- 2006-8-7
楼主 |
发表于 2011-4-9 11:48:11
来自 江苏南京
D:\SoftWork\QHJX\01-freesize>REM HWVERSION_10.0build60_May 12 2009_9:20:48
bash.exe: warning: could not find /tmp, please create!
d:\Altair\hw10.0/hwsolvers/bin/win32/optistruct.exe D:/SoftWork/QHJX/01-freesize
/Opt-test.fem -exec=OS
Found config file: d:\Altair\hw10.0/hwsolvers/hwsolver.cfg
Preserving existing .out file as:
D:/SoftWork/QHJX/01-freesize/Opt-test_009.out
Preserving existing .stat file as:
D:/SoftWork/QHJX/01-freesize/Opt-test_009.stat
** OptiStruct 10.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows XP Professional SP3 (Build 2600) MONSTOR **
** 2 CPU: Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz **
** CPU speed 2550 MHz **
** 1190 MB RAM, 3939 MB swap **
** Build tag: 0466938_5333O00_Ci3242M-000 4000 **
** COPYRIGHT (C) 1996-2009 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
The amount of memory allocated for the run is 32 MB.
This run is intended to use incore processing in the solver.
OPTIMIZATION HAS CONVERGED.
FEASIBLE DESIGN.
Process completed successfully
D:\SoftWork\QHJX\01-freesize> |
