查看: 491|回复: 5
[基础知识] 分析大模型遇到这个问题该怎么解决
发表于 2011-3-1 21:12:07 | 显示全部楼层 |阅读模式 来自 山西太原
悬赏6仿真币未解决
小弟分析一个大的模型,之前将模型拆成很多小块,都没有问题,但是综合起来出现一个类似于ADAMS设置问题,出现的错误信息如下:
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "ACPDOF" while allocating " INTE" space
   from "TEMP" for the "DOF temp array".
   Space Available:  5    Space Requested:  270
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   10,000,000
        HUGE       20,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
   Alternatively, you can start 'adams_settings.exe' in the 'utils\win32'
   folder of your ADAMS installation directory.
ERROR:   Abnormal termination encountered in ADAMS/Solver.
楼主啊,高手啊,大哥啊,帮个忙啊,小弟快跳楼了!
发表于 2011-3-1 21:46:02 | 显示全部楼层 来自 湖北宜昌
这个问题我来解决。
回复
发表于 2011-3-1 21:46:38 | 显示全部楼层 来自 湖北宜昌
直接qq联系我就行了,442956890,免费告诉你,相互学习嘛!
回复
发表于 2011-3-2 09:49:07 | 显示全部楼层 来自 湖北宜昌
寻找到安装文件ADAMS-settings,将AView-Preferences和ASolver-Preferences下的memSize修改为huge,ok即可。
回复
 楼主| 发表于 2011-3-6 21:00:09 | 显示全部楼层 来自 山西太原
老大,这个方法我试过了,但是还是不行,电脑的CPU使用率还是很低,不到15%,我的电脑是i7,内存8g的。还有别的什么办法吗
回复
发表于 2011-3-9 21:00:29 | 显示全部楼层 来自 重庆沙坪坝区
这个就是提示解决办法啊
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   10,000,000
        HUGE       20,000,000
这个是说明原因的
回复
GMT+8, 2026-1-2 20:07 , Processed in 0.040289 second(s), 11 queries , Gzip On, MemCache On.
