- 2008-4-4
发表于 2011-4-18 09:47:07
来自 新加坡
SECTYPE, SECID, Type, Subtype, Name, REFINEKEY
Associates section type information with a section ID number.
SECID
Section identification number.
Type BEAM
| — | Defines a beam section. See Beam Cross Section Subtypes.
| TAPER
| — | Defines a tapered beam section. The sections at the end points must be topologically identical.
| GENB
| — | Defines a nonlinear general (temperature-dependent) beam section.
| SHELL
| — | Defines a shell section.
| GENS
| — | Defines a preintegrated (temperature-dependent) shell section.
| PRETENSION
| — | Defines a pretension section.
| JOINT
| — | Defines a joint section.
| REINF
| — | Defines a reinforcement section.
例子如下:
sectype,1,beam,rect ! define cross section at first end pointsecdata,.0001,0.5sectype,2,beam,rect ! define cross section at far endsecdata,3,0.5sectype,3,taper ! new Section ID for tapered beam analysissecdata,1,0.0,0.0 ! section 1 at location (0,0,0)secdata,2,0.0,20.0 ! section 2 at location (0,20,0) |
