- 2006-11-20
请问,做压电分析时如何添加边界条件呢?
/clear
/title,Model of Cantilever
/PREP7
/GRAPHICS,FULL
!############################## parameter ##############################
tstep=2*1E-6 ! 加工技术步长
ch=1E-6
*SET,t_Si , 8.0*ch ! Thickness of Si
*SET,t_SiO2 , 0.8*ch ! Thickness of SiO2
*SET,t_pt1 , 0.2*ch ! Thickness of up-pt
*SET,t_PZt , 0.75*ch ! Thickness of pzt
*SET,t_pt2 , 0.15*ch ! Thickness of down-pt
BTOL,10E-4
VOL=0
VOH=10
!############################## Material property #############################
!********************** 1---Si **********************
ET,1,SOLID45 ! 用于硅薄膜层的8节点立方单元类型具有(UX,UY,UZ)的自由度 (solid 45)
MP,EX,1,1.2e11
MP,PRXY,1,0.42
MP,DENS,1,2329
R,1,t_Si
!********************** 2---SiO2 **********************
ET,2,SOLID45
MP,EX,2,0.72e11
MP,PRXY,2,0.17
MP,DENS,2,2200
R,2,t_SiO2
!********************** 3---pt **********************
ET,3,SOLID45
MP,EX,3,1.7e11
MP,PRXY,3,0.39
MP,DENS,3,21450
R,3,t_pt1
!********************** 4---PZT **********************
ET,4,SOLID226,1001
MP,EX,4,0.75e11
MP,PRXY,4,0.31
MP,DENS,4,7500
R,4,t_pzt
MP,PERX,4,804.6 ! Permittivity of piezoceramic (压电陶瓷的介电常数)
MP,PERY,4,804.6
MP,PERZ,4,659.7
TB,PIEZ,4
TBDATA,3,-5.2 !(给当前数据表定义数据)
TBDATA,6,-5.2
TBDATA,9,15.1
TBDATA,14,12.7
TBDATA,16,12.7
!********************** 5---pt **********************
ET,5,SOLID45
MP,EX,5,1.7e11
MP,PRXY,5,0.39
MP,DENS,5,21450
R,5,t_pt2
!********************** end **********************
!下面定义几何模型参数和建立几何模型
!********************** 1--Si **********************
NUMSTR,KP,1
NUMSTR,LINE,1
NUMSTR,AREA,1
k,1,100*ch,0,0
k,2,100*ch,-25*ch,0
k,3,200*ch,-25*ch,0
k,4,200*ch,-75*ch,0
k,5,100*ch,-75*ch,0
k,6,100*ch,-100*ch,0
k,7,50*ch,-100*ch,0
k,8,50*ch,-600*ch,0
ksymm,1,1,8
a,1,2,3,4,5,6,7,8,16,15,14,13,12,11,10,9
VOFFST,1,-t_Si
!********************** 2--SiO2 **********************
WPOFFS,0,0,t_Si
AGEN,2,2,,,,,,,,
VOFFST,19,-t_SiO2
!********************** 3--pt1 **********************
WPOFFS,0,0,t_SiO2
AGEN,2,20,,,,,,,,
VOFFST,37,-t_pt1
!********************** 4--PZT **********************
WPOFFS,0,0,t_pt1
AGEN,2,38,,,,,,,,
VOFFST,55,-t_PZt
!********************** 5--pt2 **********************
WPOFFS,0,0,t_PZt
AGEN,2,56,,,,,,,,
VOFFST,73,-t_pt2
WPAVE,0,0,0 !工作平面回到原始位置
WPSTYLE,,,,,,,,0 !不显示工作平面
vglue,all
NUMCMP,all
/VIEW,1,1,1,1 ! 变换视角
/AUTO,1 ! 自动适应窗口大小
/TRIAD,OFF ! 关闭坐标系显示
VPLOT
!**************************************** 划分网格 ********************************************************
/COM, ! 对于四种材料网格剖分
ESIZE,5*tstep ! 设置单元尺寸
/COM, ! 压电层与硅膜层耦合网格剖分
VSEL,S,LOC,Z,t_Si+t_SiO2+t_pt1 ,t_Si+t_SiO2+t_pt1+t_pzt ! 选择压电层体
CM,v_pzt,VOLU ! 定义压电层为一个组,名字为v_pzt
VATT,4,4,4 ! 定义压电层材料类型及单元类型
VSEL,S,LOC,Z,0,t_Si ! 选择硅膜层体
CM,v_si,VOLU ! 定义硅膜层为一个组,名字为v_si
VATT,1,1,1 ! (定义体的属性)定义压电层材料类型及单元类型 (VATTT, MAT, REAL, TYPE, ESYS)
VSEL,S,LOC,Z,t_Si,t_Si+t_SiO2 ! 选择二氧化硅膜层体
CM,v_SiO2,VOLU ! 定义二氧化硅膜层为一个组,名字为v_SiO2
VATT,2,2,2 ! (定义体的属性)定义二氧化硅材料类型及单元类型
VSEL,S,LOC,Z,t_Si+t_SiO2,t_Si+t_SiO2+t_pt1 ! 选择下电极层体
CM,v_pt1,VOLU ! 定义下电极层为一个组,名字为v_SiO2
VATT,3,3,3 ! (定义体的属性)定义pt1材料类型及单元类型
VSEL,S,LOC,Z,t_Si+t_SiO2+t_pt1+t_pzt,t_Si+t_SiO2+t_pt1+t_pzt+t_pt2 ! 选择上电极层体
CM,v_pt2,VOLU ! 定义上电极层为一个组,名字为v_pt2
VATT,5,5,5 ! 定义pt2层材料类型及单元类型
CMSEL,all,volum ! 添加选中压电层 (CMSEL,Type, Name, Entity 选择元素和集合的子集,a表示添加)
VSWEEP,ALL ! (体扫掠生成单元)对选中体划分网格(VSWEEP, VNUM, SRCA, TRGA, LSMO,含义:从邻近的面穿过体通过扫掠的方法填充没划分网格的体)
/COM, ! 下电极网格划分及节点组件定义
ASEL,S,,,19 ! 选择下电极层
nsla,s,1
CM,bot_elec,NODE ! 定义下电极节点组件
CP,1,VOLT,ALL ! 耦合电压自由度在下电极面
*GET,nel1,NODE,0,NUM,MIN ! 获得所选节点的最低节点序号赋值给nel1变量
ASEL,S,,,22 ! 选择上电极层
nsla,s,1
CM,top_elec,NODE ! 定义下电极节点组件
CP,2,VOLT,ALL ! 耦合电压自由度在上电极面 (2为耦合组编号)
*GET,nel2,NODE,0,NUM,MIN ! 获得所选节点的最低节点序号赋值给nel2变量
ALLSEL ! 选择所有实体
FINISH ! 退出当前处理器
!**************************************** 定义边界条件 *************************************************
!**************************************** boundary condition *************************************************
ASEL,S,LOC,Y,O !面 0
ASEL,S,LOC,X,200E-6 !面1
ASEL,R,LOC,Y,-25E-6,O
ASEL,S,LOC,X,-200E-6 !对称面1
ASEL,S,LOC,Y,-25E-6 !面2
ASEL,R,LOC,X,100E-6,200E-6
ASEL,S,LOC,Y,-25E-6 !对称面2
ASEL,R,LOC,X,-100E-6,-200E-6
ASEL,S,LOC,X,200E-6 !面3
ASEL,R,LOC,Y,-75E-6,-25E-6
ASEL,S,LOC,X,-200E-6 !对称面3
ASEL,S,LOC,Y,-75E-6 !面4
ASEL,R,LOC,X,-200E-6,-100E-6
ASEL,S,LOC,Y,-75E-6 !对称面4
ASEL,S,LOC,X,100E-6 !面5
ASEL,R,LOC,Y,-100E-6,-75E-6
ASEL,S,LOC,X,-100E-6 !对称面5
ASEL,S,LOC,Y,-100E-6 !面6
ASEL,R,LOC,X,50E-6,100E-6
ASEL,S,LOC,Y,-100E-6 !对称面6
ASEL,R,LOC,X,-100E-6,-50E-6
DA,AREA,ALL
DALIST,Area !列表显示面上的DOF约束
ALLSEL,ALL
FINISH
!******************************************* 求解 ***********************************************
/solu
antype,static
ALLS
d,bot_elec,volt,VOL
d,top_elec,volt,VOH
time,1
nsubst,5 !子步数为5
outres,all,all !输出数据库选项
kbc,0 !设置载荷变化方式
nsel,all !选择节点
esel,all !选择元素
save
solve
finish
/POST1 ! 进入通用后处理器
/TITLE,Electric potential distribution in model for static voltage of 10V !定义标题(Z方向位移)
PLNSOL,VOLT ! 显示电压分布云图
/WAIT,10 ! 延时10S
/TITLE,Vertical displacements in the piezo micropump. !定义标题(Z方向位移)
PLNSOL,U,Z ! 显示Z方向位移云图
FINISH ! 退出当前处理器
这是我的命令流,哪位能帮我看看哪个地方出现问题了呢?小弟感激不尽.期待您的解答. |
