查看: 193|回复: 4
[电磁场] 请问三维圆柱体的感应加热模拟结果为什么不对称
发表于 2011-2-27 14:57:34 | 显示全部楼层 |阅读模式 来自 湖北武汉
这段时间一直在做三维的圆柱体的感应加热的模拟,使用帮助文件里的二维感应加热的例子的循环语句,但一直无法得到一个堆成的结果,以下是我的命令流,就是一个圆柱钢轴,外套一个感应线圈,其他部分用空气包裹。线圈,钢轴和线圈与钢轴间的空气都是使用的扫描网格划分,其他部分使用自由划分,一下是命令流,求高手指正,先谢谢了。
/TITLE, gangguan INDUC         !
/PREP7
EMUNIT,MKS                    !
*AFUN,DEG                     !
ET,1,SOLID117                 !
ET,2,SOLID117,1               !
ET,3,SOLID117                 !
MP,MURX,1,1                   !
MP,RSVX,1,0.1724E-8           !
MP,MURX,2,1.01                !
MP,RSVX,2,0.88E-6             !
MP,MURX,3,1                   !
*SET,FTIME,8                  !!!
*SET,TINC,0.5                                  !
*SET,TIME,0                                  !
*SET,DELT,0.1                                !
CYLIND,0.015, ,0.02,0.06,0,360
CYLIND,0.02,0.0175,0.05,0.06,0,360
CYLIND,0.015,0.0175,0.05,0.06,0,360
Vglue,all
NUMCMP,VOLU
lsel,s, , ,5,8,1                   !根据编号选择线段
lsel,a, , ,23,26,1
lsel,a, , ,19,22,1
lesize,all, , ,30
lsel,s, , ,51
lesize,all, , ,30
lsel,s, , ,53
lesize,all, , ,10
CYLIND,0.05,0,0,0.07,0,360
vovlap,all
NUMCMP,VOLU
VSEL,S,VOLUM, ,1              !将线圈标为1号材料,3
VATT,1,1,3
VSEL,S,VOLUM, ,3,4,1             !将空气标为3号材料,1
VATT,3,1,1
VSEL,S,VOLUM, ,2               !将钢标为2号材料,2
VATT,2,1,2
VSEL,ALL
vsweep,2
vsweep,3
vsweep,1
ESIZE,0.008,0,
VSEL, , , ,       4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
MSHKEY,0
MSHAPE,1,3d
FLST,2,1,6,ORDE,1
FITEM,2,4
VIMP,P51X,1
FINISH
/SOL
CSYS,1                                    !
ASEL,S,LOC,X,0.05                         !
ASEL,A,LOC,Z,0.07
ASEL,A,LOC,Z,0
DA,ALL,AZ,0                               !
ASEL,ALL
CSWPLA,11,1,1,1,                       !给单元创建柱坐标系
ESEL,S,MAT, ,1
TYPE,   1
MAT,       1
REAL,
ESYS,      11
SECNUM,
! TSHAP,LINE
BFE,ALL,JS,1, ,0.84E8
ESEL,ALL
ANTYP,HARM                                !
HARFR,80000                               !
PHYSICS,WRITE,EMAG                        !     写入emag
FINISH
/PREP7
LSCLEAR,ALL                               !
ET,1,0                                    !     将1号材料转换成0
ET,2,SOLID90                              !     将2号材料转换为SOLID90
ET,3,0                                    !     将3号单元转换成0
MP,KXX,2,30                                !!!!!传导率各向同性
MP,C,2,500                                !
MP,DENS,2,7900                            !
FINISH
/SOLU
ANTYPE,TRANS                              !
TOFFST,273
TUNIF,25                                  !
CNVTOL,HEAT,1                             !
KBC,1                                     !
TRNOPT,FULL
AUTOS,ON                                  !     自动时间-
DELTIM,5E-3,5E-4,DELT,ON                  !
OUTRES,BASIC,ALL                           !
PHYSICS,WRITE,THERMAL                      !     写入THERMAL
SAVE
FINISH
*DO,I,1,FTIME/TINC                    ! solution *do loop
*SET,TIME,TIME+TINC                        ! increment time
PHYSICS,READ,EMAG                     !read emag physics file
/SOLU
*IF,I,EQ,1,THEN
TUNIF,25                             ! initial temperature
*ELSE
LDREAD,TEMP,LAST,,,,,RTH             ! read thermal analysis temperatures
*ENDIF
SOLVE                                 ! solve harmonic analysis
FINISH
PHYSICS,READ,THERMAL                  ! read thermal physics file
/ASSIGN,ESAV,THERM,ESAV               ! redirect files for use in thermal restart
/ASSIGN,EMAT,THERM,EMAT
/SOLU
parsav,scalar,parameter,sav !save parameters before multiframe rest
*IF,I,GT,1,THEN
ANTYPE,TRANS,REST                    ! thermal restart
*ENDIF
parres,new,parameter,sav !restore parameters after multiframe re
TIME,TIME                             ! time at end of thermal run
ESEL,S,MAT,,2                         ! select billet region
LDREAD,HGEN,,,,2,,RST                 ! 从emag
ESEL,ALL
SOLVE
FINISH
/ASSIGN,ESAV                          ! reassign files to default
/ASSIGN,EMAT
*ENDDO
关于单元坐标轴,改不改的结果都是一样。
 楼主| 发表于 2011-2-27 18:15:50 | 显示全部楼层 来自 湖北武汉
各位大虾啊,出个主意吧,实在是困在这里好久了。。拜谢。
 楼主| 发表于 2011-2-28 10:19:37 | 显示全部楼层 来自 湖北武汉
自己顶一个。。。。。
发表于 2011-3-21 09:48:19 | 显示全部楼层 来自 台湾
这模拟是很吻合实际阿,看起来像边界效应,不知你的分析是想达到什么情形?
发表于 2011-3-30 13:17:38 | 显示全部楼层 来自 江苏南京
看着这图还不错啊
GMT+8, 2024-9-29 21:27 , Processed in 0.035789 second(s), 10 queries , Gzip On, MemCache On.
