查看: 116|回复: 3
optistruct运行错误?错误提示如下!
发表于 2011-1-13 08:36:14 | 显示全部楼层 |阅读模式 来自 吉林长春
**                          OptiStruct 10.0                           **
**                  Design and Optimization Software                  **
**                   from Altair Engineering, Inc.                    **
**     Windows XP Professional  SP3 (Build 2600)  PC2010121013DDB     **
**        2 CPU:  Pentium(R) Dual-Core  CPU  E6500  @ 2.93GHz         **
**                        CPU speed  2950 MHz                         **
**                     994 MB RAM,  3938 MB swap                      **
** Build tag: 0466938_5333O00_Ci3242M-000      4000                   **
**  COPYRIGHT (C) 1996-2009                 Altair Engineering, Inc.  **
** All Rights Reserved.  Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc.                 **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
   install config file: D:\Altair\hw10.0/hwsolvers/hwsolver.cfg
RADIOSS/OptiStruct error termination report:
  RAM:            1580 MB total,      1 MB used.
  Data arrays:     236 total,       158 allocated.
  DATA SET size      0 MB, ram_disk      0 MB
DATASET USAGE: ndirs: 1, nfiles 1, nsets: 0, nblocks: 0, mode: 8
DIR: 0, size 0[B], path "F:/7.24/hm/optistruct/" num_files 1
OptiStruct traceback info at: 01/13/11 08:40:19
Trace point: 1005
CPU times[sec]: user     93.750, system      7.391, Wall clock    101.156
Command line arguments:
F:/7.24/hm/optistruct/kuai-da-sym1.fem
-check
-exec=OS
File stats with output file root: kuai-da-sym1
Work directory: "./" Free size 209.3 GB
               0 kuai-da-sym1.2412_scr.s40
       187865257 kuai-da-sym1.fem
        26207246 kuai-da-sym1.hm
            1662 kuai-da-sym1.out
             634 kuai-da-sym1.stat
               0 kuai-da-sym1_2412_00.scr
Work directory: "F:/7.24/hm/optistruct/" Free size 209.3 GB
 楼主| 发表于 2011-1-13 10:23:31 | 显示全部楼层 来自 吉林长春
快帮帮忙吧!!!
发表于 2011-3-27 21:37:52 | 显示全部楼层 来自 辽宁大连
网格没画好吧,你按F10(check  elem)检查下网格质量
发表于 2011-4-6 13:46:20 | 显示全部楼层 来自 甘肃兰州
网格的错误 ,在仔细检查一下网格
GMT+8, 2024-7-3 09:01 , Processed in 0.042718 second(s), 14 queries , Gzip On, MemCache On.
