查看: 146|回复: 3
【分享】an excellent ansys website
发表于 2007-3-23 04:56:05 | 显示全部楼层 |阅读模式 来自 英国
The following website gives many example problems in both GUI and command line.
http://www.mece.ualberta.ca/tutorials/ansys/
The web site has been organized into six sections
  • ANSYS Utilities
    An introduction to using ANSYS. This includes a quick explanation of the stages of analysis, how to start ANSYS, the use of the windows in ANSYS, convergence testing, saving/restoring jobs, and working with Pro/E.
  • Basic Tutorials
    Detailed tutorials outlining basic structural analysis using ANSYS. It is recommended that you complete these tutorials in order as each tutorial builds upon skills taught in previous examples.
  • Intermediate Tutorials
    Complex skills such as dynamic analysis and nonlinearities are explored in this section. It is recommended that you have completed the Basic Tutorials prior to attempting these tutorials.
  • Advanced Tutorials
    Advanced skills such as substructuring and optimization are explored in this section. It is recommended that you have completed the Basic Tutorials prior to attempting these tutorials.
  • Postprocessing Tutorials
    Postprocessing tools available in ANSYS such as X-sectional views of the geometry are shown in this section. It is recommended that you have completed the Basic Tutorials prior to attempting these tutorials.
  • Command Line Files
    Example problems solved using command line coding only, in addition to several files to help you to generate your own command line files.
I personally find they are very helpful.
发表于 2007-4-3 12:10:21 | 显示全部楼层 来自 加拿大
It is indeed excellent website!
Thanks a lot.
发表于 2007-4-4 10:17:24 | 显示全部楼层 来自 河南郑州
去看看,希望有关于优化方面的例子!
发表于 2007-4-4 11:20:09 | 显示全部楼层 来自 加拿大
原帖由 stardreams 于 2007-3-23 04:56 发表
ANSYS Utili ...
更好的是不会贴出来的,^_^!
GMT+8, 2024-9-30 01:44 , Processed in 0.031333 second(s), 10 queries , Gzip On, MemCache On.
