- 2009-7-21
msg 文件出现这个错误***ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT
什么问题呢
下面是MSG中的警告信息,请问如何解决
***WARNING: THE SYSTEM MATRIX HAS 21 NEGATIVE EIGENVALUES.
IN AN EIGENVALUE EXTRACTION STEP THE NUMBER OF NEGATIVE EIGENVALUES IS
EQUAL TO THE NUMBER OF EIGENVALUES BELOW THE CURRENT SHIFT POINT.
THIS MAY BE USED TO CHECK THAT EIGENVALUES HAVE NOT BEEN MISSED.
NOTE: THE LANCZOS EIGENSOLVER APPLIES AN INTERNAL SHIFT WHICH WILL
RESULT IN NEGATIVE EIGENVALUES.
IN A DIRECT-SOLUTION STEADY-STATE DYNAMIC ANALYSIS, NEGATIVE
EIGENVALUES ARE EXPECTED. A STATIC ANALYSIS CAN BE USED TO VERIFY THAT THE SYSTEM IS STABLE.
IN OTHER CASES, NEGATIVE EIGENVALUES MEAN THAT THE SYSTEM MATRIX IS NOT
POSITIVE DEFINITE:
FOR EXAMPLE, A BIFURCATION (BUCKLING) LOAD MAY HAVE BEEN EXCEEDED.
NEGATIVE EIGENVALUES MAY ALSO OCCUR IF QUADRATIC ELEMENTS ARE
USED TO DEFINE CONTACT SURFACES.
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74600 IS OVERCLOSED BY 3.93186
WHICH IS TOO SEVERE.
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74614 IS OVERCLOSED BY 3.07369
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74963 IS OVERCLOSED BY 3.748
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 76600 IS OVERCLOSED BY 3.07018
***NOTE: SEVERE CONTACT OVERCLOSURES EXIST. CONVERGENCE IS JUDGED UNLIKELY.
INCREMENT 1 STARTS. ATTEMPT NUMBER 2, TIME INCREMENT 2.500E-02
***WARNING: THE SYSTEM MATRIX HAS 24 NEGATIVE EIGENVALUES.
EXPLANATIONS ARE SUGGESTED AFTER THE FIRST OCCURRENCE OF THIS MESSAGE.
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74600 IS OVERCLOSED BY 3.79578
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74963 IS OVERCLOSED BY 3.61586
INCREMENT 1 STARTS. ATTEMPT NUMBER 3, TIME INCREMENT 6.250E-03
***WARNING: THE SYSTEM MATRIX HAS 22 NEGATIVE EIGENVALUES.
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74600 IS OVERCLOSED BY 3.75872
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74963 IS OVERCLOSED BY 3.58018
INCREMENT 1 STARTS. ATTEMPT NUMBER 4, TIME INCREMENT 1.563E-03
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74600 IS OVERCLOSED BY 3.72376
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74963 IS OVERCLOSED BY 3.54738
INCREMENT 1 STARTS. ATTEMPT NUMBER 5, TIME INCREMENT 3.906E-04
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74600 IS OVERCLOSED BY 3.64151
CONTACT PAIR (SURF-CONTACT-TRD,SDRUM) NODE 74963 IS OVERCLOSED BY 3.46982
***ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT |
