- 39
- 2006-1-20
发表于 2007-6-14 09:39:24
来自 黑龙江哈尔滨
有可能是shear locking or volumetric locking。
To alleviate this problem it is wise to choose elements with midside nodes or changing the element formulation.
Using the 18x series is highly recommended. These elements have five different forumulations available, B-Bar(default for low order elements), URI (default for highorder elements), Enhanced Strain, Simplified Enhanced Strain, andMixed u-P.
为减小volumetric locking consider using Mixed u-P formulation (where ‘u’ represents displacements
and ‘P’ represents hydrostatic stresses or pressures), so that hydrostatic pressures are calculated as a degree of freedom, rather than
being a derived quantity. You may also consider the other element formulations, with them each having pros and cons.
By: Professor F. E. Jargon |
