEL,R,radius,,BR1
LSEL,S,LOC,Y,-JPT/2-CD-BH1-BH2
LSEL,R,radius,,BR3
LSEL,R,radius,,BR1
LSEL,S,radius,,CR
LSEL,A,radius,,CR-CD
LESIZE,ALL, , ,3, , , , ,1
LSEL,S,length,,CB-CR*2
LSEL,A,length,,CC-CR
LESIZE,ALL,15, , , , , , ,1
LSEL,S,length,,CA-CR*2
LESIZE,ALL,12, , , , , , ,1
LSEL,S,length,,BJ*CA+2*BL
LSEL,A,length,,BJ*CA+2*BL+SD
LSEL,A,length,,CA
LSEL,A,length,,BJ*CA+2*BL-CA
LESIZE,ALL,8, , , , , , ,1
LSEL,S,length,,JPT/2
LSEL,A,length,,CD
LSEL,A,length,,BH1
LSEL,A,length,,BH2
LESIZE,ALL,2, , , , , , ,1
LSEL,S,length,,JJ-BL
LESIZE,ALL,30, , , , , , ,1
LSEL,S,LOC,Y,0,-JPT/2
LSEL,R,LOC,X,CA,CA+BJ*CA/2
LSEL,R,LOC,Z,JJ,JJ+BJ*CA-CA
ALLSEL,ALL
MOPT,QMESH,MAIN
CMSEL,S,JOINTPLATE
VATT, 1, , 1, 0
VSWEEP,ALL
VSEL,NONE
CMSEL,S,BEAM
CMSEL,A,COLUMN
CMSEL,U,WANJIAO
VATT, 2, , 1, 0
VSWEEP,ALL
VSEL,NONE
CMSEL,S,WANJIAO
VATT, 3, , 1, 0
VSWEEP,ALL
VSEL,NONE
CMSEL,S,BOLT
VATT, 4, , 1, 0
VSWEEP,ALL
!!!!!!接触建立!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!节点板与C型钢!!!!!!!
ET,3,170
ET,4,174
KEYOPT,4,7,1 !时间步长二分
KEYOPT,4,9,2
KEYOPT,4,12,2
allsel,all
mat,5
R,5,,,-2000
REAL,5
!! 建立目标面
ASEL,S,,,JJCC
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF,ALL
!!建立接触面
ASEL,S,,,CCJJ
TYPE,4
NSLA,S,1
ESLN,S,0
ESURF,ALL
ALLSEL
!!!!!!!螺栓杆与孔壁的接触!!!!!!!!!
*DO, n, 1, 8
ET,5,170
ET,6,174
KEYOPT,6,7,1
KEYOPT,6,9,2
KEYOPT,6,12,1
allsel,all
mat,6
R,%n+5%,,,-2000
REAL,%n+5%
!! 建立目标面-螺栓杆
ASEL,S,,,B%n%
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF,all
!!建立接触面-孔壁
ASEL,S,,,C%n%
TYPE,4
NSLA,S,1
ESLN,S,0
ESURF,all
*ENDDO
!!!!建立预紧单元!!!!!
/PREP7
ALLSEL,ALL
psmesh,BB1,pretens,,volu,18,0,y,0,,,,Bbolt-1
psmesh,BB2,pretens,,volu,68,0,y,0,,,,Bbolt-2
psmesh,BB3,pretens,,volu,74,0,y,0,,,,Bbolt-3
psmesh,BB4,pretens,,volu,80,0,y,0,,,,Bbolt-4
psmesh,CB1,pretens,,volu,86,0,y,0,,,,Cbolt-1
psmesh,CB2,pretens,,volu,92,0,y,0,,,,Cbolt-2
psmesh,CB3,pretens,,volu,98,0,y,0,,,,Cbolt-3
psmesh,CB4,pretens,,volu,104,0,y,0,,,,Cbolt-4
!!!!边界约束条件!!!!!!!!!!!!!!!
NSEL,ALL
NSEL,s,LOC,Z,0
D,ALL, , , , , ,UX,UY,UZ,
NSEL,ALL
NSEL,S,LOC,Z,2*JJ+BJ*CA
NSEL,S,LOC,Y,0
DSYM,SYMM,Y, ,
SAVE
ALLSEL,ALL
!!!施加预应力!!!
/SOLU
ANTYPE,0
AUTOTS,ON
NEQIT,100
NLGEOM,ON
NSUBST,1,,,1
SLOAD,ALL,9,LOCK,FORC,PREFOR, 1,2
ALLSEL,ALL
*do,n,1,2
solcontrol,on !优化非线性求解
time,n
EQSLV,PCG,1E-2,3
CNVTOL,F, ,0.05,2,0.04
LSWRITE,n
*enddo
LSSOLVE,1,2,1,
save
!!!单调荷载!!!
/solu
ANTYPE,,REST
ALLSEL,ALL
num=node(CA/2+SD+JJ+BJ*CA+BL,-JPT/2,JJ+BJ*CA-CA/2)
D,num,UZ,DISP
NSUBST,500,1000,20
allsel,all
time,3
NLGEOM,1
OUTRES,alL,1
allsel
KBC,0 !采用渐进式加载方式加载
lnsrch,off !关闭线性搜索
EQSLV,PCG,1E-2,3
LSWRITE,3,
FINISH
/SOLU
LSSOLVE,3,3,1,
上边是用solid45建的模型,由于对称性,模型只建了一半,用预紧单元给螺栓施加预应力,钢材间,螺杆螺孔间定义了接触对,柱子上下铰接,梁端施加位移。
还有一个是用shell181建的模型,螺栓使用beam4,螺栓和型钢使用combin39连接,柱子上下铰接,梁端施加位移。
两个模型都运行不出来,现求助高手帮忙。
不胜感激
*SET,CA,160!C型钢参数
*SET,CB,65
*SET,CC,20
*SET,CD,1.8
*SET,CR,6
*SET,EP,35!螺栓端距
*SET,BJ,1.25 !螺栓间距参数1.0;1.25;1.5
*SET,JPT,6 !节点板厚度
*SET,SD,10 !安装间隙
*SET,JJ,600 !支撑间距
*SET,DISP,50 !施加位移
/PREP7
ET,1,SHELL181
R,1,CD, , , , , ,
R,2,JPT, , , , , ,
ET,2,COMBIN39,,,1
R,3,0,0,0.1,5000,0.5,8000,
RMORE,1,9000,1.5,12000,3,15000,
ET,3,COMBIN39,,,2
R,4,0,0,0.1,5000,0.5,8000,
ET,4,COMBIN39,,,3
R,5,0,0,0.1,50000000,
ET,5,BEAM4
R,6,200.905,3210,3210,1000,1000, ,
RMORE, ,6421,10000,10000, , ,
!!!!!!节点板!!!!!
mp,ex,1,176000
mp,prxy,1,0.3
tb,kinh,1,1,4
tbpt,,0.002,235
tbpt,,0.02,235
tbpt,,0.1,235/2
!!!!!!C型钢!!!!!
mp,ex,2,176000
mp,prxy,2,0.3
tb,kinh,2,1,4
tbpt,,0.002,235
tbpt,,0.02,235
tbpt,,0.1,235/2
!!!!!!螺栓!!!!!!
mp,ex,3,176000
mp,prxy,3,0.3
tb,kinh,3,1,4
tbpt,,0.1,235*1.2
tbpt,,0.02,235*1.2
tbpt,,0.1,235*1.2/2
!!!!!!截面属性!!!!!!
SECTYPE,1,SHELL,RECT
SECDATA,CD,2, ,5
SECTYPE,2,SHELL,RECT
SECDATA,JPT,1, ,5
SECTYPE,3,BEAM,CSOLID
SECDATA,BR,8,4
!!!!!开始建模!!!!!!!!
K,1,-(CA-CD)/2+CC,-JPT/2-CB+CD/2,0,
K,2,-(CA-CD)/2,-JPT/2-CB+CD/2,0,
K,3,-(CA-CD)/2,-(JPT+CD)/2,0,
K,4,-(CA-CD)/2+EP,-(JPT+CD)/2,0,
K,5,(CA-CD)/2-EP,-(JPT+CD)/2,0,
k,6,(CA-CD)/2,-(JPT+CD)/2,0,
K,7,(CA-CD)/2,-JPT/2-CB+CD/2,0,
K,8,(CA-CD)/2-CC,-JPT/2-CB+CD/2,0,
K,9,(CA-CD)/2-CC,-JPT/2-CB+CD/2,BJ*CA/2,
K,10,(CA-CD)/2-CC,-JPT/2-CB+CD/2,BJ*CA/2+EP,
K,11,(CA-CD)/2-CC,-JPT/2-CB+CD/2,BJ*CA/2+EP+JJ/12,
LSTR, 1, 2
LSTR, 2, 3
LSTR, 3, 4
LSTR, 4, 5
LSTR, 5, 6
LSTR, 6, 7
LSTR, 7, 8
LSTR, 8, 9
LSTR, 9, 10
LSTR, 10, 11
LFILLT,1,2,CR-CD/2, ,
LFILLT,2,3,CR-CD/2, ,
LFILLT,5,6,CR-CD/2, ,
LFILLT,6,7,CR-CD/2, ,
LSEL,S,LOC,Z,0
ADRAG, ALL, , , , , , 8
LSEL,S,LOC,Z,BJ*CA/2
ADRAG, ALL, , , , , , 9
LSEL,S,LOC,Z,BJ*CA/2+EP
ADRAG, ALL, , , , , , 10
K,1001,CA/2+SD,-JPT/2-CB+CD/2,-(CA-CD)/2+CC+(BJ*CA-CA+CD)/2+EP,
K,1002,CA/2+SD,-JPT/2-CB+CD/2,-(CA-CD)/2+(BJ*CA-CA+CD)/2+EP,
K,1003,CA/2+SD,-(JPT+CD)/2,-(CA-CD)/2+(BJ*CA-CA+CD)/2+EP,
K,1004,CA/2+SD,-(JPT+CD)/2,-(CA-CD)/2+EP+(BJ*CA-CA+CD)/2+EP,
K,1005,CA/2+SD,-(JPT+CD)/2,(CA-CD)/2-EP+(BJ*CA-CA+CD)/2+EP,
k,1006,CA/2+SD,-(JPT+CD)/2,(CA-CD)/2+(BJ*CA-CA+CD)/2+EP,
K,1007,CA/2+SD,-JPT/2-CB+CD/2,(CA-CD)/2+(BJ*CA-CA+CD)/2+EP,
K,1008,CA/2+SD,-JPT/2-CB+CD/2,(CA-CD)/2-CC+(BJ*CA-CA+CD)/2+EP,
K,1009,CA/2+SD+EP,-JPT/2-CB+CD/2,(CA-CD)/2-CC+(BJ*CA-CA+CD)/2+EP,
K,1010,CA/2+SD+BJ*CA+EP,-JPT/2-CB+CD/2,(CA-CD)/2-CC+(BJ*CA-CA+CD)/2+EP,
K,1011,CA/2+SD+BJ*CA+EP+JJ/12,-JPT/2-CB+CD/2,(CA-CD)/2-CC+(BJ*CA-CA+CD)/2+EP,
LSTR, 1001, 1002
LSTR, 1002, 1003
LSTR, 1003, 1004
LSTR, 1004, 1005
LSTR, 1005, 1006
LSTR, 1006, 1007
LSTR, 1007, 1008
LSTR, 1008, 1009
LSTR, 1009, 1010
LSTR, 1010, 1011
LFILLT,84,85,CR-CD/2, ,
LFILLT,85,86,CR-CD/2, ,
LFILLT,88,89,CR-CD/2, ,
LFILLT,89,90,CR-CD/2, ,
LSEL,S,LOC,X,CA/2+SD
ADRAG, ALL, , , , , , 91
LSEL,S,LOC,X,CA/2+SD+EP
ADRAG, ALL, , , , , , 92
LSEL,S,LOC,X,CA/2+SD+BJ*CA+EP
ADRAG, ALL, , , , , , 93
ASEL,S,LOC,Z,BJ*CA/2+EP,BJ*CA/2+EP+JJ/12
AGEN,12,ALL, , , , ,JJ/12 , ,0
ASEL,S,LOC,X,CA/2+SD+BJ*CA+EP,CA/2+SD+BJ*CA+EP+JJ/12
AGEN,12,ALL, , ,JJ/12, , , ,0
ASEL,S,LOC,X,-CA/2,CA/2
ARSYM,Z,ALL,
ASEL,ALL
ARSYM,Y,ALL
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
K,2000,CA/2+SD+2*EP+BJ*CA,0,BJ*CA/2-CA+CD+EP,
wpro,,90.000000,
RECTNG,-(CA-CD)/2,(CA-CD)/2,BJ*CA/2+EP,-BJ*CA/2-EP,
RECTNG,(CA-CD)/2,CA/2+SD+2*EP+BJ*CA,BJ*CA/2+EP,BJ*CA/2-CA+CD+EP+EP,
A,1888,1891,1892,2000
RECTNG,-(CA-CD)/2+EP,(CA-CD)/2-EP,BJ*CA/2,-BJ*CA/2,
RECTNG,CA/2+SD+EP,CA/2+SD+EP+BJ*CA,BJ*CA/2,BJ*CA/2-CA+CD+EP+EP,
ASEL,S,LOC,Y,0
AOVLAPE,ALL
alls
lsla
lsel,invert
ldele,all
ALLS
KSLL
KSEL,INVERT
KDELE,ALL
ALLSEL,ALL
NUMMRG,KP,0.1,0.1, ,LOW
!!!!!!!创建实体组件!!!!!!!!!!!!
ASEL,S,LOC,Y,0
CM,JP,AREA
ASEL,S,LOC,Y,-JPT/2,-JPT/2-CB
CM,COLUMN1,AREA
ASEL,S,LOC,Y,JPT/2,JPT/2+CB
CM,COLUMN2,AREA
ASEL,R,LOC,X,CA/2+SD,CA/2+SD+BJ*CA+EP+JJ
CM,BEAM1,AREA
CM,BEAM2,AREA
ASEL,S,LOC,Y,JPT/2+CD,JPT/2+CD+CR
ASEL,A,LOC,Y,-(JPT/2+CD),-(JPT/2+CD+CR)
ASEL,A,LOC,Y,JPT/2-CD+CB,JPT/2-CD-CR+CB
ASEL,A,LOC,Y,-(JPT/2-CD+CB),-(JPT/2-CD-CR+CB)
CM,CORNER,AREA
!!!!!!!划分网格!!!!!!!
LSEL,S,radius,,CR-CD/2
LSEL,S,length,,EP
LSEL,A,length,,EP-CR+CD/2
LESIZE,ALL, , ,2, , , , ,1
LSEL,S,length,,CB-CD-2*(CR-CD/2)
LSEL,A,length,,CC-CR+CD/2
LSEL,A,length,,CA-2*EP-CD
LSEL,A,length,,BJ*CA/2
LSEL,S,length,,JJ/12
LESIZE,ALL, , ,1, , , , ,1
LSEL,S,length,,BJ*CA+2*EP
LSEL,A,length,,CA-CD
LSEL,A,length,,CD/2+SD+EP
LSEL,A,length,,CD/2+SD+EP+BJ*CA+EP
LSEL,A,length,,EP
LSEL,A,length,,CA-EP-CD
LSEL,A,length,,BJ*CA+2*EP-(CA-EP-CD)
LSEL,S,LOC,Y,0
LSEL,R,LOC,Z,-BJ*CA+EP/2,-BJ*CA+CA
LESIZE,ALL, , ,20 , , , , ,1
ASEL,NONE
CMSEL,S,JP
AATT,1,2,1,,2
AMESH,ALL
ASEL,NONE
CMSEL,S,COLUMN1
CMSEL,A,COLUMN2
CMSEL,A,BEAM1
CMSEL,A,BEAM2
CMSEL,U,CORNER
AATT,2,1,1,,1
AMESH,ALL
ASEL,NONE
CMSEL,S,CORNER
AATT,3,1,1,,1
AMESH,ALL
ALLSEL,ALL
NUMMRG,NODE,0.1,0.1, ,LOW
NUMCMP,ALL
!!!!!!!!建立弹簧单元!!!!!!!!!
BN11=node(-(CA-CD)/2+EP,(JPT+CD)/2,BJ*CA/2)
BN21=node(-(CA-CD)/2+EP,(JPT+CD)/2,-BJ*CA/2)
BN31=node((CA-CD)/2-EP,(JPT+CD)/2,BJ*CA/2)
BN41=node((CA-CD)/2-EP,(JPT+CD)/2,-BJ*CA/2)
BN51=node(CA/2+SD+EP,(JPT+CD)/2,BJ*CA/2)
BN61=node(CA/2+SD+EP,(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP)
BN71=node(CA/2+SD+EP+BJ*CA,(JPT+CD)/2,BJ*CA/2)
BN81=node(CA/2+SD+EP+BJ*CA,(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP)
BN12=node(-(CA-CD)/2+EP,0,BJ*CA/2)
BN22=node(-(CA-CD)/2+EP,0,-BJ*CA/2)
BN32=node((CA-CD)/2-EP,0,BJ*CA/2)
BN42=node((CA-CD)/2-EP,0,-BJ*CA/2)
BN52=node(CA/2+SD+EP,0,BJ*CA/2)
BN62=node(CA/2+SD+EP,0,BJ*CA/2-CA+CD+EP+EP)
BN72=node(CA/2+SD+EP+BJ*CA,0,BJ*CA/2)
BN82=node(CA/2+SD+EP+BJ*CA,0,BJ*CA/2-CA+CD+EP+EP)
BN13=node(-(CA-CD)/2+EP,-(JPT+CD)/2,BJ*CA/2)
BN23=node(-(CA-CD)/2+EP,-(JPT+CD)/2,-BJ*CA/2)
BN33=node((CA-CD)/2-EP,-(JPT+CD)/2,BJ*CA/2)
BN43=node((CA-CD)/2-EP,-(JPT+CD)/2,-BJ*CA/2)
BN53=node(CA/2+SD+EP,-(JPT+CD)/2,BJ*CA/2)
BN63=node(CA/2+SD+EP,-(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP)
BN73=node(CA/2+SD+EP+BJ*CA,-(JPT+CD)/2,BJ*CA/2)
BN83=node(CA/2+SD+EP+BJ*CA,-(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP)
N,10011,-(CA-CD)/2+EP,(JPT+CD)/2,BJ*CA/2,,,,
N,10021,-(CA-CD)/2+EP,(JPT+CD)/2,-BJ*CA/2,,,,
N,10031,(CA-CD)/2-EP,(JPT+CD)/2,BJ*CA/2,,,,
N,10041,(CA-CD)/2-EP,(JPT+CD)/2,-BJ*CA/2,,,,
N,10051,CA/2+SD+EP,(JPT+CD)/2,BJ*CA/2,,,,
N,10061,CA/2+SD+EP,(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP,,,,
N,10071,CA/2+SD+EP+BJ*CA,(JPT+CD)/2,BJ*CA/2,,,,
N,10081,CA/2+SD+EP+BJ*CA,(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP,,,,
N,10012,-(CA-CD)/2+EP,0,BJ*CA/2,,,,
N,10022,-(CA-CD)/2+EP,0,-BJ*CA/2,,,,
N,10032,(CA-CD)/2-EP,0,BJ*CA/2,,,,
N,10042,(CA-CD)/2-EP,0,-BJ*CA/2,,,,
N,10052,CA/2+SD+EP,0,BJ*CA/2,,,,
N,10062,CA/2+SD+EP,0,BJ*CA/2-CA+CD+EP+EP,,,,
N,10072,CA/2+SD+EP+BJ*CA,0,BJ*CA/2,,,,
N,10082,CA/2+SD+EP+BJ*CA,0,BJ*CA/2-CA+CD+EP+EP,,,,
N,10013,-(CA-CD)/2+EP,-(JPT+CD)/2,BJ*CA/2,,,,
N,10023,-(CA-CD)/2+EP,-(JPT+CD)/2,-BJ*CA/2,,,,
N,10033,(CA-CD)/2-EP,-(JPT+CD)/2,BJ*CA/2,,,,
N,10043,(CA-CD)/2-EP,-(JPT+CD)/2,-BJ*CA/2,,,,
N,10053,CA/2+SD+EP,-(JPT+CD)/2,BJ*CA/2,,,,
N,10063,CA/2+SD+EP,-(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP,,,,
N,10073,CA/2+SD+EP+BJ*CA,-(JPT+CD)/2,BJ*CA/2,,,,
N,10083,CA/2+SD+EP+BJ*CA,-(JPT+CD)/2,BJ*CA/2-CA+CD+EP+EP,,,,
*DO, m, 1, 3
*DO, n, 1, 8
TYPE,2
MAT,3
REAL,3
SECNUM,3
TSHAP,LINE
E,BN%n%%m%,100%n%%m%
*ENDDO
*ENDDO
*DO, m, 1, 3
*DO, n, 1, 8
TYPE,3
MAT,3
REAL,4
SECNUM,3
TSHAP,LINE
*ENDDO
*ENDDO
*DO, m, 1, 3
*DO, n, 1, 8
TYPE,4
MAT,3
REAL,5
SECNUM,3
TSHAP,LINE
*ENDDO
*ENDDO
*DO, n, 1, 8
*DO, m, 1, 2
TYPE,5
MAT,3
REAL,6
SECNUM,3
TSHAP,LINE
E,100%n%%m%,100%n%%m+1%
*ENDDO
*ENDDO
NSEL,ALL
NSEL,s,LOC,Z,-(JJ+BJ*CA/2+EP)
D,ALL,ALL,0,
NSEL,ALL
NSEL,S,LOC,Z,JJ+BJ*CA/2+EP
D,ALL,ALL,0,
NSEL,ALL
NSEL,S,LOC,X,CA/2+SD+EP+BJ*CA+JJ
D,ALL,UY,0,
NSEL,NONE
*DO, n, 1, 8
*DO, m, 1, 3
NSEL,A, , , 100%n%%m%
*ENDDO
*ENDDO
D,ALL, ,0, , , ,ROTX,ROTY,ROTZ, , ,
NSEL,NONE
*DO, n, 1, 8
*DO, m, 1, 3
NSEL,A, , , BN%n%%m%
*ENDDO
*ENDDO
SAVE
FINISH
ALLSEL,ALL
/SOLU
ANTYPE,0
AUTOTS,ON
NEQIT,200
NLGEOM,ON
NSUBST,500,1000,20
time,10
OUTRES,ALL,ALL
num1=node(CA/2+SD+EP+BJ*CA+JJ,-(JPT+CD)/2,0)
num2=node(CA/2+SD+EP+BJ*CA+JJ,(JPT+CD)/2,0)
D,num1,UZ,DISP
D,num2,UZ,DISP
KBC,0 !采用渐进式加载方式加载
lnsrch,ON !关闭线性搜索
EQSLV,PCG,1E-2,1
ALLSEL,ALL
SOLVE
其实实际的试验模型很简单,就是两个C型钢背靠背,中间夹一块钢板,用高强螺栓连起来,柱子两端固定后,两端加反复荷载。加载时,在平面内,型钢,钢板,螺栓都承受剪力。型钢和螺栓,型钢和钢板之间有摩擦。不知道ansys能不能解之类问题。
国外有类似的研究,用的是shell(壳)单元,beam(梁)单元,spring(弹簧)单元建模,将接触、摩擦都简化为弹簧的性质。
这种连接的接触状态比较复杂,在荷载较小的时候,剪力由预紧螺栓的摩擦力承受,力增大后,螺栓和型钢间出现滑移,待螺杆和孔壁接触后,螺栓既受剪力,又受孔壁的压力。共三种状态。再加上材料非线性,几何非线性,问题就更加复杂。
所以我现在倾向于使用shell单元,不使用接触,将接触状态的非线性直接定义为combin(弹簧)单元的属性。
这个shell模型估计还是自由度的问题,combin和beam能不能连接,怎么连接,需不需要偶合? |
