我有一个adams和easy5联合仿真的模型(别人建的)。我把easy5生成的。Dll文件挂上去之后,在adams里无法计算,并显示如下信息:
——————START:WARNING——————
cdriver::sensub:Adams/Controls assumes sensor/3 is associated with GSE/3.
To verify this,you can look at the 'adams_name"in the .admfile -- they prefix of the SENSOR should match the GSE name.
If this is not the case,you can:
1.Regenerate the model
2.Add a seventh parameter to your SENSOR user functionsto specify a different
GSE ID
3.Modify the appropriate GSE/SENSOR ID's in your .adm to match
