- 2010-5-7
我做了一个比较复杂的模型,计算结果的错误文件里面是这样的
没有错误
但是没有计算结果生成,各位大侠能帮我看看大概哪里出了问题吗
DATE :07-06-10 TIME :12:04:26
%W-P1023229-NAS_PUT_SET1_ON_NIF,,,
SET1 (ID = 8) - Not referenced by any other entry
%W-P2141407-P2_CALC_GAS_CONST,,,
The specific heat has not been specfied, or cannot
be calculated for material 4 . As a result, editing of
temperature for elements and heat transfer calculations concerning this
material is not possible.
%I-P2022803-P2XXTXIX_SET_GLOBAL_DEFAULT,,,
No minimum time step defined , so 10% of initial time step will be used
%E-P3116501-V3_REVERSE_POLYH_V3,,,
A side of a face in surface SURFACE1 has no other faces attached.
This indicates a hole in the surface.
NO MORE MESSAGES OF THIS KIND WILL BE WRITTEN
%E-P3116502-V3_REVERSE_POLYH_V3,,,
Program error:
Inconsistent sorting of faces of COUPLING surface SURFACE1
Program error:
Program error:
Program error:
Program error:
%I-P3017601-P3_RESET_EUL_POL,,,
Reversing all faces in surface SURFACE1 ( 192 ), to get a
positive surface volume
%W-P3002401-P3_CHECK_POLYH_SURF_VOL,,,
The projection of the area of surface SURFACE1 is not consistent.
The area on the x-plane is -0.28000E+05
The area on the y-plane is 0.19600E+05
The area on the z-plane is 0.28000E+05
The surface is most probably not closed.
%W-P3002402-P3_CHECK_POLYH_SURF_VOL,,,(05),
VOLUME OF POLYHEDRON ,SURFACE1, CANNOT BE COMPUTED CONSISTENTLY
BASED ON X-PLANE ,VOLUME IS 0.00000E+00
BASED ON Y-PLANE ,VOLUME IS -0.49000E+06
BASED ON Z-PLANE ,VOLUME IS 0.98000E+06
SURFACE IS PROBABLY NOT CLOSED.
%I-P3002404-P3_CHECK_POLYH_SURF_VOL,,,
Area of surface SURFACE1 is 0.43599E+05
%I-P4024001-P4_SET_EUL_POLYH_TOLS,,,
The general coupling will use the following tolerances:
Relative tolerance for lengths : 0.100E-13
Relative tolerance for gradients : 0.100E-13
%W-P4023706-P4_PROC_1_EULER_INFACE_CELL,,,
Illegal coverage of face (4) of Euler element 146 by surface
1. Covered face area is -0.10179E+03.
Total face area is 0.21875E+03
Check Current Geometry.
%W-P4023702-P4_PROC_1_EULER_INFACE_CELL,,,
Intersection volume for Euler element 154 by surface 1
is more than cell volume
Cell volume is 0.31250E+04, intersection volume is 0.46062E+04
%W-P4023707-P4_PROC_1_EULER_INFACE_CELL,,,
Illegal coverage of face (5) of Euler element 215 by surface
1. Covered face area is -0.35714E+02.
Total face area is 0.25000E+03
%W-P4023708-P4_PROC_1_EULER_INFACE_CELL,,,
Illegal coverage of face (6) of Euler element 498 by surface
1. Covered face area is -0.15944E+01.
Total face area is 0.17857E+03
%I-P3044801-P3_WRITE_RBE2_SUMMARY,,,
For a comlete MATRIG-RBE2 summary including a list of grid points for
each assembly, please use PARAM,RBE2INFO,GRIDON |
