- 2007-9-10
楼主 |
发表于 2008-1-8 09:57:36
来自 浙江杭州
贴两张大脑建模图
贴两张用Simpleware建模的大脑图片 供参考
Simpleware ---software solutions are based on a core image processing platform,
ScanIP, with optional bolt-on modules for FE/CFD mesh generation and CAD
integration:
*ScanIP Software - Image processing and STL generation*
ScanIP offers an extensive selection of image processing tools for
visualizing, segmenting and manipulating regions of interest. Segmented
images can be exported as STL files for CAD analysis, RP manufacturing
or, with the +ScanFE module, imported directly into leading commercial
Finite Element packages.
*+ScanFE Module - Volume and surface mesh generation*
+ScanFE generates volume and/or surface meshes, contact surfaces and
material properties from segmented data. These high quality meshes can
be directly imported into a range of commercial FE and CFD packages.
*+ScanCAD Module - Integration of CAD Models within Image Data*
+ScanCAD allows the import and interactive positioning of CAD models
within the image data. The resulting combined models can then be
exported as multi-part STL models or, using +ScanFE, converted
automatically into multi-part Finite Element or CFD meshes. |
