- 2009-5-10
错误问题:1.MinMax does not accept 'boolean' signals. The input and output signal(s) of 'xuanjia4/Fuzzy Logic Controller/FIS Wizard/Defuzzification1/Max (COA)' must be one of the MATLAB 'uint8', 'uint16', 'uint32', 'int8', 'int16', 'int32', 'single', or 'double' data types, or one of the Fixed-point data type
2、An error occurred while propagating data type 'boolean' from 'xuanjia4/Fuzzy Logic Controller/FIS Wizard/Defuzzification1/Zero Strength (COA)', output port 1
我用的7.0,按照下面操作步骤做错误更多!
在Simulation-》Configuration Parameters中找到Implement logic signals as boolean data
请高手指点!!!!!!1 |
